Question about Zebra 105SL Thermal Label Printer
Paper out light comes on at 105sl printer
My 105SL Zebra printer has aproblem :
error condition paper out warning light comes on , error light flashing , pause light comes on and cancel green light comes on .
notes:
1-this is the first time I use the printer (its new).
2- I follow up the trouplshooting procedures in the manual.
3-I make adjuste (calibrate) for both media sensores and make manual calibration for media but problem still on.
the lower sensor (source light) the light does not light ! I dont know if it must light or not.
part number of label (strap tie down label) is :CM-SCE-1/4-4H-9
AND i USE Rippon (110.0X 300M Ink coated out black lot:7d62-74
or no. 742412-000 Reorder number 1330-0607-10 )
thanks for your help
Khaled Raja (Jordan Aeronitical Company system)
e mail : khaladraja@yahoo.com
  • hcjoshi4 May 11, 2010
    What data you are sending to the printer?Can you post it?
    What Mediatype u are using(Thremal Transfre or themal Direct)?
Dear team
sorry for lating to response to your question amd thanks very much for your help, the answers for your questions as follows:
the date i sent to printer through PC is anumber example( 2w1x326)
I use Thremal Transfre Mediatype
thanks very much
Posted on Jul 16, 2008
Zebra 105sl printer labels print too small
There are 3 different DPI Printheads for Zebra printers if you print a label set up for a 200 DPI Printhead on a printer with a 300 DPI Printhead installed it will be about 66% of the size.
Feb 13, 2014 | Zebra 105SL Thermal Label Printer
We have a Zebra 105SL thermal printer. When I print to it with any application, the error light and paper out comes on.
Sounds like it may need a calibration. Press the calibration button on the front of the machine.
Nov 28, 2013 | Zebra 105SL Thermal Label Printer
We have a Zebra 105SL thermal printer. When I print to it with any application, the data light comes on, but it doesn't print. It has ribbon, media, calibrated, no error lights
The data light indicates that the printer is receiving data. Hold the cancel key for 10 seconds while powering on. This will print printer configuration. Use to troubleshoot. If the data or format is wrong it will not print as you send data. Make sure you are using the 105SL printer driver. To test the printer functionality you can go to www.teklynx.com and download a demo copy of labelveiw, select the 105SL printer and try to print a simple label. If you can print with labelveiw then it is not a printer problem. Double check your driver and label format.
Nov 12, 2010 | Zebra 105SL Thermal Label Printer
I am trying to print a label on the zebra 105SL but the font and the "text boxes" are printing too large like it is zoomed out - how do I resolve this issue?
I am trying to print a label on the zebra 105SL but the font ...
www.fixya.com/support/t5406223-am_trying_print_label_zebra_105sl
Jul 11, 2010 - I am trying to print a label on the zebra 105SL but the font and the "text boxes" are printing too large like it is zoomed out - how do I resolve this ...
db:: 4.67::Crystal Report Label Won't Send To Zebra k9
www.hivmr.com/db/k99xad9dfspspddfs1scm9fzxxkdz9dj
My routine can print the label to any other laser printer, but the Zebra. ... I am tryingto find a way to print actual time a smartform label gets printed out on a zebra ... In this i want to changeCross Tab expert Row Label Font,Cross Tab expert ..... And labelpaper too. ..... DB:2.73:Zebra 105sl And Crystal Report Label Issues 1d.
db:: 5.16::Help My printer is printing in 3x5 documents and I ...
www.hivmr.com/db/xkzpajp81937ap7zdf87sdmsxmcm179m
DB:4.06:Printing 3x5 Continuous Feed Labels On Hp Officejet 6100 d8 ... Are they toosmall? ... I want to help you but I am not sure I can be of much help until I know what kind ... If the paper size is 3.5x5 but you are trying to print a 3x5 photo (which seems to be ...... I have a label format issue on a Zebra 105SL label printer.
db:: 4.15::Custom label sizes md - Hivmr
Jul 11, 2010 | Office Equipment & Supplies
Zebra 105sl felt paper error
check if the sensors behind the printhead (small metal open case)is on the same position that the uper sensor(black plastic bit with the screw behind the printhead) Run the sensor profile, check if he check the gap.
run manual calibration from the settings.
worst case senario, Reset the printer to Factory defult (Press PAUSE and CANCEL buttons and tun printer on, then relese the butons after 5 secounds.
Jul 06, 2010 | Zebra 105SL Thermal Label Printer
Zebra 105SL thermal Label Printer prints blank with new supplies
Some possible reasons:
1. The darkness is not set high enough for the paper/ribbon combination
2. The ribbon is on backwards. Zebra uses coated-side out ribbons so the ribbon should be coming off the right side of the roll if you're looking at it from the side.
Hope that helps !
Apr 16, 2010 | Zebra 105SL Thermal Label Printer
Zebra s4m error condtion paper out
Sounds like you will need to perform the calibration procedure.
when you access the menu system go to advanced menu, the password is 9999, use the keys to navigate to manual calibration and follow the instructions. when it states load backing this is refering to backing paper, so remove the labels from the backing and place in label path. hope this helps
Jan 16, 2009 | Zebra 105SL Thermal Label Printer
105SL PRINTER PAPER OUT PROBLEM
Jun 19, 2008 | Zebra 105SL Thermal Label Printer
Zebra 105SL Thermal Label Printer Logo
669 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
