Question about Canon PowerShot SD750 / IXUS 75 Digital Camera
"CARD LOCKED"-just downloaded pictures from memory
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
It's easy enough for the switch to get moved accidentally, especially when inserting it into a card reader or a camera.
Posted on Nov 15, 2010
Testimonial: "That was exactly what the problem was...Someone that I know had already given me that answer and my card is now unlocked and ready to go!! "
SOURCE: Memory card locked
I just got done fumbling around with the same problem. All you need to do is take the card itself out of camera and there's a mini switch on the side of the card that slides up and down for lock and unlock.
Posted on Oct 04, 2007
abcisme
you have to put a bit of tape around the bit were the little tab use to be.. This works epically if you have lost the tab from the card.
p.s. i did this with an SD card an it worked i don't know if it will work with any other types of card. good luck anywhos, try yahoo answers they seem to have alot of info too. (Y)
Posted on Dec 05, 2007
Bubbabear64
  • 2794 Answers
Take the card out. On the left side of the card is a tiny white switch. Reverse the position.
Posted on Jul 04, 2008
jrcolbert
  • 73 Answers
SOURCE: CARD LOCKED
There should be a small toggle along the end side (it is tiny and easily missed, but it is there, I just checked my memory card / mine is 4GB SD card from Sony) that you can swtich to unlock and your images may come back that way.
Look for it this way, hold the card face down it should be on the back edge where you use your thumb or finger to push it into the slot on your camera.
Posted on Mar 03, 2009
There is a tiny button on the side of the card - so small you can hardly see it. Just slide it up and voila All is solved.
It is frustrating as there is nothing in the manual bout this and the onl line assistance wants to charge for 20 seconds advice Mine is free dorothy
Posted on Jun 18, 2009
Memory Stick Duo 512MB. Where are no pictures on the card, but it says that "were is no space" when I put it in the camera. What should I do?
First make sure the card is not locked. Do this by checking on the side of the card that the lock notch is not in the locked position. If it is not locked then you should put the card in your computer and reformat it. If this isn't successful then its time to go get a new card. You can get a new one for under $20.
Aug 26, 2011 | Sony 2GB Memory Stick PRO Duo Memory Card
Can I download pictures from internal memory directly to my computer for a NIkon coolpix S570 camera? The memory card I was using went bad and the camera displays "This card cannot be used"
You can connect the camera to the computer with the USB port. If there's no memory card in the camera, the computer should see the pictures in the internal memory.
Alternatively, you can get a new memory card (you're going to need one, right?) and copy the pictures from the internal memory to the card, then put the card into a card reader and transfer the pictures taht way.
Aug 15, 2011 | Nikon COOLPIX S570 Digital Camera
I viewed pictures on my computer and didn't upload them. When I placed my sdhc card back in my camera it gave me the error message "memory card error" and "card locked", however the...
Don't be panic. you can try some data recovery software. You can see
http://download.cnet.com/Asoftech-Data-Recovery/3000-2248_4-75328850.html?part=dl-75328850&subj=dl&tag=button
It tells the steps how to perform data recovery.
If above does not work, you may have to format the memory card (use quick format), and then use above mentioned software to scan again the memory card and recover your files.
Jul 15, 2011 | Cameras
I took my memory card andput it in the laptop, then it said "import pictures" i clicked yes...then my friend said "wait no!" no i exited the little import box. now when ever i put the...
They're still there, except the card has become corrupted, and is not readable by your camera. See if you can insert the card back in your laptop and save the pictures onto your computer. If your laptop doesn't recognize the card either, then you may need to use recovery software. In that case, see the corrupted card procedures in this link. Once you successfully recover your photos onto your computer, you'll need to format your card IN YOUR CAMERA to make it usable again. Finally, sorry but if you were intending to use the card to long term store your photos and display them using your camera, you will no longer be able to do that with the previously taken photos.
Jul 11, 2011 | Cameras
The camera display reads "card
Here is a tip that I wrote about SDCards and how to unlock and lock SDCards. If youare getting a memory card locked message then check this out.
How to UnlockSD Card heatman101
Jun 14, 2011 | Samsung S860 Digital Camera
Well my camera is a Casio Exilim Anti-shake DSP. When i put all my photos onto my laptop i tried to put them back on the card. But after i tried i turned on the camera and it says "MEMORY FULL"...
Okay, you put your pictures on the computer hard drive but, the pictures will still be on the card until you format the memory card in the camera. So then you loaded the pictures back on the card so in fact you have two sets of the same pictures on the memory card maxing out the cared capacity. I doubt they will show on the camera because there will be different file formats one from the camera and another from the computer. So to clean things up first make sure you have your pictures on the computer hard drive then safely remove hardware or eject the camera memory card and unplug the cable. then go into your camera settings looking for "Format" might also say initialize but format is pretty well universal anyway find format and follow the screen. Formatting cleans off the memory card and reformat the card back to new to receive more pictures.
Jan 04, 2011 | Cameras
I have bought the philips 10.4 inch digital photo frame and im trying to put pictures on it and store them in the internal memory. When i put my card in it starts to install them but then says not enough...
Tough the picture frame states 1000 photos, it really depends on the size of the picture. To resolve this purchase a 2 or 4 gb memory card and download your pictures onto the card. You can insert the card in the slot of the picture frame and then connect to your computer and download your pics from your computer directly onto the memory card.
Dec 14, 2009 | Philips PhotoFrame -10 Digital Picture...
How do I transfer pictures onto the memory card?
You should be able to transfer the pictures if it has built in memory. then transfer it to memory card the same way you'd take them off
Oct 05, 2008 | Nikon Coolpix 2000 Digital Camera
Go to the camera's "setup menu" and scroll down to the last option, "move images to card" That should put the images onto the memory card.
Apr 06, 2008 | HP Photosmart M415 Digital Camera
Ativa memory card
The card is probably formatted with a FAT16 filesystem. Try reformatting the card with a FAT32 filesystem.
Jan 17, 2008 | Electronics - Others
Canon PowerShot SD750 / IXUS 75 Digital Camera Logo
162 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
