We have old 'inherited' Ferroli Combi Boiler ( 15 years old) the original clock has been replaced has the following: Auto ( with slide to on /off ) Auto(also with slide' has a clock;'one and 'P' the other Assume one is time other programme Below that is a digital readout of time Then 3 buttons: one with a 'P' below One with a + below One with a - below At right hadn side there is an @override This marked with arrow facing both ways then the right hand end with an arrow onit Can you advise how to set a simple ' time to come on in the morning 7.00am And go off at 5.00pm Clearly it has options for 7 days of setting but we are not bothered about that Any help you can giv eis very much appreciated
  • 625 Answers
SOURCE: glow worm combi boiler
check the pilot line for an obstruction. check the millivolt generator that's supposed to keep the pilot valve open. check for a high limit control being bad.
Posted on Dec 27, 2007
  • 333 Answers
SOURCE: require room thermostat for ferroli combi boiler
almost any thermostat you install will have the 2 wires that you are looking at It depends on how in depth you want to get with your thermostat. Home depot will have what you need. I hope this helps. Don't forget to rate my answer.
Posted on Feb 18, 2009
SOURCE: my boiler keeps firing up
I had the same problem. I traced it to the micro switch in the water/central heating motorised valve having shorted out.
I replaced the (Honeywell) motorised valve and it is now only running when it should.
Posted on Apr 23, 2009
SOURCE: I have a Honeywell ST499A/ST699B
I have an old Honeywell ST499A/ST699B thermostat. It still works OK but when we have a power cut I have to re-programme everything. Presumably this is because the battery needs replacing. I cannot find a way of opening the control box to get into the unit to replace the battery and in any case I’m not sure if the battery is renewable?
Posted on Dec 28, 2009
  • 3182 Answers
SOURCE: my worcester 240 combi boiler. when heating goes
check the water pressure on the combi could be low or in the back of your manuel there is a fault finding guide which is very good and simple to follow .
Posted on Oct 02, 2010
Ferroli boiler optimax he 38 c.Powers up ok,no hot water,no error code.Think its an ignition problem.Heating flame not showing?????
Is there an error code? If not the flow sensor for the hot water could be faulty. Also if you've had a power cut depending which model of Optimax HE you have, you sometimes have to tell the boiler it's a Combi, as they have a generic Pcb fitted which is also used on the system only boilers.
Sep 26, 2013 | HQRP Universal A/C Remote Control...
Ferroli boiler 31 che will not light up when hot water switched on notice in windowe says no ca or no co
are you getting no ca or no co on the time clock? if so change the time clock
May 16, 2010 | Heating & Cooling
Fault code ( nocn ) on a ferroli boiler
if nocn is on the time clock then check the wiring to time clock and if all good then it is the time clock at fault and will need repleacing
Apr 25, 2010 | Heating & Cooling
Central Heating\which combi boiler?
HI right first i would look at a worcester greenstar combl
best you can get and you have full back up from worcester leave all rads with stats as they are i think you will have to remove one , the that would be the bath room also the greenstar comes with a clock bulit in these are on the worcester bosch web site i have been a gas fitter fot 30 years and this what i would go with a really good combi, you can also get awire less room thermostat for this hope this helps
Feb 01, 2010 | Desa International CBN30T Central Heating...
Vaillant 831 combi boiler timer help
check to see the time clock is set with the clock symbol. there are three settings on analog clocks I , O and clock the I setting is constant running, the O setting is off and the clock setting is timer.
also try setting the thermostat up higher to see if the boiler fires.
Mar 25, 2009 | Water Heaters
I have a twenty year old worcester combi boiler with pilot light failure. It relights following instructions and is fine for a week or so then problem arises again, only this time it won't relight at all....
If you are lucky it may just be a worn out thermocouple or maybe a choked pilot jet or the gas valve may have gone faulty and require replacement, if you haven't had the boiler serviced on a regular yearly basis then a service will be required and any other worn parts replaced,fans,pressure switch, thermistors and safety stats are all parts that wear out after a few years, your oher option would be to replace your boiler with a new high efficiency boiler without a pilot, cheaper to run and better for the planet.
Mar 01, 2009 | Combi Centre DX - Mango
Require room thermostat for ferroli combi boiler optimax 25c . I have a honeywell at the moment which stopped working. it has two wires coming into it from the boiler
Get a Ferroli wireless programmable room stat. City plumbing supplies can get hold of them but you'd be looking at approx £130. Part number 30800009. No wiring involved, the receiver connects to the boiler pcb. Had same problem but now fine.
Feb 18, 2009 | Honeywell Programmable Thermostat Heater
My Worcester Bosch 35cdi boiler is flashing temp then backwards t forwards t, whats wrong with it.?
35 cdi worcester combi about 3 years old,heating not working,hot water works fine.It's been serviced not long ago.Room stat turned up and trv's ,but boiler want fire up,there's power to the boiler and the room stat the built in time clock is switched to on, but still nothing. do you think it could be the diverter valve, when i got there it was flashing SE which mean's it needs a service,cleaned the heat exchanger and burner with the proper worceter brush etc then re set boiler with technical, they also said it could be the built in clock and told me to disconect it, and just use the heating stat to control it.It still want fire.
Sep 03, 2008 | Heating & Cooling
Heating & Cooling Logo
56 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
