Question about Eureka 4700A Maxima Bagless Upright Vacuum
The brush doesn't rotate - Eureka 4700A Maxima Bagless Upright Vacuum
Changed filters in my shark rotator pro and now it doesn’t suck through floor brush.
If the brush roll isn't spinning fast enough it will not pick anything up off carpet leading many people to think they don't have suction. Check your belt.
Mar 28, 2018 | Shark Vacuums
Brissell proheata 2x doesn't have suction or the red brushes won't rotate on the hand tools?
Check the brushes for hair or some other clogging material and remove it. If the brushes can't spin freely, there is not enough suction power to make them spin.
Sep 17, 2012 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bottom agitator brush bar doesn't rotate.
First, check to make sure the brush bar is on. The switch is right next to the machine's on-off button, and it is easy to accidentally turn it off when you turn the DC 25 on or off.
Next, check for and clear any obstructions in the brush bar housing.
Finally, check for belt wear and replace if necessary. There is a very video online showing the procedure.
Jul 21, 2012 | Dyson DC25 All Floors Bagless Upright...
Brush bar doesn't rotate.
Either the bearing in the rotating brush is bad and isn't allowing the brush to turn, or in the majority of cases, the belt is broken.
May 20, 2012 | Vacuums
Dyson dc14 brush bar is not turning at all. Everything else seems to be fine. I just replaced the brush bar but still no movement. What else could it be?
I'm sorry to hear you're having difficulty with your DC14 Animal. If the brushbar doesn't rotate, please check you have the brush control set to 'Carpets', not 'Hard floors'. The brushbar will not rotate when the machine is standing upright, so please recline it into the vacuuming position before testing it.
If this doesn't resolve the issue, please give our Helpline a call on 0800 298 0298 (UK), or 1-866-693-9766 (US), so we can provide further assistance.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Mar 24, 2012 | Dyson DC14 Animal Bagless Upright Cyclonic...
What is wrong when the roller doesn't move when my
I'm sorry to hear you're having difficulties with your DC07. Please check you have the brush control set to 'Carpets', as the brushbar will not rotate when you have the brush control set to 'Hard Floors'.
If the brush control is set to 'Carpets', and the brushbar will not rotate when the machine is reclined into the vacuuming position, I'd encourage you to contact us directly so we can provide further assistance. You can call us free on 0800 298 0298 (UK), or 1-866-693-9766 (US) - please have the machine to hand when you call.
Best wishes,
Jack
http://www.dyson.com/
Jan 15, 2012 | Vacuums
I can't switch from the brushless option to the rotating brush option.
You should be able to turn the brushbar on using the brush control on the cleaner's head, turning it from the 'Hard floors' to the 'Carpets' setting. For further guidance, you might find it helps to refer to the user guide supplied with the cleaner. In case you don't have this to hand, you can download a copy here:
http://media.dyson.com/downloads/us/floorcare/manuals/dc07_opmanual_usa.pdf
However, if the brushbar doesn't seem to be rotating when the brush control is set to 'Carpets', it's probably best if you get in touch with us directly so we can help. You can call us free on 08002980298 (UK), or 1866MYDYSON (US).
Kind regards,
Jack
Oct 17, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
The brushes won't turn, and cleaning the filter (as suggested in the owner's manual) doesn't help.
Hi ken wright.
Remove the bottom of the head of the vacuum...remove the roller brush assembly.
Clean the assembly...remove the end caps and clear all hair,strings,etc from the end cap and rotating brush head.
After cleaning the brush head and bearings, lube the bearings with a good grade of machine oil such as 3 in 1 oil.
Check your belt condition.
Reassemble and you should be good to go
Please take time to rate me
Sep 05, 2011 | Vacuums
The brushes are not turning I have cleared them of hair and such like but still will not turn
I'm sorry to hear you're having difficulties with your DC14. If the brushbar is free of obstructions, but doesn't seem to rotate, please check that you have the brush control set to 'Carpets', and that you have the cleaner reclined into the vacuuming position. The brushbar will never rotate when the cleaner is standing in the upright position, or if you have the brush control set to 'Hard Floors'.
If you're certain the brush control is correctly adjusted and the brushbar will not rotate, it's probably best if you get in touch with us directly so one of our experts can assist you in resolving this as quickly as possible. You can call us free on 08002980298 (UK), or 1866MYDYSON (US).
Kind regards,
Jack
Jul 03, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
Eureka 4700A Maxima Bagless Upright Vacuum Logo
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
