Question about Samsung SyncMaster 245BW Monitor
Monitor will not display in native resolution.
I recently had my 245bw sent out for service because the backlight started flickering. Got it back, and now its all well and good, except for one problem: it won't display in its native resolution of 1920x1200 anymore. It will only display in 1600x1200. I didn't buy a widescreen monitor to look at a 4:3 aspect ratio. I have updated the drivers from Samsung's website (multiple times!) yet the problem presists. Help!
  • vladimir24 Jun 20, 2008
    Thanks. They took it back and are sending it back out for repair. Hopefully this solves to problem, although I was hoping I wouldn't have to wait around for another fix, but that's on their end.
    Thanks a lot, it helped when I went in to explain the problem!
  • Anonymous Sep 27, 2008
    I had the same problem with the flickering and now it just went out on me completely.
  • 558 Answers
Sounds to me like they replaced your vga board with another compatible one but not the same exact one I would call the repair facility that did the work and ask questions about how they repaired the monitor like if they used another vga board etc. hope this helps
Posted on Jun 19, 2008
Occasional odd coloring and backlight flickering
Please check it monitor color adjust button. If ok then you check it monitor cable if change possible then change it or power cable also proper connect. If not solved contact Good Monitor technician.
Thanks.
Feb 17, 2014 | Apple Cinema Display 23" HD Monitor
Tip
Flickering LCD/CRT monitor screen or unstable image fix
If the screen flickers, make sure the display settings in Windows match the native resolution and refresh rate for the monitor. You can find the native resolution of a flat panel display in the specifications, in the printed material or on the box that came with the monitor. Some common native resolutions are 800 x 600, 1024 x 768, 1920 x 1080, and 1680 x 1050. To find out more about optimal screen resolutions see my tip on resolutions here.
The most common refresh rate for LCD monitors is 60 Hz. This normally cannot be changed for flat panel displays using Plug and Play settings. However, if you are using special video software to increase or decrease the refresh rate, change the refresh rate to match the default refresh rate specification of the monitor. To find out more about refresh rates see my tip here.
STEP 1
To change the screen resolution and refresh rate settings in Windows, do the following:
- In Windows XP
See my tip on setting up the optimum screen resolution for Windows XP here.
- In Windows Vista
1. Click Start, and then click Control Panel .
2. Find the Appearance and Personalization area, and click Adjust Screen Resolution .
3. Move the slider bar until the screen resolution matches the native resolution.
4. Click Advanced settings, and then click the Monitor tab.
5. Select the Screen refresh rate that matches the default rate for your monitor (if it is not already selected).
6. Click OK, and then click OK again.
If you cannot select the native resolution or the native resolution is unavailable, continue to the next step to update the drivers for the graphics adapter on the computer.
You can get the latest updated video drivers from the video hardware manufacturer's Web site. Here is a list showing some of the video hardware websites:
Check for NVIDIA video driver updates at NVIDIA Home Page.
Check for ATI/AMD video driver updates at ATI Home Page.
Check for Intel video support and downloads, Intel Downloads.
After updating the video drivers, go back to Step 1 and try to change the screen resolution again.
Note: If you cannot select the native resolution after updating the video drivers, the graphics adapter in the computer might not support that resolution and may need to be upgraded.
If after changing the resolution and updating video drivers the flickering persists then check the video cable connections. Unplug the cable and inspect the cable for damage. If the cable is damaged, replace it with a new cable. Try to use cables less than 3 meters (10 feet) long.
Monitors are sensitive to magnetic fields so have a look at the environment around the monitor. Speakers, florescent lights, fans, cell phones, radios, and any other electrical device can cause flickering. Temporarily move electrical items away from the monitor to see if they is producing a field that causes the flicker.
If the monitor has more than one type of connection available such as VGA, DVI, or HDMI, try a different type of connection.
To see if the video coming from the computer is causing the problem, temporarily connect the monitor to another computer. If the flicker is gone when the monitor is connected to another computer, the graphics adapter hardware on the first computer might need to be upgraded to use the monitor.
If however the flicker remains then the problem lies within the harware of the monitor itself and is not a software problem. If you have bought this monitor fairly recently then I suggest you take it back to the place of purchace and have them test it. Some monitors carry 3 year warranty support so if you bought it within the warranty period specified by the reseller I suggest you see if you can get refunded or have them swop it out.
on Jun 08, 2011 | Computers & Internet
Backlight flickers
drop it down from the window!
