Question about Konica Minolta magicolor 2400 Laser Printer
Error light flashes ... Message: Open the printer cover and put Yellow Toner Cartridge. Action: Reinstall yellow cartridge; close cover Error light flashes ... Message: Open the printer cover and put Cyan Toner Cartridge. Action: Reinstall cyan cartridge; close cover. Then it starts over again with the Yellow Toner Cartridge ... to the Cyan Toner Cartridge ... back to the Yellow Toner Cartridge ... etc. I have tried cleaning the contacts on the cartridges and putting in new cartridges, I have turned everything off and rebooted, I have tried removing the cartridge and closing the cover and then reinstalling the cartridge ... no luck.
  • 1 more comment
  • connie15 Nov 16, 2010
    Unfortunately, nothing that you suggested worked:
    All toner cartridges are full ... the control panel is not indicating a toner cartridge is empty.
    Pressing the Rotate Toner key does not work ... it will not rotate from the toner cartridge it wants (switches between yellow and cyan).
    In the Status Display, all selections in the menu under "Printer" are grayed out and unavailable.
    When I close the printer top the printer begins to "warm up" then after about 3-5 seconds, it immediately lights up "error" ... does not indicate any toner cartridge by lighting up ... then I get the message(s) described in my original desdription.
  • connie15 Nov 17, 2010
    Yes ... I tried everything that I could. I hope you received my message to that effect. All cartridges are full, the panel is not indicating any cartridge as low/empty. The "Rotate" button will not operate ... when I get the error messages (for yellow and cyan) it is rotating to the color it wants, but replacing or reinstalling the cartridge does not change anything; the error message on the computer monitor just switches back and forth between the two colors.
    I have not tried the Mode Setting suggestion as all options under the "Printer" option on the menu bar are grayed out and unavailable.
    Windows XP Pro
    Guru:
  • 731 Answers
Hi Connie,
If you take out all the toners you will find a contact at the bottom where the chip from the cartridges touch , these three springs work loose.
If you notice them loose, you need to take the black clip out split it and solder them back on; that will sort the problem out.
CLICK HERE to download Service Manual for future reference (Its for MC 2300, works for 2400 series as well) Troubleshooting with service manual is on Owners risk.
Regards
Riztech
Posted on Nov 19, 2010
    President:
  • 1,961 Answers
Hi!
There are two ways to fix this problem
1. Clean any toner dust from the small microchip contact on each cartridge, (which I assumed was the first thing you did) you can use a cotton moistened with alcohol or an eraser to clean the contact surface.
2. Clean any toner dust from the 3 copper sensor contacts inside the printer where the contact of the cartridge is touching, check also if this is misaligned, manage to access inside the printer and remove this. If you take out all the toners you will find a contact at the bottom where the chip from the cartridges touch , these three springs work loose , so you need to take the black clip out split it and solder them back. Clean the dirt (much loose toner) that was floating around inside it, realigned the fragile little contacts and reassembled it. That will fix it. The only hardest part is disassembling it.
Hope that helps.
thank you for using Fixya
Alp
Posted on Nov 17, 2010
  • Konica Minolta Master
  • 7,733 Answers
1. Check the control panel to see which color of toner is empty. As an example, the procedure for replacing the cyan toner cartridge is described below. I f the Auto Toner Replace check box of Mode Setting in the Status Display was selected, printing stops when the toner is empty, and the empty toner cartridge moves so that it can be replaced. .
2. Press the Rotate Toner key. The lit indicator for the cyan toner goes off, and then the toner cartridge carousel rotates. When the cyan toner cartridge is positioned so that it can be replaced, the indicator for the cyan toner lights up again. Press the Rotate Toner key once to move the cyan toner cartridge so that it can be replaced. With each additional press of the Rotate Toner key, the black, yellow, then magenta toner cartridge moves so that they can be replaced. The indicator for the toner cartridge that was moved so that it can be replaced lights up.
