Question about Philips Magnavox MWR20V6 DVD Recorder/VCR
I got a magnavox dvd recorder and 4 head hi-fi stereo vcr and im having trouble with hooking it up to my cable box how do i record shows on my recorder without switching inputs on my tv because i switch inputs and the recorder comes on but not my cable
  • Philips Master
  • 5,130 Answers
To record from the set-top box, you need to connect the coax out of the box to the coax in on the recorder (daisy-chain). Then connect the coax out of the recorder to the TV. The DVD/VCR channel needs to be set to Channel 3 or 4 depending on the output of the set-top box. (Check the manual for the cable box for this information.) Then press the TV/Video button if you see noise on the TV. Then set the TV to channel 3 or 4. See page 80 of the manual for setting the RF output of the DVD/VCR unit; the TV must be on to set this properly.
Then set the cable box for the channel that you want to record. If you keep the TV on, you will only be able to watch the channel that is recorded. Unless you have a second source going into the TV on another input.
If you have the video cable connected for a better picture from the DVD (composite or component video, for example), this is separate from the rest of the connections you need. (To watch the DVD, you'd change your input source.)
I hope this helps. BTW a copy of the manual is available here: http://tv.manualsonline.com/manuals/mfg/magnavox/mwr20v6_1.html .
Posted on Nov 15, 2010
  • Cindy Wells Nov 15, 2010
    If the cable box doesn't have RF out, you may need a converter. (Composite to RF - they used to be available from most stores. Radio Shack still lists them at their web site.)
    Please note that most TVs do not have video out connections so the daisy chain has to end at the TV.
  • Philips Master
  • 8,457 Answers
Don't hook the DVD/VCR recorder through ur cable box.Hook the DVD/VCR recorder through ur tv only it should work find.This way each units have it own direct functions to the tv.U recording the shows from the tv not the cable box ok.
My VCR unit only plays a tape for a few seconds, it stops,turnsoff entire system and ejects tape. I have tried to clean it. Is there a fix for this problem?
If the take up reel is not properly winding the tape the machine will shut down. U need to address that issue to resolve the problem.
Jul 22, 2015 | Magnavox ZV457MG9 DVD Recorder and 4-Head...
Recording Error-Cannot record on this disk. . New disk
Check on different/various format disks...if it will not write to any may have developed a component fault or the reading lens may simply need cleaning with something like isopropyl alcohol.
Ensure the machine is unplugged if you do the cleaning internally
Jul 07, 2015 | Magnavox ZV457MG9 DVD Recorder and 4-Head...
Hook up of magnavox zv427mg9
I have a magnavox dvd recorder/vcr combo (ZV427MG9A) connected to my Sharp hdtv via hdmi cord, Can anyone tell me simple setup steps to make it record and play on either sides. I have read instruction book over and over and it is still not recording to disc or tapes. I also have Charter Cable connected. Can you tell me what do i need to do to make it work. H-E-L-P!!!!
Nov 17, 2009 | Philips Magnavox DVD+R/+RW Recorder/VCR
I have a Magnavox ZV427MG9 A VHS & DVD Recorder
U must make sure ur tv channels must work throught ur DVD and VCR unit.Then u can record it out the tv show programs.U must connect the tv air signal or cable to the DVD VCR unit in the antena port.Use another cable connect out on the DVD &VCR unit and in the tv signal input in ur tv antena input.Make sure u in the channel 3 or 4 switch desire back of the DVD&VCR of the back,and the tv correct to ur desire channel switch to 3 or 4 .U
can record tv shows now.
Aug 18, 2009 | Philips Magnavox DVD+R/+RW Recorder/VCR
Would like to record from my tv to my magnavox dvd/vcr combo box
If I understand your request right, You do not have cable or satellite box.
You can not record from your TV. You use the TV as a monitor from the dvd/vcr combo box. What the box receives is what shows on the TV. So you will have to have a digital convertor hooked to the (antenna in) dvd/vcr combo box, (antenna out to the tv antenna in) Depending on the antenna you are using that is on the other end of your cable-in coax connection this will hook to your antenna in on the digital convertor box. If your cable is hooked up and operating correctly and directly to the tv that is digital ready you probabbly have a good picture. When the vhf/uhf signal was transmitted you could go from the dvd/vcr to the tv with no problem. But now that the signal is digital and the tv is set for digital the dvd/vcr will not pass a digital signal to the tv. Best suggestion, you have to get a digital dvd/vcr receiver. If you have more question please contact me.
Mike
Jul 25, 2009 | Philips Magnavox DVD/VCR Dual Player
DV220MW9 DVD/VCR: won't record video on VHS
your cable tv connect into dvd/vcr,video/audio out connect to av in your tv,solved
Jul 06, 2009 | Philips Magnavox DVD/VCR Dual Player
Vcr hooked to tv and converter box. Will not record digital chann
The vcr has to be set to channel 3 or 4. The converter box has to set to the channel you want to record the show from and left on during the time that the vcr is recording or you will get no recordings.
Apr 19, 2009 | Philips Magnavox DVD/VCR Dual Player
How to connect my dvd & vcr with the converter box
Here is my setup.
1) Separate DVD player 2) Separate VCR 3) Digital to Analog Converter box 4) Analog TV 5) Rabbit ears (UHF/VHF) antenna
The antenna goes into the converter box.   The RF-output of the converter goes into the RF-Input of the VCR The DVD output goes into the front input jacks of the VCR The VCR RF-output goes into the TV RF-Input The VCR Line output goes into the front of the TV
To watch DVDs, we turn on the DVD player, turn on the VCR, and set the VCR channel to L2, and tune the TV to channel 3.  The converter is off.
To auto record on the VCR, the converter must be tuned to the station being recorded.  The converted must be turned on, the TV can be off.
To watch VCR tapes, turn the TV and VCR on.  The TV is set to channel 3.  Just press play on the VCR.
To Watch TV.   Turn the TV and converter on.  The TV is set to channel 3.   Change the stations using the converter.
May 06, 2008 | Insignia Digital-to-Analog Converter for...
Dvd/vcr with ** hookup for cable tv
Just hook your antenna or whatever wire you have currently connected to the TV to the input on the new recorder, and you'll be to record anything you can watch now.
Mar 10, 2008 | Memorex MVD4540 DVD Player/VCR
Philips Magnavox MWR20V6 DVD Recorder/VCR Logo
206 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
