Question about Dell V305w All-In-One R840635AU InkJet Printer
V305 I put new ink in and it says cannot allign. says check to make sure tape is removed. I have and it is....
  • 3,267 Answers
Ink may be new, but their nuzzles may be blocked; depending on manner of storage. To be sure apply a folded tissue paper to the ink nuzzle and press firmly. If the tissue comes off well blotted with ink it means you still have a good amount of ink in it and the nuzzle is not blocked. If not blotted or scantily blotted, it means ink is really low or nuzzle is blocked. To be very sure of this, place nuzzle in a plate/saucer with a bit water so that the nuzzle is soaked. Leave for about 10 minutes. Then apply the tissue again. If still not well blotted it means ink is really low or empty. If new you should return it for a replacement. In the case of blocked nuzzles, the procedure may be repeated over to get results.
However you may also
need to run the maintenance program for the printer, and align the new cartridge. The printer will do that with the numbers & letters you put in, after it prints a setup page.
Posted on Nov 15, 2010
I changed the color ink cartridge and now all it says is paper not alligned take tape off of ink cartridge and press ok
I beleive that it is telling you to take the sealing tape off the ink cartridge, so remove the cartridge and ensure that there is no tape and re install
Aug 11, 2014 | Office Equipment & Supplies
Dell v305 printer allignment problem
Hello Michelle,
You are using Dell Series 9 ink cartridges, correct?
If you unplug the printer from the wall and remove the power brick for 60 seconds, this will reset any error messages the printer has. I would then plug everything back in.
Power on the printer.
Open the printer(with the power on) and take out the Dell Series 9 black cartridge and then reseat it. I would then take out the color Dell Series 9 ink cartridge and reseat it. Now close the printer and it will print an alignment page.
Any error messages?
black cartridge = black side(left side) color cartridge = color side(right side)
photo cartridge = black side(left side) color cartridge = color side(right side)
It's possible to get a Dell Series 9 ink cartridge with a bad sensor. I would take these back to the place of purchase for a replacement.
Bhautesh,
Jan 30, 2014 | Dell Computers & Internet
Printer says allignment is off and I need to remove tape from Black ink but there is no tape on black ink, bought new cartridge even though I did not need one and still says same thing
If you're still experiencing the same problem even with a new cartridge, it could be your printer itself that is the problem. Please contact Lexmark Technical Support Center for assistance.
Mar 08, 2012 | Lexmark X5495 Printer
Dell v305 all in one printer alignment problem remove tape from cartridges. what does this mean?
There is usually tape protecting the ink nozzle on the bottom of the ink cartridge. Did you remove this before inserting it into the printer?
Jan 22, 2011 | Dell Office Equipment & Supplies
My printer will not print black ink, says I need to remove tape from cartridge? the ink is partly gone and has been working and is not empty.it will be a cppier and do it but not from computer.
Mine did same ....turned out I was out of ink.....even though the estimated levels say I had a full black and near empty color ...went to store picked up a color cartridge ..put it in and it still gave me the same err message [allignment prob please remove tape] thats when I tried to clean cartridges and there wasnt any black ...soI went out & got a black also ...put it in and wala Im back in buisness...accept for the wrong messages or is it a software prob?
Sep 14, 2010 | Dell V305w All-In-One R840635AU InkJet...
Aligment problem
I replaced my ink cart. Now it states that the aligment is off so I did the test and now it is saying that I need to take the tape off of the cart. There is no tape
What to do?
Jun 14, 2010 | Dell V305 All-In-One InkJet Printer
New cartridge installed printer gives message that
Check both cartridges, one might still have plastic film that needs removal.
Dec 17, 2009 | Dell 926 All-In-One InkJet Printer
Fax machine
Your machine is telling you it cannot read the new cartridge for some reason. Try running an allignment scan form the printers management area.
Feb 08, 2008 | Lexmark X4270 All-In-One InkJet Printer
Refill colored ink, what holes, lexmark x5470
To open the printer, just above the front control panel you use both hands & pull upwards. The whole top of the printer will open up. The ink cartrifges will be close to the center of the opening. The printer should be on for this. There are two ink cartrages. The one with the black lid is for your black ink. There is a small tab in front of the cartridge lid. Push down on the tab & the lid will open. Remove the old ink. Remove the tape that is protecting the the bottom & copper back side of the new ink. Place the ink into the printer. The copper back that runs from the bottom & up the back side about 3/4" goes into the printer cartridge. The colored ink goes into the other cartridge holder, it's lid is blue. Again press the tab just in front of the lid & it will pop open. Repeat the above removing the protective tape & install the ink.
The ptinter will want to run either a test page or allignment page or both. You will need your manual. If you do not have your manual you can download it from this site. Click the link below.
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=f7f0a21c03aee016b79da0cdbb74cf9f&q=Lexmark+X5470
Click "Start download" & save it to your Pc.
Have fun!
please vote...
Jan 20, 2008 | Lexmark X5470 All-In-One InkJet Printer
Not copying or printing
Your printer is telling you it cannot allign the cartridge due to tape, did you remove all the tape off a new cartridge? I use the cleaning solution that comes with the ink refil kits to clean the printer heads and bottom of contact, and have you checked for roller jams, paper jams etc inside unit itself. Also, could be a commincation error. Try turning off unit, unplugging it and reverse, try agian, this resets it. Good luck, post back if no go cheers lilacgerry xxx
Sep 29, 2007 | Lexmark X6170 All-In-One InkJet Printer
Dell V305w All-In-One R840635AU InkJet Printer Logo
142 people viewed this question
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
