Midiland Gcs-691 speakers are working but no external sound. im thinking i need to update drivers
  • 95 Answers
SOURCE: cant get speakers on my monitor to work after I unhooked external
IF you have xp go to control panel/sound,speech and audio. You will see a drop down choice that says change speaker settings. Click on this. Then under the tab that says speaker settings hit advanced. Then select the sound scheme that says monitor with stereo speakers and apply this. Assuming you still have a functioning sound driver this should return it to the monitor speakers. Hope this helps.
Posted on Mar 29, 2009
ankushsethi
  • 61 Answers
SOURCE: NO SOUND
www.10001downloads.com
Posted on May 16, 2009
Jermzii
  • 106 Answers
SOURCE: I have no sound from my Multi-Media Alaska ms 691
make sure that they are plugged in to the right connection in the back of the computer, this jack is usually color coded light green.
Posted on Aug 06, 2009
  • 1584 Answers
SOURCE: IBM thinkpad type 2647 - after installing external
Go to control panel / sounds / audio, and see if the boxes have greyed out writing, if so then the driver needs reloading, if they are all good check all settings.
Meant to ask if volume control icon is showing in the right lower task bar.
Posted on Dec 22, 2009
SOURCE: HP Pavillion HDX 9000 - No Sound from Speakers
hi all after replacment of speaker no sound comming fron spaeker,so suggest
Posted on Apr 29, 2010
Had my computer rebuilt and now my cambridge soundworks GCS300 speakers will not work....what do i do
Generally speakers will not need a driver, its more likely your soundcard needs the driver - have you tried anything else rather than the speakers to get sound? If you cant get any sound at all then its your soundcard so you will need the driver for it - otherwise try the link below, its the only thing that comes remotely close to a driver for these speakers -
http://www.bioticaindia.com/gcs300.html
thx, hope this helps :)
Jan 28, 2011 | Gateway Cambridge SoundWorks GCS 300 PC...
My speaker is not working with my computer
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
also you if this does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
hope this helps
Jan 27, 2011 | MidiLand MLi SW190 Computer Speakers
No sound
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have made the correct adjustments there
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar
hope this helps
Jan 13, 2011 | MidiLand MLi 691P Computer Speakers
The computer sound isn't working
the drivers might have been corrupted by something foreign or you might have got a virus run your antivrus program
hope this helps
Jan 12, 2011 | MidiLand MLi 190 Computer Speakers
Not playing sound on my computer but plays sound on other things
the built-in speakers may have failed or you need to update drivers. please provide more details for us to follow up! what happen just before they failed?
Dec 20, 2010 | MidiLand MLi 691H Computer Speakers
My mli 699 speakers are not working . And I dont have the driver
if your computer came with a motherboard disk the sound drivers could be on it
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or
audio you will find 3 drop down lists make the necessary adjustments there or
control panel,administrive tools,computer management,device manager,sound video and game controllers could be a yellow question mark? right click to re-install drivers
hope this helps
Dec 12, 2010 | MidiLand MLI-699 Computer Speakers
My hp laptops volume sounds really distorted im not sure why?
The first thing to check is to ensure you have the most updated drivers for your computer and the audio section. If that is okay, then it may be that the speakers are busted. If you have a set of headphones, you can plug them in and if the sound is okay, then the problem is probably your speakers.
Nov 29, 2010 | Computers & Internet
I recently got a new computer & it has windows
If there is not a dedicated port for the sub, you are out of luck. Unless - the MLI sub can serve as the splitter
Jul 24, 2009 | MidiLand MLi 450 Computer Speakers
Speaker power supply
Found power supply for MLI-691 H speakers
Output is 9vdc, 600 ma. center of plug +.
SUN 9
Jun 10, 2007 | MidiLand MLi 691H Computer Speakers
Computers & Internet Logo
99 people viewed this question
David Payne
David Payne
