Question about Craftsman Tools & Hardware - Others
The electric motor for my Craftsman table saw stopped. The switch tested out good. Brushes are still in good shape. There is no reset button. It stopped momentarily, then ran again, but would not respond to the next on-off cycle. It was not under excessive loading, just cutting simple 5/8 plywood. The motor was not overheated. Model No. 315.218050. email floyd.pederson@gmail.com
  • Floyd Pederson Nov 15, 2010
    I will rely on your "Good luck" wish and test for continuity. Thanks for your input.
  • 43,501 Answers
Before removing the motor I would check for sure that you are getting power to the motor...if so then the motor is gone...there could be an internal overload that went out on it....
Check your yellow pages for a motor repair shop, many times they can fix the motor for a few bucks and they will give you an estimate before you okay the repair.
heatman101
Posted on Nov 16, 2010
    President:
  • Craftsman Master
  • 1,388 Answers
Sometimes these motors can break/burn a wire internally. Easy to test however if you have meter. Before the test, remove the brushes and take a look at the surface that contacts the armature. It should be smooth and shiny. If burned or scratched, there may be debris preventing the brushes/brush from properly contacting the armature. If they look ok, then on with the test. With brushes removed and unplugged from wall socket find white wire at the on/off switch. Test for continuity between white wire and both of the brush sockets (brass part of socket). Only one brush socket will have continuity. Once found mark that side white. If no continuity on either, then broken wire inside of motor (white lead goes thru winding). If continuity on white wire, now same for black wire and mark that side black. If no continuity on black wire, then broken inside of motor. If continuity on both wires then suspect switch or cord from switch to end of male plug. I know that you already know how to test that part. Good luck
Posted on Nov 15, 2010
Craftsman model 137.415030 10 in portable table saw won't turn on. It is getting power the switch sounds like it is working ok but it won't turn on. The reset button ,does not appear to do anything.
My table saw motor just stopped.. What do I do? - The WoodenBoat ...
forum.woodenboat.com/showthread.php?...table-saw...I...
WoodenBoat
Apr 6, 2013 - 23 posts - ‎20 authors
Does the motor have an internal thermal cutoff switch? ... Auto reset on a table saw, now that would be scary. ... A Craftsman, I think. ... The saw is a Grizzly 1022Z contractor-style saw about 10 years old. .... After the motor cools down the switchneeds to be pressed to restart the motor, it won't start suddenly ...
My table saw stopped, the reset button won't reset. What ...
www.shopyourway.com > Manage My Life > Questions
It is a Craftsman Table Saw Model 137.248880. ... I pressed the reset button and the saw restarted. I continued ... My table saw stopped, the reset button won't reset. ... One was just the switch the other the rocker switch, identical except in cost.
Craftsman 10 table saw motor stalled - Yesterday's Tractors
www.yesterdaystractors.com > Discussion Forums > Tool Talk
Dec 25, 2015 | Craftsman 21802 10-inch 13-amp Portable...
I have a $120 10"
It's possible that the brushes may have worn out or a bad connection may have developed in them or at the brush holders. Open the motor, check the brushes and look for any overheating. One of the windings may have gone open circuit in the armature of the motor and in this case it probably isn't worth repairing.
Mar 11, 2011 | Ace Hardware Ace; Table Saw with Stand
I have a Craftsman 10" table saw, probably at least 50 years old. The motor is dying, model number 113-12070. Where can I get this motor repaired or replaced?
I would go to the nearest electrical company and they will match it up for you.(yellow pages. Probably a ? to ½ hp, so should be reasonable for pricing. You could have it rewound, but would near the same price for new motor. good luck
Sep 25, 2010 | Craftsman 10" Table Saw
My very old Craftsman 10" Table Saw does not power on. While rip cutting some plywood, I errored and caused the blade to bind. Before I was able to power off the saw, the motor stopped. I thought I had...
Go to searspartsdirect.com and put in your model number. Look at the motor and wiring section. Look at item 16. The motor overload protector. (probably your reset button) WIth saw unplugged, unwire one sid of this switch and test with an ohm meter. You should read through the switch. If it is open then that's why the saw doesn't work. Many of this type of oveload requires quite a push to reset as you're flexing a klixon disc back to make contact. If is open and you can't reset, it's available there although a bit high priced.
Aug 13, 2010 | Craftsman 10" Table Saw
Craftsman 10' table saw model # 137.248830 will not start
Reset button on the motor, push till it clicks. How about the breaker? What kind of switch is it? Is it plugged in? Check this stuff out. Hope it helps.
May 09, 2010 | Craftsman Saws
Saw stopped working mid-cut as if power loss. Blade turns freely, was no unusual odor. Reset button no help. No problems prior to that event. This is a Craftsman 10" table saw.
Could be the motor burned out. That shouln't happen and if it did craftsman is really good at replacing damaged tools. I'd return it for a replacement.
Mar 04, 2010 | Craftsman 10" Table Saw
I have an older craftsman radial arm saw, model 113-19770. It will not start. main power switch is fine, power to the motor. how do I determine if it is the overload switch?  I have the housing off...
First check brushes if it has brushes. Sometimes the springs also "soften" so brush does not press on commutator.
Usually they have a rest button for the overload. They can take a good strong press to reset. You can use an ohmmeter to check continuity of the overload.
Sep 16, 2009 | Craftsman Saws
Saw will not run
I had the same problem several months ago with a craftsman (shut down during a long rip), and the reset switch had tripped but did not actually pop out. I tested everything in the line between the power supply and the motor, and found out that the reset switch was not conducting. I was able to reset it manually before re-installing it into the saw, and it's been fine ever since. I'd test that before you start pulling the motor out, it would be a much easier fix if the switch was just sticking.
Apr 13, 2009 | Craftsman 10" Table Saw
Tools & Hardware - Others Logo
141 people viewed this question
Top Craftsman Tools & Hardware - Others Experts
Dusty Ryan
Level 1 Expert
Mike
John Trevino
Are you a Craftsman Tool and Hardware - Other Expert? Answer questions, earn points and help others
