Question about GE Dishwashers
Leaking dishwasher (new)I am under Warranty - GE Dishwashers
    President:
  • 1,462 Answers
For a start, check the fill hose is properly connected
Posted on Jun 19, 2008
New haier dishwasher with f4 code. Means it's leaking but how to know from where ? Model hdbl865ats
new --still under warranty - get the technician out under warranty
any work you do voids the warranty
Dec 30, 2016 | Haier Dishwashers
LG dishwasher new model.. Ne error coming how to repair pls ask me
if it is new then it is under warranty and that means get a technician out under warranty to fix it
if you or any unauthorized person touches it , then the warranty is void
Jun 22, 2016 | LG Dishwashers
Leaking dishwasher
1-if it is brand new it should be under warranty 2-try changing soap brand, some suds up more than others and sneak past the seals 3- where is it leaking? (around the door, or underneath ie likely motor seal or plumbing) 4- check Plumbing connections 5-most "tubs" nowadays are one piece plastic, look it over carefully with a good flashlight. if you think you have found a crack remember where it is start the dishwasher and run it till it starts leaking and then open it and examine that spot-with the heat it may open up more or otherwise change
Apr 08, 2012 | Kenmore Dishwashers
Door is leaking at the bottom of the new dishwsher. Made sure it was level. Any other Suggestions
well if its new you should not touch it ,,the best thing to do is call for service because your under warranty,,there a 1-800 number on the inside lip when you open door..or check the back of your owners manual..if anyone srevices it it will void your warranty,,not worth it ....good luck
Sep 12, 2011 | Maytag Dishwasher
Door has loud squeek on one side at hinge area.
Call the manfacturer and tell them your problem give them make, model, and date of purchase They should be happy to help you.Esp.since it is still under warranty
Jan 08, 2010 | Electrolux EIDW6105GW 24 in. Built-in...
Leaks at the bottom of the door it is barnd new
you havent specified the place where its leaking ... is it from the bottom? ...since you say its brand new....... the best option for you would be to go back to th manufacturer.... for 2 reasons
a) you will void ur warranty if you open the unit
b) leaking is not a common thing among brand new dishwashers....
regards
iversh
Sep 27, 2009 | Maytag MDBH945AWW / MDBH945AWQ /...
Leaking Kenmore Elite at the right front of dishwasher
Sorry to hear of your plight. My advice is to ask for a new machine under the lemon law since they cannot get it fixed. You can also try calling Whirlpool who is the manufacturer but they are likely to tell you to work with Sears. They were out under warranty and it has not remained fixed so the warranty should carry through since you called for service while still in warranty. I feel for the tech because it is frustrating to have a problem that you cannot find a cure for be the tech should also have escalated it to the tech support line for resolution. (I was a Sears tech for 21 years)
Sep 14, 2009 | Kenmore 15129 Built-in Dishwasher
Leaking at the bottom of a GE dishwasher
If it's under a year old, it's under warranty, just call 1-800-GECARES and they'll send someone out to replace the door gasket. If it is over a year old, you need to replace the door gasket. There are small black lines that extend beneath the door into the body of the dishwasher that will be replaced when you install the new gasket. This will seal the door so that you no longer have anymore leaks.
Jul 11, 2009 | GE Dishwashers
Whirlpool DU1100XTPS dishwasher leaking from front door panel
Hi karen_kinzer,
I'm Harvey the Master Plumber.
The d/w was a recent purchase?
Then my advise to you is don't worry about it! The unit should be under warranty. It's time to make the call. Let the warranty repairman worry about it. If he can't fix it, he has the authority to condemn it and you'll get a new one. Anyway, this is one problem you should not have to worry about.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 13, 2008 | Dishwashers
How do I remove the back of my fisher-paykel dishwasher? The draining pipes have been kinked resulting in a back flow of water and now leaking. It is no longer under warranty.
I decided not to open the back of the dishwasher and just cut out the kinked pipes and rejoin them. I haven't used the dishwasher yet so I am unsure if this will fix the leaking problem.
Jun 24, 2008 | Dishwashers
Dishwashers Logo
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
