Question about Garmin nuvi 765T GPS Receiver
My garmin nuvi 1490t and 765t both are very slow loading maps when viewing maps before navigating when you zoom out. I also have a garmin nuvi 265 and this one loads pretty fast the same map. I'm using the same map for all 3.
SOURCE: Garmin nuvi 250 mapsource
Thanks for the help. I managed to resolve the problem by installing the program on an external SD memory card.
Dave
Posted on Jan 29, 2008
  • 2920 Answers
SOURCE: Garmin Nuvi 360 Won't Load Maps
go buy a tom tom you dont havve to do any downloads to keep it up to date.garmin has to many issues
Posted on Aug 25, 2008
jonniewalker
  • 1031 Answers
SOURCE: how to load maps from google to garmin
This solution works for more than the 760. i think it will work for all 6xx and 7xx series.
a simple solution to convert Google maps to Garmin routes and is found here:
http://www.elsewhere.org/journal/gmaptogpx/
In essence, you create your route in Google maps and then click the recommended url bookmark.
Save the GPX file to the Garmin device and from "My Data" (under Tools) convert the file to a route. You are done.
hope this helps pls appreciate by rating as fixyaa thanks
Posted on Nov 23, 2008
bunnydawg
  • 5158 Answers
SOURCE: garmin nuvi 205 can't find satellites
you can get the manual at www.garmin.com
you'll also need to get yourself a usb cable... the normal end for the computer and i believe the other end is called a mini b connector.
Robert
please take a moment to rate this solution.. thanks
Posted on Feb 02, 2009
SOURCE: Garmin Nuvi 205 keeps saying no maps available ???
This is easy. You have to run your software, select the maps tap and then transfer maps to the device. Chances are good you uploaded a 2009 map on top of the 2008 map. The updater doesn't delete maps.
Your unl file only has one key, you have two maps loaded. Simple go into the garmin directory and delete the map file and the mapsupp file. You can easily find them because they are greater than 500 mb.
Then run mapinstall (google for the file). This will install your most current map to the Nuvi. You are back in business.
Posted on Apr 12, 2009
Update garmin nuvi 1490
Connect it to computer with Garmin Express installed.
Garmin: n?vi® 1490T Software Update Collection
www8.garmin.com > n?vi® 1490T
n?vi® 1490T Updates & Downloads. ... Updates & Downloads. n?vi® 1490T. Update Unit Software with Garmin Express. Use Garmin Express to keep your ...
Garmin: nuvi 1490TV (GCD File) Updates & Downloads
www8.garmin.com > On The Road > nuvi 1490TV (GCD File) nuvi 1490TV (GCD File) software version 6.20 ... Fixed an error that caused traffic provider information to update, whether or not it had previously updated to the ...
Maps & Map Updates ' Garmin ' Canada
www.garmin.com/en-CA/maps/updates/?/golf Update your maps to ensure you have the most accurate data available for your Garmin device.
Garmin Nuvi 1490 LMT (Lifetime Maps and Traffic Edition) - Review ...
? 13:05
https://www.youtube.com/watch?v=Yew6dtXelNk Jan 13, 2012 - Uploaded by elchino
Unboxing the Garmin Nuvi 1490 LMT. Purchased at FutureShop Canada for $199.99. Original price was $239 ...
Garmin nuvi 1490 - how to go past the computer update icon - YouTube
? 1:46
https://www.youtube.com/watch?v=r8ZQ2z2yZUU
Jul 12, 2015 - Uploaded by syalamarti
1. Connect the Garmin nuvi 1490 GPS device to charger - in the automobile or to a USB port on a computer. 2 ...
update garmin nuvi 1490 Google Search
Oct 01, 2017 | Garmin GPS
Nuvi 765T doesn't recognize preprogramed SD card City Navigator Europe NT
Did you get this working? You may only need to access the menu and choose Maps and select deselect the current maps and select the Europe CNNT maps to get them to display.
If you need additional help - leave a comment.
