My polaroid hdtv model 2700 screen 27 inch, when i turn on the video screen on for a while, then it's shutting down by itseft, and i heard some noise from the back of the tv. thank.
  • 335 Answers
The power-supply board needs to be serviced or replaced, the noise you hear is one of the switching transformers arcing contently. This could be from a cold solder joint along the AC input connections or a faulty switching regulator. This shouldn't cost much to repair at your local shop, or maybe you can do it yourself if so I'll walk you through what too do. Its important that your technically proficient to do it yourself otherwise have a professional do it for you.
http://tvtechwork.webs.com/
Posted on Nov 15, 2010
Some time turn on some time don't, some time cut off by itseft
If the problem is same with different input devices and you have ensured the are no loose contacts in power outlet, RC jack, cable and sockets, the TV needs servicing.
Aug 16, 2012 | Olevia LT27HVX 27 in. LCD Television
Turned back light down on my polaroid 4GB pmp280-4 touch screen now i cant see to turn it back up
settings is in the lower right hand side of the screen, tap there.
display is in the middle of the screen on the left hand side about one(1) inch down from the top of the screen.
the slider for brightness is down one and one-forth inches down from the top of the screen, tap about 1 inch from the left hand side of the screen, remember it is 1 1/4 inches down the screen.
NCMB
Jan 22, 2011 | Audio Players & Recorders
Hdtv 27" screen polaroid model 2700 , problem is
This is a classic "Hic-upping" switchmode power supply problem. The protection circuitry inside the SMPSU, has sensed a severe potential problem, and is attempting the shutting of the set, down to avoid a fire, explosion, or both.
This set had developed a problem, that is so severe that the set must be shut down, (This set should be removed from the Power),
What is happening is the internal "Fault" that is causing the Protection Circuitry , to detect the problem and attempt to shut down the set, keeps restarting the set, because as soon as it shuts down, the "Faulty" component(s) cool down?, and the "Fault" ostensibly "Clears" so the PSU starts up again, only for the component(s) to heat up, whatever, again and fail, so it shuts down, and if left unattended, this would continue on until the part eventually failed. As related this is called a "Hic-upping Power Supply". Any fault that involves the power supply is usually quite serious, and needs a professional, usually, unless one is familiar with servicing current day, televisions. It is the "Noise" that gives it away, among other things.
And in my professional recommendation, you should get a "Quote" for repair, from, an, Approved Service Center. Now, this point is very important for a good result, Always contact, their "Local" or a, "Head Office" Philips in your case. Ask them, for a referral to an authorised servicing center, where you ask for a "Quote". Now, when you get the information you want, then you can decide as to repair of replacement.
The reason we want an approved agent, is that way, all the engineers are trained on their own brand sets, they have seen almost all faults, and will get the job done quicker, and for less cost, and usually have parts on hand, also sometimes, there has been a service bulletin in issued and the repair may be subsided or even free. There are many, many, many reasons that display this symptom, one must work through the troubleshooting steps to isolate and identify, the Cause and repair that and any damage done.
Nov 15, 2010 | Polaroid Televison & Video
Poloraid hdtv 36 inch model FLM 3201 PICTURE
FAULTY POWER SUPPLY OR INVERTER PANEL ON BACK OF SCREEN
AVERAGE REPAIR COST £60 TO £80+
Aug 25, 2010 | Polaroid FLM-3734B 37 in. LCD HDTV
My Polaroid HDTV, the screen turned blue i heard it was the capacitors but im not shure the model # is TLA-04841C and serial FR7B0215560001737 if you know whats wrong would you help me.
Might be the caps. Usually though you won't get any OSD-on screen display when it is the caps. Could also be the YSUS-Main.
Best regards and Semper Fi
Aug 06, 2010 | Televison & Video
My 19 inch Polaroid FLM-1911 900t shows a white screen
your t-con board has failed check shop jimmy/com see uf they have a replacement
polaroids are hard to find parts
Sep 20, 2009 | Polaroid FLM-2011 Television
A owners manual for a 27 inch polaroid flat screen
google this owners manual model number: TDA-03211C
Mar 26, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
Televison & Video Logo
114 people viewed this question
Top Televison & Video Experts
