Question about LG Televison & Video
Where can I find an LG DLP ballast? I ran into a couple online but it's a different part number. Ours is 3850VC0098D (other numbers I saw 913700711405 and EVC120p-11). Had a TV repairman come and he said our lamp was good and it's the ballast that needs to be replaced. Our TV tries to power on but then after a few minutes it just starts blinking red.
  • 1153 Answers
SOURCE: rca 50 dlp hd50lpw175
Yes but did you find a fuse open and changed it?
Posted on Jan 08, 2008
SOURCE: how to replace ballast in toshiba 52hm84 dlp rear tv.
how do I change the lamp?
Posted on May 15, 2009
  • 304 Answers
SOURCE: Lamp Light still on after replacement
First, A common mistake made is when you insert the orange ribbon cable from the Color Wheel into the DMD bd. To correctly insert the Ribbon Cable you need to look at both sides. You will see a shiny silver side and a dull black/orange side. You must insert the shiny silver side AWAY from the Color Wheel or towards the rear of the set. Now for the Ballast. When you power up the tv,Do you hear a short Buzzing sound? If you do that means that the Ballast is trying to fire up the Lamp and is working. Next, do you hear the Color Wheel spin up? If you do not then you have installed the Color Wheel incorrectly and you need to repeat the installation while making sure that you hold the rubber gasket in perfect place or else it won,t work. Chances are the gasket is in the wrong position and is binding the Glass Wheel. The Ballast is on the right side of the engine and on top of the Lamp Housing. You will see two RED High Voltage wires coming out of one end. Don't worry, there is no stored voltage in the ballast so you won't get a shock providing you have unplugged the tv from the outlet. That is the first step before you change any parts any way. Listen for the correct start sequence. With the rear backing off and the Safety Interlock Switch is being held in the up position, turn on the set. First sound you hear is a clicking which is the power on relay engageing. Then you will hear the fans turn on and then the Color Wheel spin up. Once the Color Wheel spins up and comes to full RPM then the Exciter on the Ballast will Buzz for less than half a second and then the Lamp should light up. Now if you have installed the correct Lamp and correctly installed the Color Wheel and you either are holding up the Interlock Switch or have reinstalled the rear cover and tightened all of the screws you should have a working tv.
Posted on Jul 16, 2009
  • 52 Answers
SOURCE: Mitubishi WD 62725 - Ballast Problem??
Could be the FMT pcb or the Dm pcb board you should check the caps on them and replace any faulty ones.
Posted on Nov 14, 2009
Slinteriors
  • 8617 Answers
SOURCE: Samsung DLP HL-R5667W lamp won't fire. Changed
Was the replacement lamp the same part number as the original as there are different arc gaps for different lamps and the wrong arc gap will cause the lamp not to light. Since the ballast is powering up the lamp should light if the baalast is matched to the correct arc gap of the lamp being used.
Posted on Nov 27, 2009
I was told I need a new lamp ballast assembly. I was also told by someone to order 6913V00002C Ballast (EUC 100 P/11) but when I opened my TV and took out the "bad" ballast, its is a EUC 100 C/00. Anybody...
so the one first is an LG model ballast but the one in the tv is a phillips one, strange.. can you give me the bord number power side... it is always best to replace old number so the damaged numer one should be the number you use. LG, Philips etc use different part to make the same tv model. e.g one can be made in twain and the other from china. both the same case do the same things but have completely different parts in side. Looking at the parts on line they don't have the same connections or the same voltage so would be a bad idea to try and put the new one in with the wrong number.
Oct 22, 2013 | LG RU-60SZ30 60" Rear Projection...
My LG projection tv (serial number 52sx4d-ub) won't turn on, an orange light flashes then turns red. How do I know if I need to change the bulb or the ballast? And how much does it cost to change the...
Orange blinking light under a small picture of a light bulb? Then turns to a red light?
Sounds like the same problem I had when I picked up my LG 52SZ8R. After replacing the lamp the TV ran fine.
Easiest way to see if the lamp is the problem is to take it out, and look at the peice of wire in the globe as you would an old light globe.
If you need help, download the following manual, and look at page 9.
http://www.jordansmanuals.com/ServiceManuals/LG/TV/PROJECTION/62SX4R/62SX4R%20Service%20Manual.pdf
If it does come down to you needing to replace the ballast contact: http://www.statewideapp.com.au/index.php?selectedContent=1188381775
They should be able to give you a quote and part number, if you don't like their quote you can always use the part number to search for one thats cheaper.
Mar 07, 2011 | LG 52SX4D 52" HDTV
I have a toshiba 46hm94p dlp tv. i need to replace the ballast. i pulled the tv apart and got the part number off the ballast, it is RPB-4434ZA . when i look that up by the part number it says its the...
yes they both the same part number one is board number and other is manufacturer number, board number is what it is and manufacture number is if its in other tvs.
Jul 15, 2017 | Toshiba TheaterWide 46HM94 46" Rear...
How to change the oil pump on the chainsaw model pcn 4545
Patrick;
I could not find anything matching the number you provided. I did find an electric saw "RY43006 Chain Saw" here (follow the instructions):
Homelite/Ryobi.com (authorized parts supplier)
https://www.gardnerinc.com/recons/disclaimer-lg.php - Agree; Choose “Product Line”; “Select OEM” & “Select Catalog” both to “Homelite Consumer Products”. A drop down list appears; self explanatory from here.
The numbers Homelite & Ryobi use do not match the numbers everyone posts. A careful inspection of your saw should find something that matches.
I think with the IPL as a disassembly guide replacement is pretty easy. There are a couple of hoses listed, I suspect one of them failed rather than the pump.
If this is not your saw please provide some different numbers (reply below) and I will try again. Good Luck. HTH
Lou
Feb 25, 2010 | Ryobi 18-inch Electric Chainsaw Chain Saws
Samsung DLP HL-R5667W lamp won't fire. Changed lamp & ballast and still won't work. Fans are working fine, color wheel good. Lamp door switch good. When I power on, I hear ballast buzz like it's trying...
Nov 27, 2009 | Samsung HLR5667W 56" Rear Projection HDTV
TV keeps turning itself off, how to stop this? Thank you
CK all of your Fans and you may have Bad Ballast Board. But Start with fans if they stop running set will turn off also go to Encompas Parts online look up your Model Number or call them 1-80-638-3328 and you could have defective Lamp if Lamp has never been replaced and all fans are running then its the Lamp! If Lamp does not come on its the Ballast or Bad Fans.
Nov 23, 2009 | Samsung HL-S5087W DLP TV
Looking for a ballast part number and price Mitsubishi WD-C657
encompass.com or parstore.com is a good store parts.
Just provide model number tv.
Thank you
Aug 06, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Ballast question
The site I work for has the same manual as you most likely as its the factory service manual. So we dont have the schematic either
May 13, 2008 | LG RU-60SZ30 60" Rear Projection...
Ballast replacement
Your set uses the Phillips UPH100W 1.3 100http://servicemanuals.vstore.ca/ 1amp bulb part number 6912V00006A which uses Ballast EUC 6913V0002A and the actual ballast isMB03CA part number 6871VSMB13F I would contact LG and give them these numbers. Is your ballast bad or is the BallastEUC bad? Let me know if I can help you further.
May 12, 2008 | LG RU-60SZ30 60" Rear Projection...
Toshiba Ballast part number
Use the following part number: 23122468. The cost is $48.38 from TRITRONICSINC.COM
Dan
Mar 18, 2008 | Televison & Video
Televison & Video Logo
156 people viewed this question
Computer Repairing
Computer Repairing
