Question about Jenn-Air 30 in. CCE3401 Electric Cooktop
I have a Jenn-Aire model CCE3401B cooktop. One of the single 6" burners no longer works. I've checked continuity on the heating element itself, and it's OK. What else can I check? I have the power off and the unit exposed with the glass top removed. There's another 6" single burner on the unit that works, and I've tried to compare the two (with power off), and found no difference.
fridgetech
  • 473 Answers
SOURCE: knob not working and some burners not heating
The switch under that knob is bad.  It's called an infinite switch.  As far as the elements go, first thing to check is for proper voltage (220) to the cooktop.  Let me know what you find.
Posted on Oct 19, 2007
  • 161 Answers
SOURCE: GE Cooktop JP930 surface element not working
It sounds like the burner needs to be replaced. When they burn out sometimes they short out to ground. The cooktop will have to be removed from the counter and the glass top opened. You will probably be able to see where the element is burned out. Replace it and you should be fine. If it is too expensive to fix just disconnect the wires to the burner where they attach to the control . Then you can use the remaining burners. I really don't know what a replacement burner costs. An open coil is around $30.
Posted on Jul 15, 2008
Eddie Rentas
  • 59 Answers
SOURCE: replace glass top
Hello Bob
I have attached the link for you to request the manual for that stove....just go there and fill out the form and they will email you the manual in a few hours....I did the same thing and I got it the same day.
http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=JA_EN_US
Eddie Rentas
Tupper Lake NY
Posted on Jul 19, 2008
  • 530 Answers
SOURCE: Romvoing the top of my Whirlpool Cooktop
well usually you have to remove the knobs. thentake all of the caps off of the burners. sometimes there are scres that hold the burner caps on. make sure you turn the power off. Then after you have done this the glass should come right off. If not there may be screws under the cooktop. Do these first steps and let me know how it goes.
Posted on Jan 18, 2009
I have a Jenn Air radiant glass cooktop, model CCE3401B. The left rear burner will not heat. Howver the indicator light under the control knob stays on continuously, regardless of the position of the...
If the light circle around the knob stayed on, then you have the same problem I just had. I purchased a OEM replacement switch via ebay for $38. Very simple replacement, but take your time so you understand how it works. It took an hour to install and works fine now. Here is the link to the parts list:
shared.whirlpoolcorp.com/assets/pdfs/literature/Repair Part List - CCE3401B.pdf
If you can, take pictures with your phone of how everything is assembled before you take it apart. It will save you hours of aggravation.
I must say, Jenn-Aire (Whirlpool Corp) was less than helpful. I asked for some advice prior to purchasing the replacement part and all they would tell me is they were willing to schedule an authorized repair shop to come over. The closest was a 2.5 hour drive each way, and the travel time cost was $85/hour. Plus the part at list price ($90 something) and installation was going to cost $600. Give me a break.
Dec 31, 2010 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Jenn Aire gas cooktop
sounds like your initor button is stuck. If you are able to remove it, take a look and see if you can adjust it. If not, it will have to be replaced. Good luck.
Jul 14, 2010 | Jenn-Air JGA8100AD Cooktop
My Jenn AirCooktop Model CVE3401 burner problems
The part you need to replace is the switch. The switch is housed under the top and connects to the dial you are turning.
The switch for the dual burner is 12002125, and 74011242 for the single burner.
The single burner switch runs about $20.00 and the dual runs about $50.00 for the parts
Apr 24, 2010 | Jenn-Air 30 in. CVE3401 Electric Cooktop
Right front burner fails to heat (at all) Jenn air
I suspect a faulty element or electrical connection to the element.
Mar 21, 2010 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Jenn-aire downdraft electric heating problem
Be sure the control is set to F* and not C*.
always unplug electricity before attempting to repair on any electrical appliance
Aug 12, 2017 | Jenn-Air JED8230 Electric Cooktop
Circuit Braker Jumps Off
You probably have a burnt out element. They almost always short out when they burn out. If it is a coil unit it may be visible. A smooth top unit can't be diagnosed without removing the top glass. Most of the time you can do this yourself. Sometimes when a burner goes it will ruin the switch also.
Mar 29, 2008 | Jenn-Air 30 in. CCE3401 Electric Cooktop
JennAir Elec Cooktop Problem
The selector knob having lose contact the elements are for full adjument , the wire connection are rust and corroded need to clean terminal of elements.
Jan 04, 2008 | Jenn-Air 35 in. JEC9536ADS Electric...
Knob not working and some burners not heating
Oct 19, 2007 | Jenn-Air JED8430 Electric Cooktop
Jenn-Air 30 in. CCE3401 Electric Cooktop Logo
42 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
