Question about Bose Wave Music System CD Shelf System
Cannot retrive CD , makes a noise and will not release
Not a solution, just confirmation that my system problem sounds like yours. Hit eject and it makes noises but will not open to release the CD.
Hope someone finds an answer.
Posted on Nov 15, 2010
Need to reset radio code after battery died
go to radio-code.com once there click on retrive code find your car make and modle you will be prompted to a steo by step to find the radios serial number then you pay you will get the code by emale
Dec 05, 2012 | Car Audio & Video
Sony xplode radio got wet. Making noise as if trying eject cd. no lights r power up. Reset button stops noise but when release noise continues,
You probably have some corrosion in the deck, more than likely on the leads of the output ic. If you are lucky, you may be able to get away with just cleaning the corrosion from the board. This can best be done with isopropyl alcohol and a stiff brush.
Aug 15, 2011 | Sony Car Audio & Video
I changed my clutch and releasing bearing but the noise is still there. When ever i release the clutch the noise starts like the release bearing problem and when i take off in first and second gear there...
a release bearing will make noise when you push on the clutch, the input shaft bearing will make noise when you release the clutch, the transmission will have to be removed and torn down to replace the bearing.
Apr 15, 2011 | 2004 Honda Civic
Today, my washing machine started making a loud clicking noise during the spin cycle, or just as the spin cycle is starting up. The machine spins. It is not off balance. It is not the timer - we've had...
if the noise is in the drum the usual culprit is a rogue Bra underwire. look for it poking through any of the holes in the drum and pull it back if you can, otherwise it can be retrived through the heater location (requires some emgineering skill to remove and replace heater). if the noise is from the motor it will be a segment broken away from the armature . this requires a new motor.
Nov 20, 2010 | Washing Machines
Althought my Vtech phone is quite old I am trying access messages
4 retriving messages goto the recycle bin and retriv ur info,4 the call awaiting when making call go to option select hold
Apr 07, 2010 | Lands Phones
Cd player in 2003 Jeep Liberty will not play or eject cds. This is factory radio with 6 cd changer.Radio works. Cd players makes clicking noise but does not play or release cds.
you might want to just take the factory cd player out and put a after market one in cause thats what i had to do on mine casue it costs way to much to get the original one replaced
Jul 31, 2009 | Car Audio & Video
Hi i have a wurlitzer 3100 when making selection from the button bank the buttons hold down until you manualy release them in this time the machine makes a buzzing sound and when you release the buttons...
Look in the bottom of the mechanism in the back. The huge circular ring with all the springs on it is the selection mechanism. There is a rotating disc with teeth along the edge, powered by a motor, which rotates to the correct position before a solenoid is fired to 'pop' a pin. You should be able to rotate that by hand. It is probably stuck solid due to a solenoid firing and jamming between the hammers. Therefore it won't select and makes that buzzing noise.
You need an engineer.
Jul 09, 2009 | Wurlitzer Jukebox 1015 One More Time...
Wont eject cd
there is a safety release in all disk drives take a paperclip and push it into the small hole on the face of the drive and the drive should pop open
May 12, 2009 | Toshiba (PA3352U2CD2) CD-RW/DVD-ROM...
I have an older tv remote that requres a 3 didgit code the tv is a zenith and so is the remote
here is how you retrive the code...make sure tv is on
Step1..press and hold code search button till light comes on then release
Step2..press the TV button once
Step 3.point the remote at TV and press and release the power button while pointing at TV((you may have to keep pressing the power button several times)) once Tv shuts off hit ENTER
Step4..Press TV button on remote and there you go!!
GOOD LUCK!!!
May 09, 2009 | Zenith DBZN-311 Remote Control
I'd like to know how to retrive the trailers that i've downloaded
Depending on what files you want to burn to CD. If it is just Data then insert a blank CD and open with nero, choose burn data cd. In the window that comes up next browse your computer for the files that you want to burn, then click on add, once you have added all of the files that you want to burn click finished. Another window will come up with the option to name the cd and for you to decide on whether this cd will be for use with your computer only or with all/most cd players you should also be given the choice as to whether or not you want to make the cd a multi session cd (meaning that you can add more data to it at a later time, please note though that if you do add more data to the cd at a later date do not rename the cd otherwise it will not work.) Once you have chosen your desired options then click on burn to burn the cd.
If you are not sure where your downloaded files have been saved then run a search in windows for the files and make a note of where they are.
I hope this helps
Dec 15, 2008 | Ahead Software Nero 6.0 (60045) for PC
Bose Wave Music System CD Shelf System Logo
44 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
