Question about Singer Featherweight II 117
Singer Simple `when not threaded runs forward and backwards,,,, `when threaded,,,,moves forward for an inch,,,and then looping clogs the bobbin area,,,it appears as one inch loops under fabric,,,have cleaned, oiled, tentions are in mid position, have changed needles,bobbins and threading is correct~ please and thank you,,,,help~
    Genius:
  • 1,788 Answers
Try this test, with the presser foot down, pull on the top thread, it should feed smoothly, now lower the presser foot, the thread should barely move, when pulled. This sometimes seats the thread in the tension discs. Hope it helps you.
Posted on Nov 18, 2010
Singer 3232 machine was sewing fine now motor runs but needle does not move up and down
Check if the machine is in the bobbin winding mode. To wind the bobbin, the bobbin spindle has to be moved to the right. (The hand wheel will not turn if the bobbin spindle is in this position.) If it is, move the spindle to the left.
If the hand wheel turns, then check for a thread jam. Remove the top thread and take out the bobbin case. Gently turn the hand wheel forward and backwards until the thread comes free of the hook in the bobbin race. Follow this by cleaning any lint from the bobbin race of the sewing machine.
The last possibility is that the belt has failed. This belt transfers the energy from the motor to the needle bar. One source of the belt is http://www.sewingpartsonline.com/motor-belt-singer-007158xxl5.aspx . You can find YouTube videos on changing the belt. There are other parts that transfer the forces form the belt to the needle bar. However, I suggest you find a good sewing machine mechanic if any of these parts fail.
The manual has good pictures of the bobbin spindle on page 11 (page 18 of the PDF). Singer has the manual on their support page: http://www.singerco.com/support/instruction-manuals . The direct link to the manual is http://www.singerco.com/uploads/download/e06cb85928ace9753f1a7124f4a2df6168ffecf0.pdf .
I hope this helps.
Jul 28, 2017 | Singer Sewing Machines
My Simple Singer sewing machine will not thread the bobbin thread. For some reason it will not pick up the bobbin thread from the bottom of the machine, does anyone know how to fix this problem?
Your needle may be in backwards, flat side should face rear of the machine or you bobbin is unwinding in the wrong direction, refer to your manual and dvd. Call Singer at 1-800-4singer if problem persists. Good luck
May 30, 2010 | Singer 3116 Simple
My machine is jammed. it will go backwards but
It usually is stuck thread and it might only be the smallest piece, run a pin around the inside of the raceway and see if anything comes out.
Mar 23, 2010 | Singer 3116 Simple
Thread tangled in the bobine
I had this same problem yesterday. I took apart the needle tension casing and now it doesn't get tangled or stop. The only thing is the bobbin is not sewing...it looks fine on the top, but the bottom is just loose loops.
Jan 17, 2010 | Singer 3116 Simple
Hand Wheel Won't Turn
The "Bobbin stopper" is in the incorrect position. It moves from side to side in a switch like motion. In one direction, it locks up the machine. That is, you can turn the wheele backwards, but not forward.. The bobbin stopper can be found in the book that cam with the machine. In our book, it is item #9.
Mar 12, 2009 | Singer 3116 Simple
Singer 7444 trouble winding bobbin
It sounds like you don't have any tension on the thread when winding the bobbin. Make sure that you are running the thread through the tension disc on the top of the machine before going to the bobbin winder.
Feb 28, 2009 | Singer 3116 Simple
Singer Touch & Sew won't loop bobbin thread
I believe you have a broken gear. These are difficult to repair on your own.
Jan 19, 2009 | Singer 3116 Simple
Singer 600 touch and sew
Hold the tail of the needle thread loosely.
Turn the hand wheel toward you (counter clockwise) and lowerthe needle into the hole in the plate.
Turn the hand wheel until the needle rises back up to it's highest position.
Gen
You will see a loop of thread wrapped around the upper thread.
Open the loop and find the free end of the bobbin thread.
Voila!
Now you can sew.
Oct 23, 2008 | Singer 3116 Simple
Bobbin problems
Any time you have looping on the bottom, it is almost always related to the upper tension and not anything in the bobbin area.
A good way to troubleshoot this is to turn the machine off, blow out the upper tension disk assemblies with canned air, (the machine needs to be off because most canned air uses butane as a propellant. Butane + electricity = bad;) replace your needle, and rethread your machine. Once you've threaded it to the point where you're about to put the thread through the needle, "floss" the thread forward and backward to ensure that the thread seats correctly into the tension assemblies.
Set your tension to around 4.5 for most applications, and drop your presser foot. Give the thread a gentle tug to see if the tensions have engaged the thread, then thread the needle.
If doing this does not address the problem, you probably need to have your tensions professionally calibrated. This is also true if the needle is in fact hitting something in the bobbin area. This is usually caused by the machine's timing being out of alignment, which is not something that can be fixed at home.
Good luck,
-R
Aug 24, 2008 | Singer 6038 Mechanical Sewing Machine
Singer Featherweight II 117 Logo
71 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
