Question about Microwave Ovens
Panasonic microwave inverter 900 nn-gt576sbpq
MicrowaveSvc
  • 9098 Answers
SOURCE: PANASONIC INVERTER MODEL NN-S76OWF
While your exact model in not available for download, you should be able to find one close enough to work here:
http://panasonic.com.au/support/downloads/file_type_results.cfm?fileTypeID=2&productCategoryID=87
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Dec 07, 2007
ukvacfan
  • 328 Answers
SOURCE: Panasonic Inverter NN-V673S microwave- shuts off after 2-30 secs
If the screen is showing a fault number or a number you havent seen before then its probably a program fault which can't be fixed. Check that the vent holes on the back of the oven aren't dirty and ensure that the whole oven is clean inside. Sadly it sounds like a program fault which cant usually be fixed by the owner though.
Finding a Panasonic oven repairer in the UK shouldnt be a problem though. My parents had a simlar problem wth their Panasonic Inverter oven, called the UK customer services and Panasonic contacted an authorised repairer in Scotland to visit them. Call customer services on 0844 844 3868.
If the call out charge exceeds £80 then you're probably better off buying a new oven.
Posted on Apr 19, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Hi, I have a NN-C784MF
Chances are there are other bad parts blowing the diodes, most likely a MOSFET.
Also, the ESR of the electrolytic capacitors should be checked and all board connections must be checked and resoldered if suspect.
If you're not experienced in troubleshooting switched-mode power supplies (inverters) then you can probably save a lot of timer and money by replacing the whole inverter.
You can find the nearest spare parts supplier by selecting your country then the support links at Panasonic.net.
Posted on Jan 02, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: PANASONIC NN-SN789S MICROWAVE INVERTER. IN LOCKED
The owner's manual cover should cover this. if for some reason you don;t have yours, you should be able to download it here.
If you're outside the US, see Panasonic.net.
Posted on Jan 17, 2010
  • 30 Answers
SOURCE: just had a panasonic inverter nn-cf778s delivered
No it definitely isn't. Sounds as though they got the interlocks connected incorrectly, or the control panel is defective.
Either way, you definitely need to send it back to where you bought it.
Posted on Oct 22, 2010
Panasonic inverter microwave nn-sd688s, stops and resets but then will work again after, seems to do this just by opening and closing door. What could be the problem?
I'd check the door switches to make sure they are being reliably activated when the door is closed.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Apr 08, 2016 | Panasonic NN-SD688 Microwave Oven...
Panisonic inverter microwave lights up but doesn't fully come on
How to fix microwave that counts down but does not heat or ...
? 4:51
https://www.youtube.com/watch?v=PIU1NRpeA_8
Oct 2, 2012 - Uploaded by G-Unit_YouTuber
How to fix frigidaire microwave door sensor relay switch. ... with a different part number (D3V-16G-2C25) but it doesn't look like it's stocked. ... Problem now is that when we open the door, themicrowave comes on by itself! ... I am not sure, when you hooked up the volt meter, did the lights turn on and off ...
All comments on Fixing Panasonic inverter microwaves ...
https://www.youtube.com/all_comments?v=hBJJU4ZRh7U
i have a nn-h965wfx the light comes on the countdown initiates but nothing comes .....I have a similar full size panasonic inverter microwave NN-L931BF built in ..... After putting it all back together the thing doesn't even power up the display.
Panasonic 1200W 1.2 Cu. Ft. Countertop Microwave Oven ...
www.amazon.com/Panasonic...Microwave.../B005BFZ...
Amazon.com, Inc.Ft. Countertop Microwave Oven with Inverter Technology NN-SN661S Stainless at Amazon.com. ... The microwave panini meals even end up with toasted crisp bread. ...But, right now, I find the interior light functionality just fine. .... (1) In this Panasonic, the light doesn't come on when the door is open; it only comes on when ...
Jan 05, 2016 | Microwave Ovens
Panasonic NN-C980B stopped working. Blown fuse.
Sometimes when the mag shorts it takes out the inverter. I would measure the mag leads to ground and they should be open or 20M or so. If you have both a mag and inverter bad it's probably time for a new oven.
Apr 19, 2010 | Panasonic NN-C980 Convection/Microwave...
Panasonic NN-T994SF Microwave Oven quits after 15 seconds
my microwave shuts off after a few seconds. is there a fuse that needs replacing?
Feb 01, 2010 | Panasonic NN-T994SF Microwave Oven
Microwave cut off
the main control board is "seeingf" a high amprage draw from the inverter board . you have a problem with the inverter or the magntron . parts are more than a new unit . try to stay away from the inverter type , there just not ready for prime time . google "panasonic inverter reviews " and you will see just common your problem is good luck
Jan 16, 2009 | Panasonic NN-S753 Microwave Oven
Stopped heating, shuts off before time expires
My panasonic microwave model # NN-S540BFW stops after 4 seconds after you hit the start button and cuts off on its own. What is wrong with my microwave?
Jan 12, 2009 | Panasonic NN-S763BF Microwave Oven
NN-GT576SBPQ door falls off
I would think your door hinge has come loose, or the door may be cracked.
This should be repaired before the microwave is used to prevent the possibility of burns due to microwave leakage.
You can locate an authorized servicer or contact Panasonic support here.
Sep 24, 2008 | Microwave Ovens
Microwave Ovens Logo
101 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
