Question about Refrigerators
GE Arctica - Running Constantly
I just fixed a broken damper door that appears to share cooling from the freezer to fridge. Ever since this "fix" the fridge fan behind the damper appears to run non-stop and keep temperature unevenly.
Questions:
1. I don't remember if the fridge fan ran all the time before my "fix". It seems like it did not. Does the fan run all the time? (It does stop when I open the door)
2. Could something else (motherboard etc.) have been tweaked during the 4 or 5 days that the damper door was broken?
Appreciate any help!
Brad
  • 2920 Answers
SOURCE: fridge left open all night and wont cool but the freezer still works.
time for a new fridge
Posted on Aug 27, 2008
SOURCE: GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Thanks
Carol
Posted on Sep 21, 2008
  • 159 Answers
SOURCE: Fridge side of American Fridge/ freezer not cooling down.
does the fridge have 2 motors or 1 if it have only 1 motor the gas level in the system are low. if it have 2 motors check if the fridge side motor runs
Posted on May 22, 2009
SOURCE: GE side by side refrigerator. Fridge side not cooling - help!
Hi, they have changed lots of parts, were they defected, did they tested parts for faults or they just change parts, because it's available, there's always a reason why a certain part, go bad. so far you change most of parts in ref. check refrigerant (gas, freon) pressure, check compressor, for faulty suction and high side valve, it's possible your compressor loosing efficiency. or say if compressor normally pump 50 psi. now it's pumping 40 psi. is the refrigeration cycle balance ? is there restriction in your ref. system? is compressor running long enough? plug on ref. let it run for 1hr, listen to compressor for any clicking sound, fans and everything else could be working, be compressor not, compressor could be short cycling (not working long enough) also check voltage in receptacle(outlet) with digital multi-tester, get accurate voltage reading, let me know, could also be a faulty circuit breaker in house (building) not your ref. let me know, system could have very slow refrigerant leak, you could have a very small (slow) gas leak, that's why your refrigerator get hot first, then your freezer, there's a condensate line (loop) that passes through, ref body, close to doors to prevent door gasket from freezing, after few years sometimes develope leaks, cause by rusting. it's very possible there could be small leak in your system. let me know what happened.good luck.
Posted on Aug 14, 2009
  • 6 Answers
SOURCE: Sharp SJ-42-WH self-defrosting fridge. Freezer
I recently had exactly the same problme with this model refrigerator. I found the problem to be the defrost timer. It is located behind the panel on the back of the refrigerator where the mains cord is located, you will need to replace it with the exact same model. I am in Australia and managed to find the exact part on ebay cheaply from a local appliance parts supplier, any appliance parts supplier that deals in Sharp refrigerators should be able to help you.
You will have to defrost the refrigerator overnight again before doing this repair.
Of course there are a couple of other components that could cause this problem, you can acutally check to see if the defrost time is moving by taking note of it's current position and then checking it every thirty minutes or so. If it does not move then it could be faulty, make sure also that power is getting to the timer as well.
Posted on Oct 27, 2009
Veg and fruits freeze up.. Why? and what should temps be for frig and freezer?
We had this problem almost 4 yrs ago. It was the damper assembly which is a common problem w/ GEs. A damper is a door flap that opens and closes between the fridge and freezer that allows cold air into the fridge to regulate the temperature. Eventually, it breaks, allowing in too much cold air into the fridge, thus making both sides a freezer! Fixya's link that helped me is this one, which is very helpful: http://fixitnow.com/wp/2007/12/06/ge-side-by-side-refrigerator-freezing-the-beer/. You also might need to enter a diagnostic code when you replace it. Check this out also:
http://fixitnow.com/wp/2009/10/02/activating-self-diagnostic-mode-in-a-ge-arctica-refrigerator/. Don't let the description of the fridge as a GE Arctica mislead you. These are different models, but internally are the same components.
Jun 14, 2014 | GE Adora DSS25KSTSS Stainless Steel Side...
