Question about Bowflex Treadmill Series 7
Bowflex treadmill won't start. Get's power because the power switch is orange, but the monitor won't turn on. Safety clip is in place.
2 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: Err LS on Bowflex Treadmill
The machine needs to be re-callibrated. L5 error.
Your speed sensor must have been damaged either during shipping or use. You'll need a new one. If under warranty - give Bowflex a call. They will ship you out a new sensor and guide you through installing it via the phone... re-calibrating the machine... and getting it operational again. It will take about 2 hours.
The instruction book doesn't mention calibration. be sure to not callibrate in metrics, however (there's no way to easily tell the difference - you have to ask) or you'll be strolling like a walk in the park at 5 "mph".
Thanks for using FixY - a FixYa rating is appreciated!!
Posted on Feb 21, 2009
How to recalibrate a bowflex series 3 treadmill
Plug power cord into wall outlet and turn on power switch. 2. Stand on the side foot support platforms or rubber floor mat. DO NOT STAND ON THE WALKING BELTS. 3. Insert the Safety Key. Note: The Bowflex if the Safety Key is not fully inserted into the safety keyhole. 4. Press and hold hold "ENTER" and "POWER" for 3 seconds while the Console is dormant. The word "CAL" shows on the display. 5. Press "START". This enables display of maximum speed (with unit of measure) and maximum incline. 6. Verify correct units of measure (English imperial/ metric). Press "START" to change from one type to another. Press "ENTER" one time to set the measurement unit. 7. Press "START". 8. Press "POWER" again to save and exit, once calibration is complete
Oct 21, 2016 | Bowflex Exercise & Fitness
Why does my treadclimber TC20 display panel light up, but machine won't start
Generally that would indicate that the safety key is not in place, or a problem with the safety key magnet causing the machine to think the safety key is not in place. A call to Bowflex customer service should take care of it if that doesn't resolve it.
Jul 15, 2014 | Bowflex TC1000 Treadclimber
My treadclimber is in sleep mode how do I fix this ?
Make sure machine is plugged into a known working outlet, and make sure the power switch is turned on. Then make sure the yellow safety key is in place. At this point you should only have to press start to use the machine.
Feb 16, 2013 | Bowflex TC1000 Treadclimber
Bowflex TC5000 won't start! Lights on circuit board show power.
see the video and proceed according and fix it. God bless you
Jan 08, 2013 | Bowflex Tc5000 Climber Treadclimber...
Do i need a safety key to start the tc1000
Yes, it will not operate without the yellow safety key inserted into the console.
Dec 15, 2012 | Bowflex TC1000 Treadclimber
Treadclimber tc5000 will switch on but start button won't work
Make sure the power cable is connected to a known good outlet (test outlet with a lamp or some other electronic device) and connected securely to the machine. Make sure the safety key is securely seated or belts will not move.
Jan 16, 2012 | Bowflex TC1000 Treadclimber
My Bowman treadmill 7 series stopped working. It just shows 2 words: safe out. Please help.
Make sure the magnetic safety key ('safety pull' or 'emergency stop magnet') is in place. SAFE OUT indicates that the safety key is not in position or is otherwise not working properly.
For more information consult the following manuals:
http://download.dfxi.com/supportdocs/OM/Bowflex/BFX_TM3-5-7_OM_RevD_web.pdf
http://www.pdfstock.com/bowflex-3-5-7-series-treadmills-assembly-manual-pdf.html
May 05, 2011 | Bowflex Treadmill Series 7
Bowflex treadmill series 7 saying safe out
I had the same problem, however the treadmill remained in 'safe out' status even when the Safety pull pin was correctly inserted.
The cause of my fault was that one of the kids decided to insert a wrist watch into the round hole located on the control panel's lower cover. In doing so this unplugged the cable conector for the magnetic switch which operates the 'safe out' function, from the main circuit board. The repair was quick and easy, i turned the power off, removed the bottom cover from the control panel and simply plugged the magnetic switch back into the main circuit board and all was back to normal.
Jun 14, 2009 | Bowflex Treadmill Series 7
Bowflex Treadmill Series 7 Logo
55 people viewed this question
Top Bowflex Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Glenn Mayer
Glenn Mayer
Are you a Bowflex Exercise and Fitnes Expert? Answer questions, earn points and help others
