Posted on Nov 15, 2010
From the IBM 6262 printer manual what do the following messages mean? Carriage check Status 0150 Thermal check Status 0410 Machine check Status 1295 Power check Status 0467
1helpful
WHTS CR SCALE OF FLEX MACHINE
The reasons why a flex machine carriage stops moving during printing can vary, and the specific movement error message will depend on the make and model of the machine. However, here are some common causes and potential explanations for a carriage movement error:
1. Obstruction or jam: If there is an obstruction or a paper jam within the printer's path, it can prevent the carriage from moving smoothly. This can trigger a movement error, indicating that the carriage movement is obstructed or impeded.
2. Mechanical issue: There might be a mechanical problem within the printer, such as a malfunctioning carriage motor, a broken belt, or misalignment of the carriage assembly. These issues can cause the carriage movement to halt and trigger a corresponding error message.
3. Sensor malfunction: Modern printers often have various sensors that monitor the movement and position of the carriage. If one of these sensors malfunctions or fails to detect the proper movement, it can trigger a movement error.
4. Connectivity or communication problem: The printer relies on a proper connection and communication between the computer or the print server and the printer itself. If there is a connectivity issue or a breakdown in communication, it can result in a movement error and cause the carriage to stop moving during printing.
5. Software or firmware issue: In some cases, a software or firmware glitch can disrupt the normal operation of the printer, including the movement of the carriage. An outdated or corrupted printer driver or firmware can lead to movement errors.
To troubleshoot the issue and determine the specific cause, you can try the following steps:
1. Check for any visible obstructions or paper jams within the printer's path. Clear any blockages if found.
2. Power off the printer, wait for a few seconds, and then power it back on. This can sometimes reset the printer and resolve temporary errors.
3. Ensure that the printer's firmware and printer drivers are up to date. Visit the manufacturer's website to download the latest updates if available.
4. Check the connectivity between the printer and the computer or print server. Ensure that the cables are securely connected and try printing from a different device or port if possible.
5. Consult the printer's user manual or contact the manufacturer's support for specific troubleshooting steps related to your printer model. They can provide guidance on addressing movement errors and resolving carriage-related issues.
If the problem persists despite these troubleshooting attempts, it is recommended to reach out to the manufacturer's support or consult a professional printer technician for further assistance.
Printer not printing first 3 left characters
There are 2 kinds of 6262 that have vastly different hammer asm, but most likely you have a hammer issue. If it is a 12 or 14 you would need
IBM 5665720 HAMMER COIL 6262 Refurbished
It can also be a cable or card, but those normally have errors reported.
PS I don't know why the wrong pick is coming up for that part on fixya, but the site has no pic as the part is super old.
2answers
I am using Epson TM T81 thermal printer and it is showing status USER INTERVENTION REQUIRED , printer is not printing document. I uninstall drivers and install it again it works but whenever I restart the...
Sir/Madam
i suggest You download Epson Printer Driver From official Epson Printer Website and Perform Below Following Step Mention On Epson website on Below, i hope You Fix Your Epson Printer problem,
1. About this software This package includes the following two software programs to use with an EPSON TM-T81 printer. 1) Windows Printer Driver This driver is a Windows Printer Driver for the TM-T81 printer. This driver makes it possible to print from a Windows application.
2) StatusAPI StatusAPI is a program that works in conjunction with the TM-T81 printer driver. It offers an Application Program Interface for obtaining the printer status whether or not the printer is printing. This API makes integrating printer status handling functions with applications more simple. For detailed information, please see each reference manual. The driver operation has been verified with the following operating systems. Windows 7 Ultimate SP1 32/64bit Windows Vista Ultimate SP2 Simplified Chinese 32/64bit Windows XP Professional SP3 Simplified Chinese 32bit Windows Server 2008 R2 Enterprise SP1 64bit Windows Server 2008 Standard/DataCenter SP2 Simplified Chinese 32bit Windows Server 2008 Standard SP2 Simplified Chinese 64bit Windows Server 2003 R2 Enterprise SP2 Simplified Chinese 32bit Windows Server 2003 R2 Standard SP2 Simplified Chinese 64bit Windows XP Embedded 32bit SP2 Windows Embedded Standerd 2009 32bit Windows Embedded POSReady 2009 32bit This driver is not supported by Windows 95/98/NT/2000 and Windows XP 64bit. EPSON IM series PC or IBM compatible PC Supported Printers EPSON TM-T81 The printer driver operates regardless of the pritner firmware version. 2. Supplied Files APD_415bSC_T81.zip : Printer Driver,StatusAPI installer with manuals Refer to the installation manual APD4_T81_Install_SC_RevE.pdf. 3. Remarks - For detailed information, please read each manual that is created by the installation. -When an error message is displayed during installation, the following procedure may enable to recover from the error. 1) Specify the uninstall option, and execute the installer "APD_415bSC_T81.exe /uninstall". 2) Remove the error factor.
3) Execute the installer "APD_415bSC_T81.exe". -Characters may not be printed correctly when using Easy Print of Windows Server 2008. For detailed information of this problem arising from the operating system, see the following web page provided by Microsoft Corporation.download epson biz com
Or If You Still Need Epson Printer Help Then Follow Us On:
Epson Printer Support
I want to change black ink cartridge in Epson Printer TX110
If ink level reach ink out level, follow How to.. on Epson status monitor. But, if it's not, turn off printer. Unlock carriage lock, then move carriage by hand. Or you can turn on printer and unplug power while carriage moving. Then move by hand freely.
You should be able to follow the bottom link and find it or you can check this answer .
tech.epson.com.au/downloads/message.asp
Hope that helped..
Started with paper jam and then after that. Error message. Carriage Jam, print carriage access door. Clear and press ok. can't figure out what this means
If you are getting a 'carriage jam' error as soon as you turn on your printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Follow the steps for fix HP Printer Carriage Jam
  • Turn off the printer and open it to see where the paper is stuck.
  • Manually move the carriage toward the opposite side.
  • Check the paper path and remove any piece of paper or any other object that is stuck in the path.
  • Reconnect the power cord and turn on the printer.
http://www.fixya.com/support/t5821600-carriage_jam_open_door_clear
3answers
My IBM 4230 printer has a 056 error does any one know what that error is and how to fix it
MACHINE CHECK X Y Z. SEE USERS GUIDE. A firmware error has occurred.
Here is a solution:
1. Turn off the printer.
2. Wait 10 seconds, then turn on the printer.
3. If the printer displays this status code again, call for
service.
sorry if this doesnt work you have to take it in for service...
Hi, All our channel switch is broken, so
Try resetting up the printer whilst attached to that machine and reinstall the printer driver.
How do I change the Ink cartridge in a Epsom DX 7450
Activate epson status monitor, if ink reach ink out, the message will appear. Then follow "How to..." Manually, turn on printer, and unplug power while carriage moving. Then move carriage by hand to replacement position. Replace ink tank, turn on printer.
5helpful
How do I change cartridge for Epson Stylus nx300
If ink out message appear in status monitor, follow "How to..". Or Turn on printer, imediatelly unplug power while carriage moving. Then move carriage by hand to replacement position. Turn on printer.
2answers
Problems with text messaging
Probably configuration problem. Make sure the center number is the one used by your service provider and set Reply via same center number to No.
Top IBM Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
