Question about Lincoln Electric LE 83180 Century Professional MIG/Flux Wire-Feed Welder
Broken wire speed switch - Lincoln Electric LE 83180 Century Professional MIG/Flux Wire-Feed Welder
  • 407 Answers
You can fix it yourself, take the potentiometer (also known as reohstat) out.You will need to open the machine and take the knob off to free it out. You can take the old potentiometer to any electrical shop, or go to your nearest welding shop/store I will recommend praxair store.
Posted on Jan 13, 2011
Broken 3-speed ceiling fan switch
Observe and read manual carefully
Jul 23, 2016 | Dryers
Switch doesnt change speed runs on hight
Only between zero and full speed high speed > replace switch inside or sometimes outside the switch there is a mosfet broken if its outside mounted on a metal heatsink laying against the motor with a 3 wire black or a 3 wire black, blue, yellow wire that little parts is damaged sometimes its separate to find in a shop but replacing a switch is not a very hard job. a switch suggestion let you see a replaceable mosfet on this side the heatsink with mosfet regulator on the side of the switch.
Apr 18, 2016 | Saws
My kitchen aid will work up to speed 4 or 5 but then stops after this. Ive never had this problem before. its happening with all the attachments.
It sounds like a problem under the back cover, maybe a broken wire on the speed controller plate. If you take the cover off to look please remember to unplug it first. If it isn't a broken wire I would be looking at the switch contacts on the inside of the speed control plate operated by that flat rid from the speed control lever.
Mar 17, 2015 | Food Mixers
No heat or variable speed on steinal heat gun
No heat- broken or burnt element wire ( a coiled spring like wire element) May have broken of where it screws on to the circuit.Check for burn marks inside the housing. No variable speed- faulty/burned switch or riostat.
Feb 23, 2013 | Tools & Hardware - Others
I have a Hampton Bay 3 speed fan. Replaced the switch that was broken but cannot get the speeds to switch correctly. fan will not turn off. and the speeds does not change. I have switched the wires around...
Most likely you have the wrong switch. You ncan't go to Home depot or Lowes and buy a generic switch off the rack and expect it to work (no matter what they tell you)Call Hunter & order switch #6378401000. 1-888-830-1326
Feb 13, 2013 | Hunter Low Profile III 20807 Ceiling Fan
I have a ceiling fan switch (Westinghouse 77075) that was broken, so I do not know where the wires (black, gray, yellow and purple) went. The speeds are black+gray+yellow, black+gray+purple, and...
I can offer resources:
1) Test switch that was removed, and test for hot connection to narrow down options.
What speed was fan stuck in when switch was removed? Let's say medium speed.
Which connection at fan is hot? Use voltage tester to find hot connection at fan, and match that up with wire-color on switch that was removed.
One and only one wire on 3-speed fan switch connects to hot. And the hot wire is the only wire that connects to each other wire as switch cycles through pull-chain sequence. All pull chain switches follow same sequence: off, low, medium, high.
Let's say old switch was stuck in medium, and you know which color wire connects to hot.
Test switch with continuity tester to see which wire(s) have continuity with hot wire: some switches, it will be 2 wires, and other switches it will be 1 wire. Match where wire(s) were connected, and map that to tests on new switch.
2) Open following link for illustrations and some other links.
http://waterheatertimer.org/How-to-wire-Cooper-277-pilot-light-switch.html#3-speed
Sep 16, 2011 | Speed Ceiling Fan 3-speed Switch By...
Wiring on a 3 speed rotary switch for a fan (cord type),the switch just broken and i want make a connection on wires for just to run at only one speed.
put the 2 white wires together then try one of the other wires from the fan to the black power wire,if to slow try the other wire if that speed works tape off the other wire . it should be white to white and red to black green is ground
Sep 03, 2009 | Patton U2-1487 Floor / Box Fan
Just replaced broken pull 3-speed switch. Fan now only runs on two speeds, need wiring diagram please
I ran into this when replacing the 3 spd switch. The replacement switch has a pair of connections at each position; you would assume the two connections are electrically tied together, they are not. The switch assembly actually has two seperate 4-position rotary switches. If your "L" wire is on the 'inner' connection, then your motor speed wires will have to be as well.
Jul 27, 2009 | Hunter Dryers
Fan switch broken, wires out when opened
I googled Hampton Bay Manufacturing and this is what I found:
Hampton Bay fans are manufactured by "King of Fans Manufacturing, FL". The contact number for them is 800-330-3267. ...
Maybe they can supply you with a wiring diagram.
Jun 08, 2008 | Dryers
Lincoln Electric LE 83180 Century Professional MIG/Flux Wire-Feed Welder Logo
213 people viewed this question
Top Lincoln Welding Tools Experts
Steve
Robert Monigold
Robert Monigold
Are you a Lincoln Welding Tool Expert? Answer questions, earn points and help others
