Question about Refrigerators
Clicking Noise From Refrigerator GSH25JFRF WW
My refrigerator stopped work the other day its making a clicking noise like a relay but unplugged it defrosted for 24hrs and then works fine. The model number is GSH25JFRF WW. Please send me an email to halextran@yahoo.com. Thank you.
  • 2 more comments
  • Anonymous Apr 11, 2009
    Same problem.
    Same issue...Not sure I want to defrost it because the food is still currently frozen.
  • Anonymous Apr 23, 2009
    Same
  • Anonymous May 02, 2009
    same problem today
  • 90 Answers
SOURCE: ge side by side refrigerator
what is your serial #
Posted on Jan 07, 2008
Ge gsh25jfrf bb sise by side refrigerator. Freezer not cold, fan not running, not turning, and is making a clicking sound. What's the cause of this?
if the fan is making a clicking noise, replace it, but be prepaired to replace the main pcb if it does not start right up..... on a ge if the evap fan motor shorts it will take out the mother board (pcb)
Oct 09, 2014 | Refrigerators
My bottom freezer amana refrigerator is making a clicking noise. And my freezer is barely cold.
Refrigerator making clicking noise compressor not running.
The clicking could be the start relay.If the start relay is bad, the compressor will not start and you will hear a clicking noise in 2-5 minute intervals. The clicking noise is the overload cutting the compressor off when it overheats from trying to start with a bad start relay. To find out if this is bad first unplug the refrigerator. Remove the lower cover from your refrigerator. Then take the cover off that is on the side of the compressor,you will see wires going to this. Now you should be able to see the start relay plugged on to the side of the compressor and unplug it. Now the best way to tell if it's bad is to shake it. If it rattles, it's bad and needs to be replaced. If not, most of the time it's ok. But rather than saying the compressors bad, you might want to replace it anyways because it does not cost much. A quick check on the compressor is to remove the start relay. You will see 3 pins connect a multi meter set for continuity. You should have continuity between any of the 3 pins. If you do not the compressor is bad. Also check from each pin to a good ground on the cabinet. There should be no continuity if there is the compressor is bad. If you replace it and it doesn't work then the compressor is bad and you'll need to call a repairman. (Note that compressors are very costly and are normally not worth fixing).You can enter your model # at Refrigerator clicking for diagrams and illustrations or to purchase a start relay. A 3 in 1 start relay will also work fine.
Jan 29, 2011 | Amana Freezers
My refrigerator and freezer are not working when i plug it in it sounds like something in the back is clicking on and off. is there a rest button?
one thing can cause the clicking noise, the ptc overload relay on the compressor is making this noise and needs replacing,it simply unplugs off the compressor and the replacement plugs in these are available at most appliance repair dealers
Jan 09, 2011 | Estate TS25AGXRD Side by Side Refrigerator
I have a GE GSH25JFRF BB refrigerator that will stop working every 3 to 4 days, i unplug it and plug it back in and it works, also the ice quit despensing about the same time
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 15, 2010 | GE GSH25JFR Side by Side Refrigerator
It keeps clicking trying to start, what might be the problem?
The clicking could be the start relay.If the start relay is bad, the compressor will not start and you will hear a clicking noise in 2-5 minute intervals. The clicking noise is the overload cutting the compressor off when it overheats from trying to start with a bad start relay. To find out if this is bad first unplug the refrigerator. Remove the lower rear cover from your refrigerator. Then take the cover off that is on the side of the compressor,you will see wires going to this. Now you should be able to see the start relay plugged on to the side of the compressor and unplug it. Now the best way to tell if it
Jul 19, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
GE bottom freezer began making a clicking noise, will not run
The clicking could be the start relay.If the start relay is bad, the compressor will not start and you will hear a clicking noise in 2-5 minute intervals. The clicking noise is the overload cutting the compressor off when it overheats from trying to start with a bad start relay. To find out if this is bad first unplug the refrigerator. Remove the lower cover from your refrigerator. Then take the cover off that is on the side of the compressor,you will see wires going to this. Now you should be able to see the start relay plugged on to the side of the compressor and unplug it. Now the best way to tell if it’s bad is to shake it. If it rattles, it’s bad and needs to be replaced. If not, most of the time it’s ok. But rather than saying the compressors bad, you might want to replace it anyways because it don’t cost much in most cases (less than $25). If you replace it and it doesn’t work then the compressor is bad and you’ll need you call a repairman. (Note that compressors are very costly and are normally not worth fixing). You can also enter your model # at www.appliancehelponline.com for diagrams and illustrations.
Apr 09, 2010 | GE GDS20SBS Stainless Steel Bottom Freezer...
Freezer/Refrigerator tempurature swinging wildly
The compressor is overheating and not starting. Could be just the start relay. If this happens again try unplugging it for about an hour then it should work for a while. Heat between doors is normal this is an electric heater designed to keep the doors from sweating. You just noticed it because the refrigerator wasn't cold.
Jun 26, 2008 | Freezers
Maytag refrigerator clicking noise and stopped working
Maytag has recall on refrigerator relay for certain models. Check https://repair.maytag.com/prjjck/refrigerator.jsp
Mar 16, 2008 | Refrigerators
Ge side by side refrigerator
Jan 06, 2008 | Refrigerators
Side by side stopped working but clicling noises every second two.
Ok the motherboard is malfunctioning. Ive observed this exact problem before. Replace the board and all will be normal again. If you keep lettig it click and click it may finally kill that relay that you descibed to me or even worse the compressor itself.
Dec 02, 2007 | GE GSL25JFR Brushed Steel Side by Side...
Refrigerators Logo
459 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