Installation:
Pull the lever, and then open the top cover. If there is paper in the output tray, remove it, and then fold up the output tray before opening the top cover. Do not touch the transfer belt.
Error light flashes ... Message: Open the printer - q0904026-1.gif
2. Carefully pull out the drum cartridge.
Error
note.gif Dispose of the used drum cartridge according to your local regulations. Do not burn the drum cartridge.
3. Prepare thError light flashes ... Message: Open the printer - q0904026-3.giftridge. Do not touch the PC drum on the drum cartridge.
4. InstError light flashes ... Message: Open the printer - q0904026-5.gifum cartridge.
5. Carefully close the top cover.
The printer must complete a calibration cycle (less than 2 minutes) after the drum cartridge has been replaced. If you open a cover before the printer is reset, the calibration stops, then starts over again after the cover is closed.
Also try:
1. Double-click the magicolor 2400W Status Display icon in the System tray, ORgo to Start/Programs/KONICA MINOLTA magicolor 2400W Utilities and select KONICA MINOLTA magicolor 2400W Status.
2. In the resulting dialog box, select Printer from the menu bar, then select Mode Setting from the drop-down.
3. You will then be allowed to change the state of the Toner Empty Mode.
magicolor
1. Panel should say READY.
2. Press MENU/SELECT button.
3. Press Right arrow button until you see ENGINE.
4. Press MENU/SELECT button.
5. Press Right arrow button until you see TONER EMPTY.
6. Press MENU/SELECT button.
7. Press Right arrow button until you see the desired state for the action when toner is empty.
8. Press MENU/SELECT button.
9. Press Up arrow until you see READY.
Posted on Nov 16, 2010
  • 2 more comments
  • Doctor PC
    Doctor PC Nov 17, 2010
    Did you try the fix above?
  • Doctor PC
    Also what is your OS?
  • Doctor PC
    Doctor PC Nov 18, 2010
    Did you have the installation CD? Did you try re-install? I suggest you to re-install it, just because we going to know if the printer needs internal components service.I found the latest driver for your OS http://onyxftp.mykonicaminolta.com/Downl...
  • Doctor PC
    1. Power OFF the printer and manually remove all toners.
    a. Open the Top Cover.
    b. Insert the tip of a screwdriver (or similar tool) into the hole found just inside the opened printer on the lower front right hand corner. While pressing the tool in, manually rotate the toner carousel to get to each of the toners (to remove and reinstall or replace altogether, whichever is required).
    2. Power the printer back on and replace one at a time as asked for by the machine ensuring each cartridge is pushed all the way into the slot AND correct color toner is in correct color slot.
    3. Check each toner developer roll to see if it turns. The one that does not turn could be at fault.
    Note: If the printer made a loud buzzing type sound before the panel error occurred, replace possible hindering toner.
    4. After all toners are replaced perform a test print and check for proper operation of the printer.
    Also try this:
    To launch the Status Monitor:
    1. Click on Start => All Programs => Konicaminolta MC 2400 Utilities => Status. If the Status Monitor launches, look under "Printer Status" for the current status of the printer. If the Status Monitor does not launch, see the next step.
    2. Check to see that sharing is not enabled for the printer. Click on Start => Control Panel => Printers and Faxes. Right-click the icon for MC 2400W and select "sharing". Select "Do not share...". Click Apply and OK then repeat step 1. If the Status Monitor still does not launch go to step 3.
    3. On your keyboard, press the following three keys at the same time: CTRL, SHIFT and ESC. This will launch the Windows Task Manager. Click on the Processes tab and look for a process called MSTMON__S.exe. Highlight it, right-click and select "End Process". In Task Manager, click on File in the top Menu bar and select New Task (Run...). Then type in the "Open:" line, MSTMON__S.exe, and click OK. This should launch the Status Monitor.
Cartridges error on a lexmark
Error: "Invalid Toner Cartridge"; Error: "Invalid Refill"; Message: "Change Cartridge"
Solution
One of these error messages may appear on the printer display immediately after or shortly after a new toner cartridge is installed into the printer. Note: This may not be specifically a toner cartridge problem; the error may be due to a stuck cover open switch on the printer.
