My Trane ModelTCONT402AN32DAA thermostat set for 75 degrees overshoots to above 81 degrees (as measured by a reliable thermometer). The thermostat temperature indicates 75 degrees and the heatpump will only turn off by manually reducing the temperature setting to a lower temparature. This is in the Heat mode but it does a similar "malfunction" in the Coolinf mode.
    Genius:
  • 1,015 Answers
I would remove front cover and see if your thermostat has a mercury switch.this will be a small vial connected to a bimetallic coil. The vial wiil be about 1/3 full of mercury. It will have a brite silverey appearence.There shoul be two leveling peg on inside of thermostat. Check the level with a torpedo level. it should be very close to level. If not loosen mounting screws that hold stat to wall and gently move base till you have it level. Hold base steady and tighten mounting screws. This should help thermostat setting and actual temperture to be closer. It's not unusual for setting to be off by several degrees.
Posted on Nov 15, 2010
My LEC T5029W is set to 1 however food in refrigerator is frozen -10 degrees C?
one is the coldest setting
set it higher say about 1/2 the adjustment of the knob
Aug 03, 2016 | LEC Refrigerators
Temperature OK during standard oven operation, however, overshoots set point 75-100 degrees during convection
clean temperature probes(sensors) usually found in oven center back wall, carefull not to damage.
Jan 11, 2016 | Jenn-Air JDS8860BD Dual Fuel Range
Set thermostat at 74 heat pump will not cycle it will cycle at 75 degrees ?
check stat calibration. see if you can measure temperture at stat. the thermostat cover temperture reading is not that accurate.
Jun 01, 2014 | Goodman CLQ36AR49 Air Conditioner
Trane thermostat is set to shut off at 75 degrees. The inside temp is 75 but the air keeps running. Why is the thermostat not shutting it down.
it may be out of calibration and is not that precise turn it up to 77 see if it shuts off. if not relay or contactor issue.
Aug 23, 2013 | Ruud Heating & Cooling
The oven cannot keep a consistent temperature. It is mostly about 100 degrees above the selected temperature. My landlord replaced the stove about a month ago and the problem is worse now than it was...
It sounds to me like the oven thermostat is faulty, as this is what controls the temperature.
If you can , get a thermometer and place it in the oven and check the temp against the seting with the thermometer, if as you say it is 100 degrees above setting , then you need to replace the thermostat.
Feb 06, 2011 | Hotpoint Ovens
My Trane thermostat (TCONT600AF11MAA) is supposed to have 1.5 degrees of heat pump "rest" above the desired setting before turning on the heat pump. The thermometer reading does not change yet...
Friend! All thermostat is calibrated to cut in and cut off at the end of - or + 1 degree end.
Example: If you set 23 degree, it will cut off in 21 degree and cut in @25 degree. So accordingly you set the temp.
Secondly, don't set temp near to your room temp.Minimum difference should be 3 degree. If your room temp 12 degree, set at least 15 degree for heat and if room temp 28, set at least 25 degree for cool.
Hope it's helpful?
Jan 02, 2011 | Heating & Cooling
1994 GMC 350 Suerra 1500 put in a new thermostat and temperature gauge still will not reach above 160 degrees. Thermostat is a 195 degree.
It depends on what reason you want the vehicle to reach 160 degrees. It seems 160 would be high to run a vehicle at. Nevertheless, if the mixture of anti-freeze and water at the correct mixture. If the mixture is not correct and it is more water than anti-freeze this will effect the heating temperature of the coolant.
Nov 28, 2010 | 1994 GMC Sierra
Oven temp set at 350. only heated to 310 after 1 hour! Set to 390 before reached 350. What to do?
Use an oven thermometer Try to figure out if by setting it to 390 it will maintain 350 accurately. (A 25 degree change while it cycles is normal. It will probably overshoot before going off and undershoot a little before cycling on.) If so the thermostat has just drifted. Pull off the control know and look usually there is an adjustment on the shaft to change the temp showing on the knob. set it up 50 degrees. If the knob can't be changed just know that you have to adjust yourself. If it won't maintain a steady temp the thermostat is bad and will need to be replaced. The thermostat will be over $100 it may not be worth it. If this is a computer controled unit (pushbutton temp selection) the sensor needs to be replaced. This is a lot cheaper than a thermostat.
Jul 03, 2008 | KitchenAid Kitchen Ranges
Edgestar 12000 heating problem
bad thermostat. the stat can be as must as 5 degrees off. try, if possible testing the unit in a differeent location
Dec 24, 2007 | EdgeStar Portable Air Conditioner Heater
Heating & Cooling Logo
122 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
