Question about Casio Parts Cash Register PC Desktop
Need to locate replacement slide switch. Unit will not stay on when "on" is selected without putting pressure on nswitch XE-A101
  • Casio Master
  • 1,780 Answers
Quite often, it is just a case of dirty contacts. Try squirting an electrical cleaner like DW40 in the switch. Otherwise, it may be a cracked solder joint on the switch. Check those two first. If it is the switch that is faulty, you will need to see a dealer in your area.
Posted on Nov 19, 2010
MACHINE WILL NOT INITIALIZE RIGHT OUT OF THE BOX. JUST BEEPS
Make sure the switch is on REG mode. Make sure there are NO batteries in it. Turn power off at wall for a few minutes. Turn on and it should beep three times. Then put the batteries in. If it beeps more than three times, the printer is probably jammed or faulty. Make sure it can turn. Try taking the ink roller out as it sometimes gets sticky and jams the printer.
Mar 23, 2016 | Sharp XE-A101 Cash Register
Lost till roll carrier can i obtain a replacement
Contact your nearest dealer and tell him you need a take-up spool
Mar 03, 2016 | Sharp XE-A101 Cash Register
HOW CAN I GET A REPLACEMENT KEY FOR MY SHARP XE A101
that machine does not use key
use the switch there
Feb 21, 2013 | Sharp XE-A101 Cash Register
Hello i have a sharp xe-a1010 cash registar and it froze. ive tried unplugging and reseting it but no luck. ive also tried the clear-escX2-subt# and nothing works.. help please thanks
I think you mean an XE-A101. Try turning the key to REG mode, take one battery out, turn off at wall for 10 minutes, turn on at wall. Put battery back in. NOTE you will lose any sales in the machine. If this doesn't work, then it is usually a keyboard or printer problem.
If anyone needs a manual for a Sharp XE-A101 cash register, c-tech has it here: http://the-checkout-tech.com/manuals/TOC/cashregisters/Sharp/XE-A101%20operating%20programming.TOC.pdf
Nov 26, 2010 | Casio Parts Cash Register PC Desktop
Garnin 260w slide switch will not turn off unit.
Try resetting the unit and also charge it using only the wall charger overnight. Here's how to reset -it just puts everything back to factory settings - 1- Turn unit on WHILE HOLDING your thumb in the lower right corner as shown in picture. 2-Select YES PLEASE Take the time to vote me up this is my only reward for trying to help. Thanks
May 01, 2010 | Garmin nuvi 205 GPS Receiver
Kenmore 70 series dryer problem
HI. This may be an issue concerning the pressure switch that is located inside the rim of the actual door.
This switch activates the main drum motor when a cycle is selected when you are ready to dry your clothes. As soon as you select the desired cycle and you load the clothes and shut the door, the last thing to do is push the start switch. if the door pressure switch is malfunctioning, it will not allow you to start the dryer. it will simply not spin.
If you can visibly see the light inside the drum/basket while the door is closed, this will confirm the malfunctioning pressure switch that is located inside the inner part of the door rim.
Its located in this position so that the actual door can make contact with it, in return, applying pressure to close the switch and complete the circuit. this will cause the dryer to spin.
You stated that you can see the drum light shinning when the door is closed and, this will confirm my diagnosis. You can preform a hard reset just to make sure of this defect. Simply unplug this unit for 5 minutes or, shut down the circuit breaker for 5 minutes as well. Any methods will work. Once the 5 minutes are up, simply plug back in this unit and try to run a normal cycle. if this problem is still and issue, it will once again confirm a door pressure switch failure and you will need to replace the switch in this unit.
I would check the wire clips and connectors as well located on this switch for lose or worn contacts. this can be a problem spot as well.
Please rate and god bless:)
Apr 26, 2009 | Kenmore Dryers
I bought a Sharp XE A102 cash register at a rummage sale only to find out that there is not an instructaion book in the like new box! I need to know how to program the thing ASAP as I'm leaving town with...
Not sure if this will help, XE-A101
intialize(clear) mode switch to REG and plug in.
Make sure battery and paper in the machine.
MODE TO PROGRAM:
TIME: enter 4 digit military time such as 8 AM would be 0800
3:00 PM would be 1500, etc press the #sbtl key time is in
DATE: Enter month date and year in 6 digits such as: March 15 2002 would be 0315202 depress the # sbtl date is in.
TAX RATE: 9 # SBTL TAX RATE SUCH AS 1 @ tm
70000 @/TM 10 CA/TEND.
YOU HAVE MADE 7 % TAX IN DEPARTMENTS 1 - 4
5 - 8 ARE NON TAX. THSI CAN BE CHANGED BUT MAY
GET YOU GOING . GO TO TO REG MODE AND SEE IF IT WORKS. AS I SAY THIE IS XE 101 MAY NOT BE THE SAME FOR 102.
Sep 02, 2008 | Sharp Office Equipment & Supplies
Casio Parts Cash Register PC Desktop Logo
22 people viewed this question
Top Casio Retail Supplies Experts
Electroboy
Electroboy
jackcity
jackcity
Level 1 Expert
tomferryman
Level 1 Expert
Are you a Casio Retail Supply Expert? Answer questions, earn points and help others