To see if the cover open switch is the cause of this problem, open the top front cover and observe the message on the printer's display panel. The display should read Close Door or Insert Cartridge.
If this message is not displayed, the top cover open sensor and switch will need to be replaced. In addition, the printer may have damaged the new toner cartridge. If the cover open sensor is not operating properly, a new cartridge can be incorrectly flagged as a refilled cartridge by the printer. If this happens, the new cartridge will continue to cause an Invalid Refill or Invalid Cartridge error even if you try reinstalling it or installing it into another printer. If this should occur, please contact the point of purchase of the cartridge to find out how to get the cartridge replaced.
Caution: If the cover open sensor is not operating, do not install another new toner cartridge until you have completed the directions below. Inserting another new cartridge can cause that cartridge to stop working as well. Should this situation arise, please take the following actions:
Place the original working cartridge (the empty or near-empty one) back into the printer. This should clear the error message.
Turn the printer off. Doing this will disengage the cover open sensor.
With the printer switched off, open the top lid and remove the old toner cartridge.
Now replace the old cartridge with another new Lexmark toner cartridge.
Power the printer back on. The printer should now read this cartridge as a newly installed toner cartridge and the error should be cleared. The printer and toner cartridge should function properly now, but the top cover sensor on the printer will still need to be replaced.
If your printer is still under warranty or covered under a service contract, please contact Lexmark Technical Support or your service provider for further recommendations and instructions. Until you can get the cover open switch replaced, remember to have the printer powered off whenever you replace the toner cartridge.
If the top cover switch appears to be working fine, or if you have followed the above steps and your printer continues to post an Invalid Toner Cartridge or Invalid Refill error, make sure you are using a new original Lexmark toner cartridge. A toner cartridge remanufactured or refilled by a third party can cause this error.
To help identify a refilled cartridge, look for the yellow label attached to the toner drum and the body of the toner cartridge. If this is damaged or removed, the cartridge may have been refilled.
If you are using a third-party refilled or remanufactured toner cartridge, it is recommended that you install a new Lexmark brand toner cartridge. Lexmark cannot guarantee the compatibility of any third-party toner cartridges with our printers.
OR
1 Switch on the Lexmark X83 printer.
2 Lift open the cartridge door at the front of the device, below the scanner unit. The printer automatically moves the cartridge carrier to the correct position.
3 Pull each ink cartridge toward you to unclasp it from the carrier. Lift the cartridge out of the cartridge carrier.
4 Clean the copper contacts on the bottom of each cartridge with a clean, dry lint-free cloth. Use a gentle, circular motion to clean the contacts.
5 Insert the ink cartridges back into the cartridge carrier. Push back firmly on each cartridge until it snaps into place.
6 Repeat each step in this procedure again. Close the cartridge door.
Oct 04, 2012 | Office Equipment & Supplies
Toner life end message with brand new toner cartridge.
1. Turn on the printer. 2. Push the button on the front of the printer to open the cartridge door. Do not remove the cartridges.
3. Push the Clear/Back button and hold till to bring up a reset menu. There are 8 different toner functions ( two Black, two Cyan , two Magenta, and two Yellow).
4. For each of these eight functions in turn, push the O.K. button and then push it again to indicate 'Reset'. After a few seconds, it will say 'Accepted' and will then display a message that the cover is open.
5. Repeat steps 3 and 4 for each of the 8 toner functions.
6. When finished, close the door and the status bar will be reset to normal with no error message.
Mar 12, 2011 | Brother MFC-9840CDW Laser Printer
Lexmark c534dn unsupported cartrige
This error message appears on the printer screen when the printer thinks the wrong toner cartridge is installed. To clear it or identify a service requirement, follow the steps below. NOTE: If you succeed in resolving the problem at any stage during the procedure, you not need to perform the remaining steps.
