My monitor keep on go to sleep mode while the computer is on and running. can you advise any solutions please?
  • jeffinjose20 Nov 15, 2010
    what if i linked my desktop monitor to my laptop, how i can access the power setting of desktop monitor?
I have a LG 700E and after switching on the monitor's power LED blinking continueously and there is no display and no relay sound at startup, Another monitor if attached to the same system is working...
Hi, I believe that the monitor has gone to sleep mode (hybernate mode). Please check and confirm that it is not running in this mode.(System properties) or display modes. Good luck.
Jun 13, 2011 | LG Computers & Internet
My Hp A6252D monitor keep turning to sleep by showing the message ' monitor is going to sleep' before it was turned off, but processor was still running. Sometimes, it hang and i hear noise from CPU. May i...
in power set up in control panel,there are setting for the computer and monitor,the setting is { shut down after 5mins,10 mins or never click never.and it should stay on
Jul 07, 2010 | HP W19b LCD Monitor
Hello
I FIX LOTS OF COMPUTER, AND MY ADVISE IS. IT MIGHT BE YOUR COMPUTERS VIDEO CARD CAUSING THAT PROBLEM . ALSO CHECK FOR VIRUSES THEY CAN DO STRANGE THINGS.
Mar 17, 2010 | Computers & Internet
Monitor works fine until the sleep mode and then it goes blank. I have to unplug the power button and it does work again
It seems it is a motherboard battery problem. It most likely is not the monitor which is in "sleep mode", it is the computer itself.
When you cannot get a computer out of "sleep mode" by any other means, typically the cause is that the button-cell-type battery of your computer, which is located on the motherboard, is empty. When your computer detects this battery is empty, it goes into a low-power mode. The solution is to replace the button-cell battery on the motherboard of your computer
If this solution works fine for you please rate this
Feb 24, 2010 | Dell E196FP 19" LCD Monitor
My monitor keeps saying monitor going to sleep waht do u o
It shows that the monitor is going to the power saver mode.It is not a problem of the monitor.This happens when there are no signals received on the monitor.It turns back to the normal mode when a signal is received on it.
Dec 21, 2009 | HP w1907 LCD Monitor
Monitor keep going into "sleep" mode
Check the power setting in control panel of windows. If you have a monitor from another computer swap them and see if the problem stays with the computer or monitor.
May 12, 2009 | Dell Dimension 3100 PC Desktop
Hp L1706 Monitor Keeps Going Into Sleep Mode
I have an hp media center that runs windows xp with service pack 3 and my monitor is an hpL1706 monitor and was running fine now it says no input and goes into sleep mode how do I fix it?
Apr 10, 2009 | HP Pavilion F1523 15" LCD Monitor
Computer asleep
I have to keep my pc in safemode now as mine is also in constant sleep mode and I can not get it out, It is the only way it will load up! :-(
Apr 09, 2009 | HP vs15 15"LCD Flat Panel Monitor
My HP FL523H monitor is locked in the sleep mode
Hi...there,
Could it be your backlight inverter it burnt out... cuz there no sleep mode in the LCD monitor.
Nov 12, 2008 | HP Vs17 17" LCD Flat Panel Monitor
When I select sleep or hibernate mode - the monitor stays black...
Hit the keyboard keys. It is better to just turn sleep and hibernate off and just use a screen saver or tun it off.
Aug 24, 2007 | ViewSonic VX910 19" LCD Monitor
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
