Question about Sony KV-27S42 27" TV
The t.v. clicks to turn on but shuts off right after what could be the problem
  • Sony Master
  • 17,129 Answers
Possible that the fault can be related to fault in the main board., Possible dry soldering joints, possible component malfunctioning.
It is important to remove the panel and check for dry soldiering, power cut off due to this when the set warms up. check on the areas of power components that heat up.
Please check this link for tips: Slow start
Posted on Nov 15, 2010
How do I turn off windows 8
To turn Off your Windows 8 PC, you can click the Power button on your screen and then click "Shut Down". If there is no Power button on your screen, you can follow the instructions below:
1. Swipe in from the right edge of the screen, and then tap "Settings".
(If you're using a mouse, point to the lower-right corner of the screen, move the mouse pointer up, and then click "Settings".)
2. Now, click or tap Power and then, click or tap "Shut Down".
The following link can be useful:
http://windows.microsoft.com/en-IN/windows-8/how-shut-down-turn-off-pc
Hope this will help you.
GuruAid.com
Sep 27, 2014 | Dell Computers & Internet
Tip
Customize the Shut down button windows 7
Customize the Shut down button The default action of the Start Menu's Shut down button is to turn off your PC. If you want to use the button for another action, such as restarting your PC, you click the arrow to the right of the Shut down button and select an action from the drop-down menu.
What if you rarely shut your PC down completely but frequently restart it? You can change the Shut down button's default action to be Restart -- or Switch user, Log off, Lock, Sleep or Hibernate.
To change your default, right-click the Start button and select Properties. On the Start Menu tab, click the "Power button action" drop-down menu and select which action you want to be the default. Then click OK, and OK again.
on Jan 12, 2010 | Computers & Internet
How do i turn off windows 8
1. In Windows 8.1, from the Start screen, click the Power button and select Shut down.
If you can't see Start screen, point the mouse to the bottom-right corner of the screen, click Settings, then click Power, then click Shut down.
2. From the Start button, select Shut down or sign out and then Shut down.
Jul 08, 2014 | Computers & Internet
Turn off windows 8
Screen stays on for about 20 minutes than shuts off after that..if you turn off and turn back on..it comes on then immediately shuts back off Its item #1704FPT 17" Monitor for 4700 Dimension...
On your Desktop, Right Click the mouse and Select Properties.
Click Screen Saver tab and Select Power. Change Turn Off Monitor
to Never. Your monitor should stay ON forever, until you turn its
power OFF.
Jul 21, 2011 | Computers & Internet
Please tell me how to reboot my laptop
If the operating system is Windows XP ...
1. click the start button at the bottom left corner of the desktop
2. at the bottom right of the start menu window that pops-up, click the Turn Off Computer button
3. at the right side of Turn off computer window in the middle of the screen, click Restart button
If the operating system is Windows 7 ...
1. click the round windows logo button at the bottom left corner of the desktop
2. at bottom right of start menu window that pops-up, click on Shut down right arrow for options
3. on the pop-up list of options window, click on the Restart item
Apr 30, 2011 | Toshiba Computers & Internet
COMPUTER HARD DRIVE SHUTS OFF WITHOUT TURNING OF COMPTER.
1) Go to Control Panel (Located on the start menu).
2) Then double click on Power Options.
3) The Power Options Properties window shall now open.
4) You will see a section called Settings for x power scheme, the x depends on which scheme is enabled.
5) Click on the down arrow to the right of Turn off hard disks: And set this to Never.
This should stop you hard disk from shutting off while your computer is still on. If you need any further help just add a comment.
Please rate this solution by clicking the thumbs up at the top right of this solution. Your rating is much appreciated.
Thanks.
Nov 02, 2010 | Computers & Internet
CD drive not working
Based on your indication the CD drive is clean, and you know the cables are attached to it, inside the computer. (Flat ribbon IDE interface cable, and 4-pin Molex connector power cable)
1.Go to Device Manager
Left-click on Start. Right-click on My Computer. Go down, and Left-click on Properties. Left-click on the Hardware tab. Go down, and Left-click on Device Manager.
Left-click on the + sign to the left of, DVD/CD-ROM drives.
Right-click right on the name of the CD drive.
(Example: Lite On DVDRW LH-20A1P.
eMachines Support indicates the T5212 has a DVD burner drive, and a CD drive. Right-click on the CD drive name))
In the drop down list, Left-click on Properties.
Left-click on the Driver tab
Go below, and Left-click on the Update Driver 'button'. Now go below, and Left-click on OK.
Close all windows, go back to your desktop screen.
Shut your computer down normally. (Start>Turn Off Computer>Shut Down)
Do Not Restart. We need a 'Hard Shut Down'.
Wait 1 minute, turn your computer on.
Still doesn't work?
Let's play hard ball.
2.Go back to Device Manager. Left-click on the + sign to the left of DVD/CD-ROM drives. Right-click on the name of the CD drive. Left-click on Properties. Left-click on the Driver tab.
This time go down, and Left-click on the Uninstall 'button'. Go below, and Left-click on OK
There will be a Microsoft 'squawk box' that comes up. "Warning you are about to uninstall this device"
Left-click on OK. (It IS okay!)
Close all windows. Shut down your computer normally. (Again, we need a 'Hard Shut Down'. To Restart a computer is known as a 'Soft Shut Down')
Wait 1 minute. Turn your computer on.
After Windows loads all the way, and all of your Start Menu programs have loaded, you should see a pop-up out of your system tray. (Bottom of Windows desktop screen)
"Found New Hardware", and perhaps another one, "Found XYZ CD drive". (XYZ = the CD drive name)
No still?
The driver for your CD drive, is located within the Windows XP operating system on your computer.
If your CD drive does not work now, I suggest it has failed.
Drives such as Optical drives, and Harddrives, are mechanical devices. Their 'Lifespan', is rated in so many hours of usage. Your CD drive may be at the end of it's 'Lifespan'.
Oct 04, 2009 | Sony VAIO PCV-RX462DS PC Desktop
Web cam won't turn off
Right Click My Computer
Select Properties go to Hardware , Device Manager
Loctate Web Cam right click on it and tell Windows to shut it down or Disable
Jul 04, 2009 | HP Computers & Internet
Systemax laptop not shutting completely down
Try this ;
Buried deep inside Windows XP lurks a little-known program called shutdown that shuts down your system in a very fast � but orderly � way. Here's how to put an icon on your desktop that'll shut down your machine quickly:
1. Right-click any empty location on your desktop.
2. Click New, Shortcut.
The Create Shortcut Wizard appears.
3. In the Type the Location of the Item box, type shutdown -s -t 0.
It's important that you put spaces before each hyphen, that you have no spaces after each hyphen, and that you use a zero at the end.
4. Click Next. 5. In the Type a Name for This Shortcut box, use a name that will remind you that this button is for a very quick shut down.
6. Click Finish.
Jan 15, 2009 | Systemax AOL Optimized PC (100607) PC...
Sony KV-27S42 27" TV Logo
26 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
