Question about Banner Faucets Castille 600 Series Brushed Nickel Bathroom Faucet...
WHEN MY SHOWER IS TURNED ON THE WATER ALSO FLOWS OUT OF THE FAUCET. HOW DO I TAKE OUT THE STEM TO CHANGE THE SEALS?
  • 4,348 Answers
The seal is not a 100% seal, but to access there are two types, one type the tub faucet screws on and the other style is retained by an allen set screw. if you have the set screw type, you will notice a slot on the underside of the faucet, at the tub wall end, look up in there. If you see an allen, loosen it and pull the faucet straight off. if no slot or allen, unscrew the entire faucet, counter clockwise (top to the left, for those digital clock people...).
Posted on Nov 15, 2010
We recently installed a Moen single handle faucet in a refinished shower after having a plumber replumb the front of our house. Handle appears to be properly installed. Now there is no hot water or even...
u need to adjust the scald protector all single handle units are shipped in cold position for safety reasons if have paper work for handle it explains how to adjust if not unscrew handle and remove on handle / valve stem will see a red and a blue plastic clips pull back clips and turn slightly and push back do this till desired hot and cold setting are to your liking replace handle and your done
Dec 17, 2010 | Moen & One Handle Tub & Shower Faucet
Delta shower faucet loses pressure when turned all the way on (hot water). What could cause this? When it first happened yesterday, a few tiny pieces of black plastic/rubber fell out of the bathtub...
Turn off the water to the home. You need tthe stem beneath the handle. Remove the handle after locating the set screw, remove the cylindrical beauty cover, and unthread the retaining nut to access the valve stem. Take it to a plumbing supply house or home store to make certain of the match.
Oct 06, 2010 | Delta & Single Handle Shower Faucet
Delta single lever faucet leakingafter bing shut off.
Will need to get delta faucet rebuild kit. Available at home depot, lowes or hardware store. It consists of valve stem seals & springs. The larger kit will contain ball assembly. Turn off water to faucet. Unscrew handle via set screw under plastic cap. Unthread cap over ball assembly. Pry out valve seals & springs. Reverse procedure to install.
Jun 26, 2010 | Delta & Single Handle Shower Faucet
I changed the stem on hot water because shower leaking- now no hot water from shower head when water turned back on- wont pass stem and some spreay from where stem is?
I am not sure what brand of shower valve you have but it sounds like you lost a peice of rubber or plastic in the valve and it has either lodged in the diverter or somwhere from the valve to the shower head. Is it posible that you got the wrong stem or switched stems or maybe it was put in backwards. Wish i could narrow it down for you,Need better info.
Dec 02, 2009 | Moen 87530 Touch Control Single Handle...
No hot water flow from faucet/shower
change the cartridge it is bad or defective.
Jul 20, 2009 | Delta & Single Handle Shower Faucet
Water comes out the shower head without the faucet lever being engaged
the whole faucet is bad it has an internal leak replace the whole thing
Jul 03, 2009 | Home
Low flow hot water in Delta Shower
If your water heater is old or has been recently replaced, it will slough off debris that will get caught in the hot water supply side of the faucet. You have to disassimble the faucet and use a dental pic to remove the debris from it. This is a real common occurance. You can also try to flush out that side by removing the parts and then slowly turning on the water without the parts inside. Be careful not to flood your bathroom when you do this. But usually you have to dig it out. I have spent as high as 3 hours digging the liner from the dip tube of a water heater out of a faucet.
Apr 05, 2009 | Delta & Single Handle Shower Faucet
Faucet kit
have you tried to change the washers in all the stem ends? this is what it sounds like,try beveled washers this may work.
Jan 26, 2009 | Danco Faucet Stem
There is a thin stream of water coming out from under the shower handle of my washer-type faucet whether the shower is on or off. What is the problem and how can I fix this please?
Turn off the water, remove the handle, escuchion, and stem.
Replace all washers/O-rings. If it is a plastic stem, replace the stem.
The seals are worn, allowing water to pass by.
On some really old valves, the actual metal walls of the valve eventually get worn, and washer replacement does not completely solve the problem, or last long. In that event, replacing the valve is about the only option.
Jan 19, 2009 | Moen 2919 Chateau Two Handle Tub and...
Moen Bath Tub Faucet
Hi varn4620,
I'm Harvey the Master Plumber.
Your question is: You had to replace the faucet in the tub due to a broken plastic piece in valve stem. Bought a Moen ripped the wall out and put new faucet in. Went good untill we turned the water on and the shower rained on us. Tightened everything you could find to tighten .Every time the water is turned on the shower rains. Can this be fixed or is the faucet broken?
Is this new faudet a single handle? If so I"ve had this experience also. Most of the time it's because the guts were not lined up properly at the factory. You may have to play with it a bit.
Turn off the water and take the handle off and remove the sleave, remove and rotate the guts. Try 90' at a time. Turn water on to try it. Useually one of the other 3 positions will be right. The correct position is there, but it may take time to find it.
Feel free contact me again!
Please give me a rating here at fixya before you sign off
Thank you,
Harvey your Master Plumber
Sep 14, 2008 | Moen 2919 Chateau Two Handle Tub and...
Banner Faucets Castille 600 Series Brushed Nickel Bathroom Faucet... Logo
127 people viewed this question
Top Banner Plumbing Experts
Mike
vince
Tom Chichester
Are you a Banner Plumbing Expert? Answer questions, earn points and help others
