Question about Hotpoint Dryers
THE TIMER IS NOT ROTATING(I CAN MANUALLY ROTATE IT,BUT IT DOES NOT MOVE WHEN THE DRYER IS RUNNING). DRYER DOES NOT PRODUCE ENOUGH HEAT AND IT TAKES LOT OF TIME (4HRS)TO DRY THE LAUNDRY.
You need to buy a new timer and replace it. Be careful when replacing the timer as there are many electrical contacts in the back of the timer so when remove it, please label all the wires. Please follow the instruction from the manufacturer how to replace the timer. Of course, make sure you unplug the dryer because the dryer is powered by 220~240 VAC not 110~120 VAC.
As for the heater, there are two possibilities. The first one is, part of the heating element is open circuit and therefore, there is not enough heat to your clothing. The second possibility is, your timer contacts is broken, when the timer asks for high heat, the electricity supposes going to all the heating elements, but since the timer contacts are broken, you have only part of the heating elements working. The heating elements are quite easy to replace but please replace the timer first. You may fix both problems once you replaced the timer. WL
Posted on Nov 15, 2010
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya
www.fixya.com > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ...
www.shopyourway.com > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
Oscillator is not rotating
make this test and fix it. God bless you
Belt
Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt , and often the idler pulley, because the pulley tends to wear out at the same time. . If you hear the motor running but it does not tumble it is most likely the belt.
Motor
If the dryer motor only hums when you press the Start button, the motor may be burned out.
Remove the belt.
Check for obstructions in the blower fan housing.
Manually rotate the shaft of the motor. If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor
If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again.
If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor. Check our videos on testing a motor and capacitor.
Door switch
Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity. When Door is open no continuity when closed you should have a reading. If it's defective, you need to replace it.
Jul 30, 2013 | Dryers
I have a 16 amp Legrand electrical timer cat 037 30 on my hot water system. How do I program it?
Legrand 037 30 is vertical analog timer similar to hagar EH 010
Open following link for illustration how to set and wire timer.
http://waterheatertimer.org/images/EH-010-2-2-500.jpg
Hours of the day appear on timer dial as you rotate dial around.
Hagar timer you push segments left for ON times, and right for OFF times.
To set current time, manually rotate 24-hour timer dial until current time lines up with mark.
You can also move some of the segments to the right and leave rest of segments to the left.
Then manually rotate timer dial several rotations with thumb while listening to the hot water system turn on-and-off, or use tester to test power at terminals 3 and 4 or use tester at hot water system.
If timer has override lever, then move lever to each position and repeat test by rotating dial with each switch setting.
Jun 30, 2011 | Hardware & Accessories
How do you program the 15119 timer? I have the tabs "up" for the times that I want the timer off and it is not working. The switch is set to "timer on". It does work when in the...
I was looking at GE timers at Home Depot tonight.
Timer ON is correct setting.
Segments up should be lights off.
You lights turn ON with outlet on, so lamp, bulb and electricity are good.
Troubleshoot your timer:
What happens when you manually rotate the dial clockwise?
Do lights turn on and off at scheduled times?
Move override switch both directions and rotate dial manually with switch in each position.
Are the segments pulled all the way up?
If lights do not respond when dial is rotated manually, and segments are all the way up, then timer is broken.
If lights turn on-off with manual rotation, then check if clock motor is rotating dial.
If dial is not rotating, then timer is broken.
The way these timers work is this:
Timer clock with plastic gears rotates dial.
Dial rotates as time passes.
Plastic arm rides along outside edge of segments. See photo below.
When segment is pulled up, plastic arm clicks inward via spring action.
The moving arm opens electrical contacts that turn lights OFF.
If dial is not rotating, or the spring is worn out, or the plastic arm broken off, or the contacts fused together, or override wire is disconnected, then timer is broken.
I test these timers.
4-6% arrive defective, and most last 1 or 2 seasons and then they break.
But they are priced low and easily replaced.
geno_3245_190.jpg Plastic arm rides along segments
geno_3245_191.jpg Segments pulled up on GE 15207
Dec 16, 2010 | General Electric GE 24-Hour Timer, 2-Pin...
Dryer not providing any heat during cycle
Go to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ Check posts on "Heaters" in this forum will work you through your problem
Jun 26, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Timer doesn't move from any position. Heater doesn't active.
HI. this is a failed timer mechanism. replacing this failed timer control module will restore normal functions.
The timer is designed to rotate, via the timer motor. if this mechanism is defective or, not rotating this timer mech, this will render the timer useless. the timer has failed.
Jun 16, 2009 | Whirlpool LGR4600 Gas Dryer
WHIRLPOOL GAS DRYER MODEL LGQ9030PQ1 DRYER RUNS BUT NO HEAT
I would be suspect of the timer. Same thing happened to mine.
Rotate the timer manually a few degrees and see if the dryer operates properly. If so, replace the timer, a simple thing to do. Cost is about $75.00 and available from SearsPartsDirect.
Reply your findings and I will help you more.
Jan 23, 2009 | Whirlpool Dryers
Whirlpool Ultimate care ii Dryer wont tumble
If your dryer doesn't tumble, check these:
Belt,
Motor,
Door switch.
Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time.
If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:
Remove the belt,
Check for obstructions in the blower fan housing,
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor.
Go here to see a diagram for your model:
one of two types. "H" or "J"
http://www.repairclinic.com/0079.asp#DiagramH
Nov 09, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Mytag Dryer ModelLdg4000Aw
I have a Maytag Atlantis Gas Dryer that will turn on, rotate, but will not get hot and dry the clothes. A load of clothes in the afternoon, didn’t dry, tried again but didn’t dry – went to bed after putting on auto dry - next morning the dryer was still rotating and didn’t turn off. No hot air – only cold air.
Jul 13, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
DBXR453ET3WW Electric Dryer Won't shut off unless on timed cycle.
hi thanks for the question in the ge dryer theres 2 elements so if one is not working you only get half heat i would check the heater thanks the appliance doc
Jun 18, 2008 | GE DBXR463EBWW Electric Dryer
Dryers Logo
187 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