  1. Open the top front cover of the printer. If the display DOES NOT read Close cover or Insert cartridge, the 32 error is not caused by the toner cartridge and printer service will be required to fix the problem.
  2. Make sure the correct toner cartridge is installed for this printer model.
    1. Check Lexmark for a list of compatible cartridges for your printer.
    2. If the wrong toner cartridge is installed, remove it and install the correct one.
  3. If the correct toner cartridge is installed, it may not be seated correctly. To ensure that this is not the cause of the error, do the following:
    1. Turn off the printer.
    2. Reseat the toner cartridge.
    3. Close the lid.
    4. Power the printer back on and check the display.
  4. If reseating the toner cartridge does not clear the error message and the error started as soon as you installed this particular toner cartridge, the cartridge may be broken. You can check this as follows:
    1. Power off the printer and then reinstall the old cartridge. (You can also try a different new cartridge to see if that clears the error.)
    2. If the error does disappear, the problem may lie with this cartridge. Please contact the point of purchase, especially if the cartridge is brand new out of the box.
  5. If the error cannot be cleared by putting in a new toner cartridge or one that is known to be working, the printer may require service to fix the problem.
Feb 15, 2011 | Lexmark C534dn Laser Printer
Xerox DC12 Error code 9-355
Error code 9-355 indicates, the magenta toner dispenser is broken and in need of repair.
Open the Front Door
From left to right, the Toner Cartridge colors are Cyan, Magenta, Yellow, and Black.
As a pre-caution, place a few sheets of paper on the floor, under the Toner Cartridge area, to catch any toner that may spill.
Remove the Toner Cartridge by rotating the handle to the left until the handle is in the unlocked position.
Pull the cartridge completely out of the machine.
Check for any obvious damage in the cartridge or printer and reinstall. Replace cartridge if damaged.
If error message continues, call a qualified repairman.
I hope this helps you fix your printer.
Jan 28, 2011 | Office Equipment & Supplies
The printer is giving me service error E527 what can be done to overcome this error
Hi Good day!!!
This error message "Service Req E527" means that the toner carousel housing the toner cartridges is obstructed, or is unable to rotate correctly. It can be caused by installing a toner cartridge incorrectly.
Solution 1:Check that the toner cartridge at the front of the printer is installed correctly.
Solution 2: Manually remove all of the toner cartridges.
Close all the covers, and then power the printer off.Open Cover B, and then remove the photo conductor unit (PCU).Turn the toner carousel by hand to line up a toner cartridge with the front of the printer.Open Cover A.If the toner cartridge is not in position to remove it, close Cover A and repeat the steps above.Remove the toner cartridge, and then close Cover A.Repeat all the steps above until you have removed all four toner cartridges.Reinstall the PCU.Close all the covers, and then power on the printer.Open Cover A and Cover B.Check thoroughly for any jammed paper, foreign objects or damaged parts.If you can locate an obstruction, remove it. Then, close all the covers and restart the printer again. If you can identify any damaged parts, there is an obstruction you cannot remove, or there is no change after restarting the printer, then contact Epson for further advice.Reinstall the toner cartridges (Follow the prompts on the LCD display), and then test the printer.
Don't forget to vote thanks!!!
Nov 02, 2010 | Epson ACULASER CX11NF All-In-One Printer
54.15 error code
Error Code 54.XX
Control Panel Message: Printer Error
Description:
15 Yellow CPR sensor
Recommended Action: Turn the printer off and then on, and then check the following itmes
Check the connections. Replace the color-registration detection assembly.
Description: Printing cannot continue. There is a sensor malfunction.
XX Description
15 - Yellow toner remaining sensor (J1014 toner level sensor)
Jun 24, 2009 | HP LaserJet 4700 Printer
New yellow toner not fitting properly
try to install the cartridge again and see if it can print.or u can reinstall the printer drivers. if the problem still persists then visit below mentioned link for a free diagnosis.
http://tinyurl.com/m7ghqz
Jun 18, 2009 | Samsung CLP 300 Laser Printer
I just put in a yellow cartridge. Previously the printer was working just fine. Now it is showing an error code: 10.92.00 So I put the old yellow cartridge back in. The same error code now appears? He
Hi ron0911170:
This is your problem.
