Question about Olevia LT37HVS 37 in. LCD HDTV
When i turn on the tv there is a flash then in just stays black took it apart and the copasitors arn't blown what could it be?
  • Olevia Master
  • 17,130 Answers
You will need to start from the main power supply section to see if the power works. Please check this link for tips on SMPS
You will need to remove the panel to determine the voltage that comes to feed the main board. check the +B , if the voltage dies off, if so check for short in the circuit. Possible drivers being short can also be the reason. Remove off the leads to the output and check if the voltage builds up to confirm.
Posted on Nov 15, 2010
I have a Vizio M550VSE tv and for the life of me I can’t fighre out what’s wrong with it. The issue I was having is the screen would just flash when turned on and then go black. It pssed the flashlight...
It could be a bad connection that shows up when the screws are tight that hold it together. Put one screw in, test, next screw, test, etc till you find the one causing the issue.
Nov 13, 2017 | Vizio Televison & Video
I have a 2013 Samsung 32inch tv that keeps turning on and off when plugged in. I took it apart and it has a blown copasitor....is this why it is doing this?
yes the capacitors keep the voltage steady, need replacing with same voltage and uf number. also make sure they 105c rated..
Jul 23, 2017 | Samsung Televison & Video
When i turn my tv on the screen just stays black. You can hear the volume. I just replaced my bulb about a month ago. I took the bulb out again to see if it was blown and it wasnt. Does anyone know wh
send me a email slinteriors@yahoo.com and I will send you the info to retreve the error code to find out why the set is shutting down. Be sure to include the moodle number and symptoms with your email
Feb 10, 2013 | Mitsubishi WD-65C9 65" DLP HDTV
Green light stays on, while the tv has black screen? and stays on for 2mins and than black screen come on, than 20secs later turns on again and this happens repeately
if its a rear projection it could be the light bulb is bad or blown. You can get ideas of what the lights mean at sony. If its the light don't buy one from Pure Glare. com They send out bad or blown bulbs.
Dec 08, 2011 | Sony Televison & Video
Samsung HD tv. had for 2 years. Heard loud pop when tv was off. now won't come on
Samsung Plasma TV HP-T4264. Found a component (mosfet transistor) open (split open). The ones attached to the big aluminum heat sinks. In our case it was part number FQPF9N50C. Mouser.com has them for $1.64 each. I am waiting for the component to replace and though I'm not 100% sure this was the problem, it's very likely.11_12_2011_4_07_50_pm.jpg
Nov 04, 2010 | Samsung Televison & Video
Sony kp-61hs10 tv, has sound but picture goes black after 3 min.
I just had the same problem. If your lucky it might be a free 5 minute fix. The five light flashes mean impropper current. I took the front grill off, then behind that is another black cover, I took that off and noticed the circuit boards COVERED in dust. I then took an air can duster and blew off all the dust... works like new. No more flashes and in an out picture. The collection of dust was interfereing with the electrical current.
Ben
Apr 15, 2009 | Sony KP-61HS10 61" Rear Projection...
The tv skeen stays black but the red light stays on . is my tube blowned out and needs replaced .idon't know can you tell me ?
If the screen is black but on, as opposed to black because it is off, check to see if your timer is set to turn the tv off.
Mar 08, 2009 | JVC AV-32050 32" TV
Tv picture tube blown
i actually have this bulb delta 771co well i have all 3 of them red blue and gree that worked when i took the tv apart. The problem with the tv was it would turn on for a few minutes then shut off so i took these out not more than 2 weeks ago. Make me an offer i will sell you all 3. jacobson767@yahoo.com
Jul 28, 2008 | Televison & Video
Tv screen stays black with the blue light and two red lights blinking
I have the same problem, if anyone has a solution PLEASE mail me at macry2121@aol.com
Apr 04, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Mitsubishi flashing light replaced capasitors that were blown tv still has flashing light
The four cap replacement in DM module repair is simplistic
and incomplete, as you found out. ALL defective DM modules
have bad SMC's ( small "top hat" caps) AKA surface-mount
capacitors that can be changed only by the most highly skilled
bench techs. We used to change out hundreds years ago in
camcorder circuit board repair.DM board repair is a much more
accessible,thus more "do-able". For more info.............T.
Sep 26, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Olevia LT37HVS 37 in. LCD HDTV Logo
41 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
