Question about Lexmark X1150 All-In-One InkJet Printer
How can I install my printer if the installation has an error?
When I install my printer theres always came out an errors. Y does it so?
  • 48 Answers
Whats the error....?????
Posted on Jun 22, 2008
    Problem Solver:
  • 32 Answers
Without specify errors nothing to do.give the details
Posted on Jun 19, 2008
CP5225N WRONG FUSER INSTALLED ERROR
Was the replacement fuser 'new' or 'refurbished'? Try re-installing the fuser, that will usually correct the problem. If not, contact your vendor & see if they will exchange it. Always try to replace parts with Factory New. I don't work for or represent any brand, but in always tell my customers: Buy new Factory parts.
Mar 20, 2014 | HEWLETT-PACKARD Color LaserJet CP5225...
Printer showing error code 3802, says to go to kodak. com/go/aiosupport
I am new user of Kodak printer and i used to get error code 3802.
The main cause of the error 3802 is improper installation of printer driver. To get rid of this error you always ensure that properly install the printer driver.
I was looking for the solution and then found this using google. I found this link helpful.
http://printersupportsnumber.weebly.com/blog/kodak-printer-error-code-3802-its-cause-and-solution
Any other suggestions are welcome.
Thanks in advance.
Jan 20, 2012 | Office Equipment & Supplies
When i started to print it always gets errors ..always appears "cancel printing"..
Possible that there are errors in the software and so needs a reset. So remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command , can be an issue with ink drying , can
also be poor ink cartridge contacts
Apr 12, 2011 | Computers & Internet
Error Code 1102 on Lexmark P6350 Printer
Hi, it seems that it's a cartridge problem. That's the most probable reason why you're getting that error code. Try this out.
1. Remove cartridges.
2. Unplug printer from power outlet.
3. Then, plug printer back in power outlet after 10-15 seconds.
4. Reinsert cartridges.
If error still appears, redo steps 1, 2 and 3. Then, insert black cartridge first. If error appears, replace black cartridge. If not, insert color cartridge, if error appears, replace color cartridge. Hope this helps.
Mar 08, 2010 | Lexmark P6350 All-In-One InkJet Printer
CX8300 printer driver cant install
update your windows installer ... v3.1 and uninstall everything related to your printer e.g. drivers, any software, disable the unit in hardware devices (control panel) download the latest driver directly from Epson
May 07, 2009 | Epson Stylus CX8300 Printer
Acer Travelmate 4220-4124
sounds like your printer cd installation disc is damaged or corrupt try going to the printer manufacturers website and download you printer driver and software direct from there website
Feb 26, 2009 | Acer TravelMate 4200 Notebook
Unable to print documents, simply says 'printer error'
The printer always worked or never worked ?  Windows version? For a printer to work properly it must have the correct driver installed. One that matched the version of windows that you are using.
Download and install the correct driver:
http://downloads.lexmark.com/perl/downloads/downloads.cgi
Jan 17, 2009 | Lexmark X4270 All-In-One InkJet Printer
I get a message error that ink cartridge is not well installed
Remove all the cartridges then back again installed..if the orange light is always blinking.long press the cancel botton til the green light is steady..ok..
Jan 03, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Getting it ready for printing
Hi There,
There is no need to set the ribbon tight. This will be re-initialised each time the lid is closed or the printer boots from being switched on.
The error message and number is important. Depending on which driver you have installed, you may not see the error message on the status monitor. However you need to know what the error is, and most importantly, the error code (04:??).
To see what the error is follow these instructions;
Switch on the printer and let it try to initialise. When it errors and the Red LED is flashing,
Download and install the Magicard Support Utility (V3.14).
You can get this here;
http://www.ultramagicard.com/support/technical-support/?R=&L=&id=&lang=1&printerID=9&supportOption=3
Run the Magicard Support Utility. Select 'USB' for the comms port. When the other tabs open up, select 'Query Printer'. Click the 'Query' button. The left-hand pane will display the result of the query.
About a third of the way down is the 'Last Error Reported' line.
What is the last reported error (and crucially the error number)?
From this I should be able to tell you what to check.
Also, have a look at the following;
http://www.magicardonline.net
Enter your printer's serial number in the QuickSearch box.
You will see the printer's current warranty status as well as all the latest driver / firmware downloads and more.
Magicard will still offer you lots of support whether the printer is in or out of warranty.
With Best Regards,
MC.
Sep 05, 2008 | Magicard Avalon Duo Thermal Card Printer
Printing Error
plz try by reinstalling your printer drivers and resit your cartridge
Jun 30, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Lexmark X1150 All-In-One InkJet Printer Logo
19 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
