Question about NetGear ProSafe FVX538 Firewall
Locked/Dead Lan Ports on FVX-538 V2
I have a strange problem that started earlier tonight.I noticed that my net connection was down both WAN and LAN.So I decided to power down the router waited 60 seconds then powered it back up.Everything was working fine for about 5 minutes then the connection died again.When It dies I can not even access the router config page at 192.168.1.1.I also noticed that the LAN ports were no longer blinking.I removed the cables and the port lights stayed lit.
I decided to try and reload the firmware.I had updated to version 3.0.3.13 a couple months ago, but had no problems until tonight.After reloading the firmware,rebooting the router, and re-entering all my settings.It again worked for about 5 minutes until the LAN ports locked up again.
Next I tried doing a hard reset using the built in reset button.I booted the router back up re-entered all my settings.Guess what, things were fine for about 5 minutes until the LAN ports did their locking up trick again.
One last thing I tried was checking Netgear's support site to see if their were any firmware updates.There was one dated 5/31/08, version 3.0.3.13.18.I tried updating to this firmware, but with the same results.
I'm thinking that my router may be beyond repair,I could try going back to an earlier firmware, but I really don't think that will help.
I've had this router for about 4 years now,and it's been pretty solid.I really hope that I can salvage it.Has anyone else experienced anything similar to what I'm going through with the FVX-538 V2?
  • 2 more comments
  • joenhre Jun 19, 2008
    No your spam is not going to solve any of my problems.I can tell yu what you can do with it, but that would be inappropriate here.
  • ben5476 Aug 28, 2008
    Have got exactly the same problem with a v2fvx538.
    happpened about two weeks ago tryed new firmware but no joy.
  • Anonymous Sep 21, 2008
    HAVE EXACTLY THE SAME PROBLEM STAYS IN TEST MODE SOMETIMES THE LIGHTS COME ON AND OFF SEEMS TO BE FRIED
    ONLY ABOUT 2-3 YEARS OLD?
  • javaidi Jan 05, 2009
    I have similar problem. FVX538 . It blocks LAN port. When I switch it off and on . It stays in test mode. Test Light stays on and firewall nevers boots up.
  • 102 Answers
Router boots up but locked ports are most likely a bad capacitor
You can tell the bad one is raised on top not flat.
You may find a matching cap on a motherboard or other junk hardware you have around. Remove the bad one and solder the new one in place.
Posted on Aug 29, 2011
2 Suggested Answers
SOURCE: CONFIGURE CONTENT FILTER IN NETGEAR FVX 538 PRO VPN FIREWALL
For blocking IM service, you need to configure the IPS (Intrusion Prevention Service)
Posted on Jul 24, 2009
Witch del port does router feed to belkin model F5D 5131-5v
You can connect the F5D5131 switch into any of the ports on your router except the WAN port. The WAN port is often a different color, and labeled "WAN" or "Internet" or "DSL"; the rest of the ports (LAN ports) are often just labeled 1-5.
Feb 10, 2015 | Belkin Computers & Internet
I need to access CCTV over internet.I am using Zyxel router (model P600R T1 v2) which having a static WAN IP provided by ISP.Can please guide me on the steps.Thanks.
first you need to forward TCP ports in your router pls write down which TCP ports used for video , audio and control in your DVR and configure to forward this tcp ports in your router
it can be do one step using disable the DMZ and it will make less sequrity in your internal network
Apr 11, 2013 | Zyxel Prestige 660HW Wireless Router...
How do i connect a wifi router to the dsl of my pc?
Your internet provider should have provided you with a modem (dsl modem) that will have a ethernet port which can be connected to a computer directly or a router to make internet available to multiple computers. Router usually comes with five ports one of them is WAN port (Wide Area Network) and other four are LAN ports (Local Area Network) The dsl modem should be connected to WAN port of your router and the LAN ports are use to connect to any computer with an ethernet cable. If the router has wireless capability you can use your laptop or smartphone to access internet wirelessly!
Sep 23, 2011 | Computers & Internet
No LAN output from router
This router has 4 LAN ports and 1 WAN port. If you mean to say like if you are running out of LAN ports or if you require more LAN ports to connect more number of computers. Then you can buy a network switch which will help you connect more computers. All you have to do is run a ethernet cable from router's LAN to switch LAN
Aug 09, 2010 | NetGear RangeMax WPN824 Router
Router page not available offline
You don't connect to WAN port, you need to connect it to one of the switch ports. The wan is strictly for modem configuration
Dec 17, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Trying to hook up router. What is the wan for and the 4 inputs
The WAN port is the physical interface that provides input and output to and from the device that provides Wide Area Networking capability .. i.e. the modem that connects to your Internet Service Provider. The usual choices are a DSL modem, a cable modem or a Wired router or a wired switch.
The 4 other inputs are wired inputs and outputs for wired Local Area Network connections.
The WAN port normally connects to the Internet. It is not necessary to connect anything to the WAN port to have a network. But without one of the usual devices, you will not have access to the Internet.
The LAN ports connect to the network interface port on the individual computers that are part of the local network. One port connects to one computer.
A large system will have routers connected through the LAN ports to the WAN ports on sub routers and so forth.
Nov 25, 2009 | Dynex DX-E402 Router
How to connect 2 PC's on a single ADSL2+ connection so that both can connect to net simultaneously
Use a router for that. Connect your DSL modem to the router's WAN port, then connect your computers to the router's LAN ports.
Apr 13, 2009 | Intel D945GCL Motherboard
Mar 26, 2009 | NetGear PROSAFE 200 FVX538 (FVX538NA)...
Can I use 2WIRE 2701HG-B router in COX internet connection
No. A router has 2 main interface types WAN (for the internet connection side, and LAN (for the home network side) the 'LAN' side often has up to 4 ports and wireless connectivity for the home network.
The most common routers available at electronics retail use a CAT-5 connection for the WAN ports and the LAN ports. Your DSL modem/router uses a phone line input for it's WAN port, which uses a signal type that is incompatible with the cable modem output.
If COX doesn't offer a router with the cable modem package, you can go and purchase and common brand of home networking router, and attach it to the output of the cable modem.
Feb 28, 2009 | 2wire 2700HG-B Router (2700HGB)
Dax router
The 2 wire Home Portal 100w is a Modem/Router combination with wireless. But it has only one LAN port. So I understand that you are trying to use a DAX router for extending the number or ports. The reason they may not communicate if 2wire LAN is connected to DAX WAN is both may have same IP address. If the router has similar IP on WAN and LAN, it will not communicate. For that changing DAX router's LAN IP will be a solution or you can do LAN to LAN cascading. Connect 2Wire LAN to DAX LAN and dont use the WAN port. This way you dont have to change anything in the configuration
Dec 04, 2008 | 2wire HomePortal 100W (1000-400026-000)...
NetGear ProSafe FVX538 Firewall Logo
960 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
