Question about Cobra FRS 85 (14 Channels) 2-Way Radio
What's the rang on a cobra free 85 - Cobra FRS 85 (14 Channels) 2-Way Radio
    President:
  • 2,761 Answers
Any distance claims made by the manufacturer are pure fantasy. These are low-power UHF line-of-sight radios -- don't expect more than 1/4 mile effective range from them under most conditions.
Bill B.
Posted on Nov 15, 2010
Looking for owners manual
Cobra says the FRS 105 and 110 are much the same as the 85.
https://www.cobra.com/sites/default/files/manuals/FRS105_EngSpa.pdf
Feb 01, 2016 | Cobra Radio Communications
Can you expand the freq. range of the cobra 25 CB 40 channel radio
Yes its possible to do with the EXPO kits.. or an eeprom. but beware of the FCC rules please. RX purposes' only not to be used for Transmiting..
May 05, 2013 | Cobra 25 LTD 40-Channel CB Radio
Need adapter for charger where to order
I called Cobra and was able to receive a new adapter.
https://www.cobra.com/contact/
Mar 01, 2011 | Cobra FRS 85 (14 Channels) 2-Way Radio
Finals for a Cobra 85 Home Base CB and hom many?
Not familiar with the 35......If it is a ssb radio it will have a pre driver and a pair of finals. they are located on the right side towards the back or along the rear of the chassis to the right. You may have the type of circuit that has a protector diode piggy backed ..they could cause that tyoe of failure also, but in the years I have serviced radios they do not fail too often. I WOULD SUSPECT THE FINALS.
Jun 20, 2010 | Cobra 25 LTD 40-Channels Base CB Radio
Mic wiring for a cobra 85 base cb
Pin 1 is shield, thats the bare wire wrapped around the mic audio wire
pin 2 ic mic audio [usually white)
pin 3 is transmit or push to talk usually red
pin 4 is recieve or speaker complete usually black
Jan 08, 2009 | Cobra 25 LTD 40-Channels Base CB Radio
Cobra hl200
hl-200 belongs to srrs or short range radio service,the 6 mile range,it depend your location,it should be open range,no solid obstruction,or open sight..
Jan 14, 2008 | Radio Communications
Long range mode
For the Cobra PR4700WX:
The user's manual is available here
To turn on/off the long range mode - (If you are referring to low & high power); Press and hold the Hi•Low/Enter button for two seconds.
Alternately, if you are referring to the Light/Max Range (receive sensitivity), 3 options:
1. To briefly turn off auto squelch - Press the Light/Max Range button for less than five seconds. If you hear two beeps, you have turned the maximum range extender on.
2. To turn maximum range extender on - Press and hold the Light/Max Range button for at least five seconds until you hear
two beeps which indicates the maximum range extender is on.
3. To turn maximum range extender off - Press and release the Light/Max Range button or change channels.
Probable reason that "fishing was all right but for hunting there is to much static" is becasue these radios operate on line of sight principle. Anything that obstructs the linear view would reduce signal strength/range. There is not that much obstruction when fishing compared to that when hunting in the woods or rough uneven terrain.
Please note that when using Channels 1 through 7 and 15 through 22 on high power, the Hi icon will be visible on the display. When using those channels on low power and on Channels 8 through 14, the Low icon will be visible on the display.
For the Cobra PR3500DX:
The user's manual is available here.
The transmission message icon off when not in use - this icon will only display if the radio is receiving something or if your are pressing the PTT button.
The other three the transmission signal is on at all times - indicates that either you are transmitting (unlikely) or the radio is in constant receive mode (most likely). I would venture a guess that the Auto Squelch is switched "OFF" or Maximum Range is switched "ON"
Both the 4700 & 3500 has Power Saver and it is a built-in feature. Your radios have this unique circuit designed that extend battery life. If there are no transmissions for 10 seconds, the radio will automatically switch to Battery Save mode and the Power Saver icon will flash in the display. This will not affect the radio’s ability to receive incoming transmissions.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Nov 07, 2007 | Cobra 22 CHANNEL 2-WAY RADIOS
Cobra FRS 85 (14 Channels) 2-Way Radio Logo
100 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
