Question about Ultra Linear UL-2200D Car Audio Amplifier
What size fuse does my Ultra Linear UL-2200D 400W amp use?
2 Suggested Answers
  • 631 Answers
SOURCE: ultra linear ul-600hc
If the amp is in protect mode, it probably has shorted output transistors. To eliminate other possible problems, do the following. I'll assume that you've checked the amplifier's on-board fuses.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
If the voltage remains near or above 12v, disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down, the amp almost certainly has shorted output transistors and will need to be repaired.
Let me know if you have any other questions.
Posted on Aug 26, 2008
Pa amp plays and then stops plays again
Please give more details. When does it cut off? Is it hot?
Jan 02, 2014 | Ultra Linear UL-2200D Car Audio Amplifier
Al-811 does not power up when i turn power on
Use a test light or Multimeter to verify that you have at least 12volts on your remote wire as well as your Power cable.
Mar 31, 2013 | Ultra Linear UL-2200D Car Audio Amplifier
The light of my amp turns on and off
your sub/s are drawing to much power adjust the bass boost
Aug 24, 2009 | Ultra Linear UL-2200D Car Audio Amplifier
CONNECTING 2 12" L7 TO US AMP MD1
IF THE AMP IS BRIDGEABLE, THEN BRIDGE THEM. IF NOT THEN RUN THEM MONO. THE TYPE OF VEHICLE HAS ALOT TO DO WITH HOW TO HOOK THEM UP.
Feb 23, 2009 | Ultra Linear UL-2200D Car Audio Amplifier
Fix for overheated Kustom KPM 7250 PA amp
You can start by trying a new fuse, use the correct fuse for your amp. If the fuse is blown, you can look at it and see the middle is burnt connecting the two sides.
Jan 16, 2009 | Ultra Linear UL-2200D Car Audio Amplifier
Power light on the amp goes on after 5 sec off ultra linear 1200
If you run the remote from the battery you will need a on/off switch. Sounds like the amp is overheating. Also, I don't understand bridge the remote and power. They should be seperate going into the amp.
Dec 23, 2008 | Ultra Linear UL-2200D Car Audio Amplifier
I have problem with my mono amplifier
Amplifiers have thermal protection. They will typically shut down at ~180F. If your amp is shutting down after running it hard for 20-30 minutes, you may not have the correct load impedance (speakers wired incorrectly).
If it overheats as soon as it's switched on (no audio), the amp may be in need of repair.
Jun 21, 2008 | Ultra Linear UL-2200D Car Audio Amplifier
Ultra Linear UL-2200D Car Audio Amplifier Logo
70 people viewed this question
Top Ultra Linear Car Audio & Video Experts
Professor_V
Professor_V
FastHarley
FastHarley
matthew nulph
Level 1 Expert
Are you an Ultra Linear Car Audio and Video Expert? Answer questions, earn points and help others