Nov 27, 2011 | Samsung SyncMaster 245BW Monitor
Get this flsh out of my monitor.
Hi there.
STEP 1
- In Windows XP
- In Windows Vista (Same for Windows 7)
Check for ATI/AMD video driver updates at ATI/AMD Home Page.
Check for Intel video support and downloads, Intel Downloads. (If you have an Intel mainboard and are using onboard graphics).
NOTE: If you are using onboard graphics with a mainboard that is not manufactured by Intel, just give me the name and model number of your mainboard and I can try and locate the graphics drivers for you.
To see if the video coming from the computer is causing the problem, temporarily connect the monitor to another computer. If the flicker is gone when the monitor is connected to another computer, then this means that the graphics adapter hardware on the first computer is damaged or might need to be upgraded to use the monitor. On the bright side at least it's not your monitor.
If however the flicker remains then the problem lies within the hardware of the monitor itself and is not a software problem. If you have bought this monitor fairly recently then I suggest you take it back to the place of purchase and have them test it. Some monitors carry 3 year warranty support so if you bought it within the warranty period specified by the reseller I suggest you see if you can get refunded or have them swop it out.
~Slasher_X
Oct 30, 2011 | Philips 190B6CB/27 19" LCD
Monitor does not display all the icons but a computer displays well when connected to an external desktop monitor
If you mean the desktop isn't completely filling the display, you need to be sure the resolution is set correctly. Native resolution for this model is 1500x1050, according to Dell's site. (Native resolution is the one the screen was designed to best work with. Unlike older CRT monitors, some resolution settings don't work well on LCD screens.) You can check and set the resolution through the Windows control panel.
If you mean that the display is dim and hard to make out, but is okay on an external monitor, you probably have a backlight issue. Without the backlight, you can't see what's on the screen even though the display is working. The usual cause of backlight failure is a bad inverter. The inverter is a small circuit board in the display that provides power for the lamp. Replacements are available for most laptops, and changing one is normally not a major job.
Sep 29, 2010 | Dell Latitude D610 Notebook
I RECENTLY STARTED USING BENQ MONITOR & NOW I HAVE IRRITATION ON MY EYES. WILL THERE BE ANY RADIATION FROM BENQ MONITORS
There's practically no radiation from LCD monitors, especially compared to older CRT monitors, which radiated several sorts of electromagnetic waves.
Is the picture on your monitor crisp, with good focus? If the letters and shapes are blurry, it may mean that you are using a different screen resolution than the native resolution of your LCD.
If your monitor type is FP731, then it's native resolution is 1280x1024 and this is what should be set in the Display Properties under Settings tab (in Windows). If it's a different model, you can search for it's specs on the web to see what is it's native (a.k.a. optimum) resolution.
Please rate and possibly leave a testimonial if helped.
Jan 06, 2010 | BenQ FP731 17" LCD Monitor
I recently purchased and installed the P191W monitor, and now my pictures are stretched. I was told I new to get a new graphics card. What card should I get? Or can I just update the driver? I am running...
Find your monitor's native resolution, in your case it's 1440x900. Go to display settings (usually right-click on desktop and choose properties), go to settings tab and move the resolution slider until it shows 1440x900. Confirm, the screen should flicker for a moment and adjust - and you should be fine.
If there is no 1440x900 resolution available, then installing a monitor .inf file that came on a disk accompanying the monitor might help.
Oct 24, 2009 | Acer AL1916W 19" LCD Monitor
1440x900 Monitor seems to think it is a 1680x1050 screen @ >19"?
Try reinstalling the video driver (Control Panel - System - Device Drivers - Video ... ) Good luck
Jun 13, 2009 | ViewSonic VA1930WM LCD Monitor
Syncmaster 245bw monitor resolution screen and resolution issues
These two devices are not compatible, you may need to read the information on this LCD MONITOR to see if the resolutions are compatible, this often times happen when monitors are purchased!
Nov 25, 2007 | Samsung SyncMaster 245BW Monitor
Samsung SyncMaster 245BW Monitor Logo
517 people viewed this question
Top Samsung Computers & Internet Experts
phoenix chi
phoenix chi
Brian Sullivan
Brian Sullivan
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
