Question about Garmin nuvi 1300 Car GPS Receiver
When I turn on my device it reads No Map Data Available it is only 6 months since I have it and I've used it around 10 times.
  • Garmin Master
  • 587 Answers
Look at your system settings and make sure that the map has a checkmark in it to be use.....
not sure on your unit where that would be but my Nuvi is under .... Tools.... Settings....... Map...on bottom of page youwill see Map Info.....press it ..... is the map you want to use have a check in it?
If not put one there
Posted on Nov 15, 2010
Whip the ******
Posted on Mar 06, 2011
All of a sudden my garmin 3790LMT shows "no map data available" how to fix?
Is the SD card containing the map (and update) inside the Garmin device yet ?
Sep 16, 2016 | Garmin Nuvi 3790 LMT GPS
No map data availble
Your Garmin GPS has an internal memory or an SD-card that contains an "operating system" and "map data".The operating system is like windows or Mac OSX. It contains the menu and everything the GPS displays. The "map data" is a digital roadmap the GPS uses to calculate your route. If the map data was on a SD-card that was inserted in your GPS, it could me that you lost the SD-card. That could be the reason your GPS can't find the map data. Sometimes it happens that when people connect their GPS to a computer to update the "operating system" of the GPS something goes wrong. For example, when you disconnect your GPS from the computer while the update software is still writing data to your device, the connection gets lost and you're left with corrupt files on the GPS. It could also be a defect in the internal memory of the GPS. I suggest you try to update the operating system with a program called "Garmin Express" (just google and easy find it). You need to connect the GPS to your computer with a USB cable. Then you can perform an update. I hope it helps to solve your problem. What you could also try is to soft reset your GPS. To do that, you need to remove the silver or blue frame around the screen of the GPS (it pops off). Behind this border there is a reset button.
If the map data is completely gone, and you don't have a backup there is only one solution: Buy the latest map for your GPS online and download it to your GPS. It's expensive. In that case it's better to buy a new device in a shop. Most new devices contain Lifetime online map updates (model name nuvi -then the number - LM or LMT) (LM= Lifetime Mapupdates T= Traffic information) Then you can update your map data every three months if you want.
Nov 08, 2013 | Garmin StreetPilot C330 GPS Receiver
DTC code P109
It states 94 cadi and it is not OBD2 so the code is P109 and not P0109.
your information is incorrect.
P109 and p052 is internal to PCM ck sum issues, Possible due to battery connections loss of voltage.
Jun 22, 2012 | 1994 Cadillac Seville
My garmin nuvi 1300 says "no map data available".
This means is that the map file inside your Nuvi 350 is corrupted and the device can not read it anymore. We will need to update your map by plugging it into the computer. First thing you should know, with this problem that you are encountering most likely you will will need to send the unit back to Garmin to reload the map data onto the device, but I am going to try a few things with you to try to get it functioning again ok?
First thing to try is go to this webpage: Garman Map Updater, click on the "Check for updates" It will bring you to a new page, where you might need to install a plug in. It is okay to install the plug in and is nessesary.
If a map update is found you should be able to follow the instructions to update your map. Next I would like you to download "webUpdater" which updates the actual software on your device.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Nov 06, 2011 | Garmin nuvi 1300 Car GPS Receiver
I turn on my gps and it says no map data available unable to use device
There are 2 possibilities; Either the map has become unselected, which is most likely,or the map is locked. You can find solutions to both these problems at http://www.fixya.com/support/r6197735-no_detailed_maps_found_support_routing
There may be more information there than you need so to find how to select an unselected map go to paragraph 5. To unlock your map start at paragraph 2.
May 21, 2011 | Garmin nuvi 255W GPS Receiver
When turning on garmin, the display reads NO Data Available in any of the icons. I 've tried recalibraing and nothing shows up. No maps available.
You need to contact Garmin Customer Support:
North America - Consumer Products
Monday - Thursday: 8 AM - 6 PM, Friday 8 AM - 5 PM Central Time (closed holidays)
US: 913-397-8200
US Toll Free: 1-800-800-1020
Canada: 1-866-429-9296
Feb 07, 2010 | Garmin Nuvi 660 GPS Receiver
"No Map Data Available" - Garmin Nuvi 350
This is because your map file has either been deleted or corrupted and needs to be replaced. Please see this link for more info. Too much info to copy & paste here:
http://www.sharc.net/nuvi_lost_map.htm
- Jim
Dec 12, 2008 | Garmin Nuvi 350 Car GPS Receiver
No data available mess
Did you try to perform a map upgrade to 2008? Turn on the Garmin and from the main menu touch the wrench, then press Map, then look for Map info.
Jul 12, 2008 | Garmin nuvi 200W GPS Receiver
Not seeming to read SD map Data Card anymore
I have seen this before, if you turn off the unit while its saving data such as your last position or your last destination, especially if you shut it down while its still navigating. the card data can get corrupted. the only way to fix this is to reload the map data. Fine Digital is out of business so I created a DVD that has the last issue of map data and firmware for these units. you can find this dvd on ebay by searching for finedrive dvd. its way cheaper than what fine digital used to sell upgrade dvds for ( $150)
May 02, 2008 | Fine Digital FineDrive 400 GPS Receiver
Garmin nuvi 1300 Car GPS Receiver Logo
730 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