Oct 08, 2011 | Garmin NUVI 765T 4.4 in. GPS Receiver
Nuvi 1490T Australia Maps on a chip
City Navigator 2012 is available preloaded on micro sd card.
http://www.gpscity.com/garmin-microsd-australia-and-new-zealand-city-navigator-nt-2012.html
Sep 22, 2011 | Garmin nuvi 200W GPS Receiver
Hi, do you know if I can install City Select maps I bought for a previous Garmin device now out of order, on a new Garmin 1490T preloaded with City Navigator ? thanks
If you want to test the maps on your new Garmin you can do one of two things. Either you can copy the maps onto an SD card and then insert the card into your GPS. You can also connect the GPS to your computer with the USB cable that was supplied with you unit. Using whatever file manager you normally use with your version of Windows (Windows Explorer, Total Commander, etc), you will be able to see your Garmin GPS as another drive on your system. You can then copy your City Select maps over to your Garmin.
Once you have the maps either directly on your Garmin GPS or on a microSD card, you have to choose to use those maps. From the main screen of your GPS choose Tools>Settings>Map. If your City Select maps are compatible with your GPS they will show up in the list of maps. To make use of the map just choose it by touching the name of the map. Your Garmin will then load that map and display it. If your City Select maps do not show up in the list, or if you choose them and they do not load or give you an error then they are not compatible with your 1490T.
If you need anymore information or help please let me know. Thank you.
Mar 12, 2011 | Garmin nuvi 1490T GPS Receiver
Where can I purchase a Philippine Map on micro sd card for my Garmin 1490T?
Hi, You can buy it directly from garmin, the map is:-
City Navigator® Southeast Asia NT Or you could try ebay or a local GPS supplier in your area.
Please dont forget to vote this answer was helpful
Many thanks
Feb 14, 2011 | Garmin nuvi 1490T GPS Receiver
My nuvi 765 will not turn on. Any solutions? How do you reset it? Vista will not even recognize the Garmin in the USB port. I'll assume that it's because it can't communicate to the OS. :) It just shows...
Resetting the Garmin Nuvi 765T: Press and hold your thumb or finger in the lower right hand corner of the screen while powering the unit on. This will erase all USER data, base and detailed maps will remain intact.
Connect your Garmin Nuvi 765T to your computer via USB.
Download Garmin's Communicator plugin and WebUpdater, both applications can be downloaded from their site. By doing so, this will load the necessary USB drivers to your computer, allowing the Garmin Nuvi to communicate and update firmware and software via the plugin and WebUpdater.
On Vista, the Nuvi 765T appears as Garmin Nuvi without the "T" as well, (a blue triangular icon also appears) it does not affect the ability to transfer files or explore the device in any way. If you load an SD card into the Nuvi 765T, it will appear as a removeable disk and assign it a drive letter, in my case H:
Dec 11, 2009 | Garmin nuvi 765T GPS Receiver
When I start my garmin nuvi 765t. it will try to start but just before finishing loading the maps it shuts down and keeps trying to start until I turn it off. also my computer does not recognize it when I...
Download the Garmin Communicator Plugin and Web Updater software from Garmin's website - both tools are free and will load the proper USB drivers for your 765T.
Ensure that the battery is fully charged via the battery strength icon, prior to aquiring satellites.
To reset the 765T: Hold finger or thumb on lower right hand corner of screen while powering the unit on from the off position. This will erase all user data.
Nov 16, 2009 | Garmin nuvi 765T GPS Receiver
I bought Garmin nuvi 765T after having Viamichelin navigator in my car fo some years. . In the old GPS I could navigate to "city center" which was quite useful, when you travel and want to visit a place...
Check in the settings/setup options to enable all the POIs (Point of Interests) and then check if you can find the "city centers" If not then maybe the maps of this GPS device does not have this POI.
Aug 10, 2009 | Garmin GPS
My Garmin 765t stopped navigating
There should be a small reset switch on the back of most garmin gps units. with the unit on, depress the reset switch with a pen tip or small object until the unit shuts off and restarts. It may take a little longer to pick up the satellite but it will reque the unit and unlock the navigation screen.
Aug 01, 2009 | Garmin nuvi 765T GPS Receiver
Garmin nuvi 765T GPS Receiver Logo
339 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
