Question about Kitchen Ranges
I am looking for a savannah mirage 2002 hot tub manual any suggestions on where to find it?
3 Suggested Answers
  • 37 Answers
SOURCE: savannah spas
probably a dirty filter!! take it out turn tub off to reset turn back on with filter out and c if nthis solves problem if so replace filter.
Posted on Dec 05, 2009
Danniboi
  • 1098 Answers
SOURCE: looking for a manual. 1997 Mitsubishi Mirage
Hi I found these, scroll down to the bottom of the page
Hope this helps, please click the link
Regards
Dan
http://shop.ebay.co.uk/?_from=R40&_trksid=p3984.m38.l1313&_nkw=1997+Mitsubishi+Mirage+manual&_sacat=See-All-Categories
Posted on Feb 14, 2010
Gear box to suit 1983 Mitsubishi Savannah
I would suggest having yours rebuilt.
Savannah Mitsubishi Cordia Rebuilt Transmissions ...
www.savannahusedautoparts.com/...transmissions/mitsubishi-cordia-trans... If you have transmission problems and you are looking for a high level company to replace ... 1983 Mitsubishi Cordia 3 Speed Automatic Transmission, FWD.
Savannah Mitsubishi PICK-UP Rebuilt Transmissions ...
www.savannahusedautoparts.com/...transmissions/mitsubishi-pick_up-tra... If you have transmission problems and you are looking for a high level company to replace your transmission, you are ... Mitsubishi PICK-UP Automatic Transmissions Online (Savannah, Georgia) ... 1989; 1988; 1987; 1986; 1985; 1984; 1983.
Pooler ~ Rincon ~ Savannah Transmission Repair
www.rincontransmission.com/ Rincon ~ Savannah transmission repair shop offering transmission repair and complete auto repair services for all of Effingham,Savannah,Pooler,Guyton ...
Dec 28, 2015 | Mitsubishi Cars & Trucks
Mirage tankless hot water heater showing message E2 and no hot water! I just bought it 2 months ago and can't find the owners manual. Amy suggestions?
I'd certainly first try the company's website. Companies often have FAQ sections, manuals available in PDF form, and even contact lists of repair personnel available by area. If nothing else, there should be an 800 number in their "contact us" section.
Aug 20, 2015 | Water Water Heaters
Hot tub error codes
I cannot find that error code but here is the manual for the information you have supplied. Hope this helps!
Jul 28, 2014 | Marquis Spas - Spa Cover - Mirage - Year:...
I have just bought a 2002 Mitsubishi mirage, it has over heating problems. I have changed the thermostat, gasket bleed the engine, but still over heating. Is there something I am overlooking, No ideas...
I would look for a clog in the system. Best suggestion is to install a flush kit and make sure water is able to pump throughout the entire system. If the Radiator is clogged you would need to have it serviced at the radiator shop. You can feel hoses along the way to determine if the fluid is flowing at various points of the system. Don't forget the heater core is part of the system as well. Look for collapsing hoses, spongy hoses and other signs that a hose may be misbehaving when hot.
Sep 24, 2013 | Cars & Trucks
3 handle shower - handles tap/ block each other
It sounds like you have the wrong handles for this faucet assembly. Did you recently purchase new handles?
Jan 17, 2013 | Price Pfister 01-81BC Savannah 3 Handle...
Savannah spas
Nov 20, 2009 | Qca Spas Jewel Series Topaz Plus Hot Tub
Looking the main vacuum supply for 2002 Mit Mirage 1.5
there should be a capped line on the intake manifold.on the same side that the cruise control actuator is mounted.
Mar 16, 2009 | 2002 Mitsubishi Mirage
Need a users manual
Kathy,
I think what you're looking at are the part numbers for the heater and control systems used in some Jacuzzi hot tubs rather than the Jacuzzi model number. I ran into the same issue and discovered through some cross-referencing on the web (jacuzzi parts suppliers) that this is the part number control unit made by Balboa. Odds are they were used in multiple Jacuzzi models.
My suggestion: Look here http://clearcreekspas.com/model_id.html to identify the control panel for your Jacuzzi and then follow the link to the correct manual. Some cover multiple models so you will need to know the electrical requirements of yours (120 V or 240 V?) and then check the layout of each tub shell to determine which model is yours.
I figured out mine is a Jacuzzi Essence Model 350 this way.
Nov 11, 2008 | Balboa Instruments Garden
Kitchen Ranges Logo
147 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