10.92.YY CARTRIDGES
NOT ENGAGED
alternates with
Open and close
front door.
The cartridges are not engaged,
poor primary transfer bias contacts,
defective high-voltage supply, or
control signal errors.
YY Description:
00 - Black print cartridge
01 - Cyan print cartridge
02 - Magenta print cartridge
03 - Yellow print cartridge
1. Open and close the front door to fully
engage the cartridges.
2. Reseat the print cartridges.
3. Check the printer primary transfer bias
contacts to the transfer unit. Clean if
dirty. If the contracts cannot be
cleaned or they are damaged, replace
the transfer unit.
4. Replace the high-voltage power supply
PCB.
5. Replace the DC controller PCB.
Hope this helps
May 24, 2009 | HP LaserJet 3600n Printer
ERRO
The following solution was found at;
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=446153&prodTypeId=18972&prodSeriesId=446153&objectID=c00314875#A9
Cut & pasted here it is;....
10.0003 Yellow cartridge e-label error Error message 10.0003 supply error alternates with Reinstall c00381084.jpg with a ? under the Yellow print cartridge gas gauge Description E-label cannot be read or print cartridge is not properly installed. Action
  1. Open the front cover of printer and remove the toner cartridge exhibiting error.
  2. Inspect the print cartridge to ensure the e-label reader is attached to print cartridge and is not damaged.
  3. Inspect the inside of printer to verify the e-label does not have any product packing tape still attached.
  4. Inspect the e-label reader to ensure the gold contact points are not damaged or bent. Also inspect the black plastic on e-label reader to ensure it is not bent or broken.
  5. Reinstall the print cartridge.
  6. Power cycle the device.
  7. If reinstalling the print cartridge does not resolve the issue, replace the print cartridge.
  8. If the problem continues, contact HP Customer Support Center for technical assistance at http://www.hp.com/support/clj2600n or see the flyer that came in the printer box for additional contact information.
Nov 28, 2008 | HP Color LaserJet 2600n Printer
Xerox phaser 7300 toner cartridge problems
Sometimes on this machine as there is a lot of loose toner around it can cover over the sensors in the machine, what I would advise is to remove all the toner cartridges and check for the copper contacts on both the machine and under the imagining unit (which the toner is placed in). Once you have cleaned that away slowly close the lid and reboot the machine and it should return to normal. Its just toner getting caught up in the sensors. Follow the instructions below, when you remove the unit, lift it over your head to find the copper contacts and clean them, be careful not to spill toner everywhere. Good luck!
Reseating the imaging unit
    Remove the toner cartridge:
  1. Open the top cover.
    caution_image88x30.gif The imaging units are sensitive to light. Do not expose the imaging units to light any longer than necessary to remove it and cover it. Failure to follow these instructions may damage the imaging units.
  2. Identify the color of the toner cartridge to be replaced (Cyan, Magenta, Yellow or Black).
  3. Move the orange lever on the toner cartridge to the right so that it unlocks.
  4. Lift on the back side of the toner cartridge first, then guide the cartridge out of the printer.
  5. Set the toner cartridge on paper to avoid any toner spilling.
    Reseat the imaging unit:
  6. Lift the imaging unit straight up out of the printer.
  7. Line up the guide pins with the printer's frame and lower the imaging unit back into the printer.
    Reinstall the toner cartridge:
  8. Install the toner cartridge by guiding the front onto the new imaging unit first then lowering the back.
  9. Move the orange lever on the toner cartridge to the left so it locks.
  10. Clean the LEDs with the supplied wipe.
  11. Close the top cover.
Sep 06, 2008 | Xerox Phaser 7300DN Laser Printer
Konica Minolta magicolor 2400 Laser Printer Logo
398 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
