Question about Kenmore Washing Machines
Washing machine spins dry the clothes occasionally. sometimes, the clothes is still dripping wet after the washing cycle is finished.
  • Kenmore Master
  • 8,220 Answers
One thing you can do is:washing machine spins dry the - themobilian_141.jpgthemobilian_142.jpgthemobilian_143.jpg
Posted on Nov 15, 2010
Doesn't dry clothes properly after spin cycle clothes are wet when cycle finishes It empties water
Bad belt will not allow drum to reach full rpm during spin cycle, not spinning all water out of clothes
Sep 15, 2015 | Washing Machines
Clothes are too wet when finished washing. water drips from clothes.The spin cycle seems to be spinning as the clothes are against the outside wall of the tub. we have the extra spin cycle used aslo and it...
Transmission is bad. Buy new washer. Best brands are (Kenmore, Whirlpool, Maytag).
Thanks and Please Rate me! Tips provided by www.HoustonRefrigeratorRepair.com Brian Gillespie (GOFAR Services, LLC)
Aug 26, 2011 | GE WPRE6150HWT
Spins but laundry is still dripping wet
This happens to me sometimes. My washing machine doesn't drain right into the drain, I have a pipe coming out of the back of the machine that I have to hook into the kitchen sink myself to let the water drain out. My washing machine was still full and I realized that it was because my sink was a little blocked and so it was draining too slowly and leaving water in the machine. If there was too much water, it would sometimes help to put the machine on again or put it on a drain cycle. My machine doesn't have a spin cycle so it will just give your clothes an extra spin so I couldn't do that and my clothes would still come out dripping wet. I advise that you give them another spin before you take them out if possible! xxThe fact that the washing machine is spinning but not drying clothes shows that there is some problem with the outlet of water. The water outlet is blocked. You can check for the blockage yourself. Normally threads or other waste accumulate in the water outlet, and if possible you can remove it yourself. Otherwise call your washing machine's customer services center and ask them to send a repair man
May 01, 2011 | Smeg Washing Machines
In the permanent press cycle only the spin cycle isn't spinning enough. Clothes are extremely wet must run another spin to get out the water.
Thts right....the permanent press cycle my only spin at 600rpm because the clothes would be creased otherwise. Hence the PP cycle.
Some machines lock the PP cycle to low spin RPM. Some allow you to over ride this setting. Check your machine and have a play with the controls. Some PP clothing should even be drip dry to retain the premanent press in the garment. If you want PP then low spin is needed. fast spin will not be a PP cycle...
Aug 07, 2010 | Washing Machines
My wash machine wash the clothes but not doing the final spin, all the clothes all soak and wet
Handyman here -
Its possible that the door is not locking properly. If the door doesn't lock the machine will wash, but not spin the clothes dry. If you wait 15mins or so after machine is done, then set cycle to spin, it will pump any water that has dripped off your clothes out, but again it will not spin. Helps a little.
Good Luck!
Apr 03, 2010 | Frigidaire ATF6000ES Front Load Washer
Maytag top loader on final spin cycle leaves the clothes soaked
how much water is in the bottom of the tub and is it louder than normal if so could be small droplets of water leaking from tub seal if not the pump is restricted by something and req replacement
Aug 20, 2009 | Maytag Washing Machines
Clothes way too wet after washing
your washer is not hitting high speed spin thats why the cloths are still wet,bad transmission,sorry-mike
Jun 03, 2009 | Kenmore Washing Machines
Dripping wet clothes
will be an UNBalanced load, maybe there was not enough clothes in the load so in that case the drum would not be able to distribute the load evenly so gave up on the spin, hence wet stuff!
Jan 27, 2009 | Haier Washing Machines
Cloths Soaked after Spin Cycle
If the motor has a transmission, it could be stuck in 1st gear. I think the agitator running is normal.
Jan 17, 2009 | LG WM1814CW Front Load Washer
Top load does not spin dry the clothes
Transmission or solenoid that should pick and put transmission into spin. I bet it's a kenmore or similar.
Mar 08, 2008 | Washing Machines
Washing Machines Logo
70 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
