Question about Zebra 105SL Thermal Label Printer
105SL PRINTER PAPER OUT PROBLEM
My 105SL Zebra printer has aproblem :
error condition paper out warning light comes on , error light flashing , pause light comes on and cancel green light comes on .
notes:
1-this is the first time I use the printer (its new).
2- I follow up the trouplshooting procedures in the manual.
3-I make adjuste (calibrate) for both media sensores and make manual calibration for media but problem still on.
the lower sensor (source light) the light does not light ! I dont know if it must light or not.
part number of label (strap tie down label) is :CM-SCE-1/4-4H-9
AND i USE Rippon (110.0X 300M Ink coated out black lot:7d62-74
or no. 742412-000 Reorder number 1330-0607-10 )
thanks for your help
Khaled Raja (Jordan Aeronitical Company system)
e mail : khaladraja@yahoo.com
What data you are sending to the printer?Can you post it?
What Mediatype u are using(Thremal Transfre or themal Direct)?
Posted on Jul 10, 2008
We have a Zebra 105SL thermal printer. When I print to it with any application, the error light and paper out comes on.
Sounds like it may need a calibration. Press the calibration button on the front of the machine.
Nov 28, 2013 | Zebra 105SL Thermal Label Printer
I have a Zebra 105 SL, I have the ribbon installed but the printer tells me that the ribbon is out. I've tried changing the ribbon and labels out but as soon as I power it back up and try printing again...
Calibrate the printer from the setup menu.
You'll (1) Load the label backing with the ribbon (2) remove the ribbon - just shove it to the right, out of the way of the ribbon sensor (3) reload the label and ribbon.
The printer will run a number of labels out.
Feb 16, 2011 | Zebra 105SL Thermal Label Printer
Zebra 105sl felt paper error
check if the sensors behind the printhead (small metal open case)is on the same position that the uper sensor(black plastic bit with the screw behind the printhead) Run the sensor profile, check if he check the gap.
run manual calibration from the settings.
worst case senario, Reset the printer to Factory defult (Press PAUSE and CANCEL buttons and tun printer on, then relese the butons after 5 secounds.
Jul 06, 2010 | Zebra 105SL Thermal Label Printer
Out of paper error
You just have to do is jsut adjust the size of the print you are taking. For eg. If you are printing the paper of A4 in a legal size of paper than the above error will be raised. Just adjust A4 to legal(As per the example. You have to choose as per your own need.)
May 27, 2010 | Zebra 105SL Thermal Label Printer
My printer says error condition paper out. But it
try to recalibrate media and sensors, run calibration, and run sensor profile, save, and restar again the printer. check if setings from the driver are correct or they can change the setings from the printer
Apr 28, 2010 | Zebra Printer 140-751-00000
Zebra 105SL thermal Label Printer prints blank with new supplies
Some possible reasons:
1. The darkness is not set high enough for the paper/ribbon combination
2. The ribbon is on backwards. Zebra uses coated-side out ribbons so the ribbon should be coming off the right side of the roll if you're looking at it from the side.
Hope that helps !
Apr 16, 2010 | Zebra 105SL Thermal Label Printer
My Zebra Zm 400 keeps saying Pause Error Condition paper out however it is set to Direct Thermal. How do I get it back to the ready state?
make sure that the maximum lenght for the label is set to something greater than the physical length of the label. I was having this issue with a 4x3 label. As soon as I increased the maximum lenght to 5 inches it worked.
Dec 29, 2009 | Zebra 105SL Thermal Label Printer
Zebra s4m error condtion paper out
Sounds like you will need to perform the calibration procedure.
when you access the menu system go to advanced menu, the password is 9999, use the keys to navigate to manual calibration and follow the instructions. when it states load backing this is refering to backing paper, so remove the labels from the backing and place in label path. hope this helps
Jan 16, 2009 | Zebra 105SL Thermal Label Printer
Paper out light comes on at 105sl printer
Dear team
sorry for lating to response to your question amd thanks very much for your help, the answers for your questions as follows:
the date i sent to printer through PC is anumber example( 2w1x326)
I use Thremal Transfre Mediatype
thanks very much
Jun 19, 2008 | Zebra 105SL Thermal Label Printer
Zebra 105SL Thermal Label Printer Logo
2,442 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