GE Profile Arctica fridge running too cold
You may want to check your damper assembly to see if the door is broken. If the door is broken it will air to migrate to the refrigerator compartment causing freezing issues. Also check to make sure that the damper door is not staying open. When you take the cover off with the door open the damper should close. If the damper is open then you need to replace the damper. Here is the damper to order.
Dec 05, 2012 | GE Refrigerators
Side by side GE turbo-cool Gss25XSRBSS, the freezer seems to be fine, the fridge is not cooling. Fans seem to be running smoothly, no weird noises. Turbo cool turns on. It hasn't been running for
if you go here you can see the damper,fan assy. that's in the top of your machine in the fresh food side
http://www.repairclinic.com/PartDetail/Damper/WR49X10091/1055112
this is a damper with another fan in it,when the t-stat calls for cold air the damper door opens to let the cold air in from the freezer and the fan in it blows the cold air around inside the fridge,if the freezer is fine and the fridge side is warm most likely this is your problem,part number WR49X10091 and it's around 130 dollars.unplug the machine,remove the light cover on the ceiling,remove the 1/4 inch screws and drop the light assy.remove thhe filter cover on the right side so you can remove the damper assy.pop off the cover on the piece that runs up the back center,remove the screws to the damper,read the instructions and put it back together again.should take you around 45 to 60 minutes.hope this helps and good luck.
Sep 27, 2012 | GE Refrigerators
I have a GE Profile Arctica Fridge. The temperature in the Freezer has dropped to 34 degrees and the Fridge has dropped to 40. The fridge is running and is blowing air in the freezer, but not really...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 11, 2010 | GE Profile Arctica Stainless Steel Top...
Refrigerator temperature is 30. We cannot set it
check the fan that runs between the freezer and fridge in the fan housing is a damper that opens and closes if ice or debris is blocking or in way clear so damper can open and close the fridge is cooled by the freezer
Jul 20, 2010 | GE Profile Arctica 25.4 Cubic Feet...
Freezer n refrigerator is warm at 78 degrees
If the compressor is running it either has broken valves or the refrigerant has leaked out. Without knowing more than the information you've provided I would start with the basics. Does the fridge have power? Can you hear both the condenser and evaporator fans running? Have you checked the coils under the fridge to see if they are clean?
Jun 21, 2010 | GE Profile Arctica Stainless Steel Top...
My 9 yr old Kenmore Elite fridge is warming up!! The freezer is fine!!!! Model 3 106*74902401 Seriel # ES423704 Manufacture date is 10/2005, I purchased it in Dec of '05 and it's been WONDERFUL!!
This problem sounds like a damper control broken or frozen.
Lowering the freezer temperature may help to fix the problem as the damper sometimes freezes and not able to open to cool down the fridge side.
If lowering the freezer temperature doesn't help, you may need to call for a technician to fix or replace the damper control.
Also, be sure the door closes properly and no air comes in or out from the fridge.
Dec 18, 2009 | Computers & Internet
Food in the freezer on my side-by-side GE Profile Arctica (PSH25MSSA SV) is thawing. Temperature is higher than normal (melted ice cream, etc.) but returns to frozen after awhile. Has happened many times...
It's hard to understand how the refrigerator compartment would be okay, but the freezer is not. The evaporator coils are normally behind the freezer. The cooled air is moved from here to the freezer and refrigerator by the evaporator fan. Is this the fan you are saying is going on and off? Or the compressor fan underneath the refrigerator.
The necessary conditions for proper cooling are:
1. Compressor is running; 2. Compressor fan is running; and 3. Evaporator fan is running.
Oct 18, 2009 | GE Profile Arctica Stainless Steel Top...
GE Profile PSC23MGNA too cold on frig side & icing up on freezer side
Check your thermostat if it is still functioning well.
May 02, 2017 | Refrigerators
Refrigerators Logo
117 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
