I have an Imation "Swivel Pro Flash Drive" "USB 2.0, 1GB". When I started using it there was only 1.95 MB available. How can I set it up to get the 1GB it should have? Thank you, Jim Weber 650-796-2001, thorgilsy@yahoo.com
  • Rabby V V
    Rabby V V May 11, 2010
    hi
    have u tried formatting it?
    Champion:
  • 214 Answers
Hi, format the drive in FAT16 format
Posted on Jun 19, 2008
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 69 Answers
Format your flash drive with the HP USB Disk Storage Format Tool - v2.1.8
My imatinon nano usb 4gb now only 1 mb what should i do?
I'd go into disk manager, delete any partitions and reformat the flash drive.
Dec 23, 2012 | Imation 27102 4GB Nano USB 2.0 Flash Drive...
What is the password for the new kingston USB DT109?
It is true that locking mobile storage devices, such as USB drives, with Imation Lock is an excellent way to protect your data.
However, using Imation Lock with a Kingston USB drive can create problems.
Learn how to unlock your Kingston USB drive so you can use it once again.
Ensure that your Kingston USB drive has been removed from your computer's USB port.
Start the Imation Lock software by double clicking the Imation Lock.
Plug in the Kingston USB into a USB port immediately after the "Please Insert the Device or Run This Utility as Privileged User" message appears.
Access your Kingston USB drive by clicking Start > Computer.
Double click on the device.
Start the Imation Lock software again by double clicking the Imation Lock.
Disable the password protection by clicking the open lock icon.
or
If you have password protected a USB drive or partition on your computer and have since forgotten the password, you will need to completely erase the drive.
Erasing and reformatting the drive will remove any password protection, software and data on the drive preventing you from accessing the drive.
The process is simple using Window's Disk Management utility.
Log into the computer as the administrator.
Open the Windows Start menu, select "Run," type "Compmgmt.msc" and click "OK." In Windows Vista and Windows 7, simply type the command into the "Search" field.
Select "Disk Management."
Locate the password-protected drive.
Right-click it and select "Delete." Confirm the action.
The drive will be erased and become unallocated free space.
Hope this helps.
Nov 28, 2012 | Kingston Ultra Thin DataTraveler DT 109...
My new imation usb 16gb is only 14.4gb in its actual properties, is this normal?
it is normal that you dont get the exact allocation size on disk itself and on the disk label, normally it only has a 500 to 800 mb difference.
Sep 04, 2012 | Imation 16GB USB Flash Drive 27125
Pen drive memory problem
click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in one box then select
check now start or you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
click start click on computer then right click on your kingston usb drive select format
the right click on your drive select properties you will see how much data you have and the ammount free space
if you need more help with this post a reply
hope this helps you
Jan 12, 2012 | Imation Electronics - Others
My imation flash drive nano 32 gb was partition public is 4gb and private is 28gb, how can i delete the partition so that it will return to its original size of 32gb.. i partition it using the imation...
click start click on computer then right click on your imation usb drive select format
this will return it the original size but it will remove any data on it
you could try to expand the partition
click start control panel administration tools computer management disk management you should see your usb drive right click in the small partition see what options are available a delete option might be there im not sure on imation software (partition magic has this option)
hope it helps
Aug 13, 2011 | Computers & Internet
My louck flash is formated and now i can not use the space what do i do?
Your Imation Swivel Flash Drive comes formatted and ready to use right out of the box.
If you will be using the drive exclusively with Macintosh computers, do not format the Imation Swivel Flash Drive. The formatting message appears if your Macintosh has not yet been set up to read Windows-formatted files. Refer to your Mac's user manual to learn how to enable Windows file read functionality.
Also, be aware that when you format your Imation Swivel Flash Drive with NTFS, you will not be able to store as much data as your would without formatting. The format file used by NTFS will use some of the available space on the Flash drive - for instance, on a 128MB Imation Swivel Flash Drive, you may lose up to 8MB to the NTFS format files.
How do I format my Imation USB 2.0 Swivel Flash Drive in Windows? Your drive must be set up as a single public partition, since neither Windows Explorer nor the Macintosh OS will recognize a password protected partition.
To format the drive in Windows:
  • Go to My Computer
  • Locate the corresponding drive letter for the Swivel Flash drive (i.e. removable drive F)
  • Right click
  • Choose Format from the menu
A dialog box will come up and allow you to format your Swivel Flash Drive. Depending on your operating system, you can choose to format the drive in FAT, FAT32, or NTFS.
How to I remove or resize a partition on my Imation Swivel Pro Flash Drive? To resize or remove a secure partition, you will need to do the following:
  • Open the Flash Manager software on your hard drive
  • Choose Create a partition
  • Move the slider to zero (0)
Why don't I see a drive letter for my Imation Swivel Flash Drive?
This problem occurs if you map a network drive to the first available drive letter following the drive letters for the local volumes and CD/DVD drives. When you install a new device or volume, a software called Mount Manager tries to assign drive letters to the new volumes. But since the software does not recognize mapped drive letters, it assigns the next available local drive letter to the new device. This causes a collision with the existing mapped network drive.
Since the problem is related to your Microsoft operating system, they are your best source for resolving this issue. For more information, click here.
Dec 05, 2010 | TDK (CD-RW74HSFXS5) Storage Media
Imation Swivel Flash Drive Cant detect
Check it another computer. If drive is still powerless, then you most likely have a failed flash drive.
Mar 03, 2008 | Electronics - Others
LS 120 Super Disk 120 MB Imation
hey there,
all i can say You make it a point to stay on the cutting edge of IT, so it's only fitting that your next support call is for a cantankerous old floppy drive. You're as far from the cutting edge as you can get, but can you still find the fix?The floppy drive is...
Feb 04, 2008 | Imation (11762) LS-120 (SuperDisk) Storage...
USB imation drive 1 gig
Usb is infected with virus and if u cant re-write it with binary languange just buy new
Oct 23, 2007 | Electronics - Others
Computers & Internet Logo
101 people viewed this question
David Payne
David Payne
