Question about AmcorAire UCHW-H24AF2 Split System Air Conditioner
AMCOR UCHW-H24CF2 Problem. Inside unit: in clean environment. Trying to maintain 74 deg F. inside of workspace. Outside unit: in dirty/dusty salt mine environment in deep salt mine (1/2 mile underground). Outside temp. in mine is mid 80's deg F this time of year. Mid summer it runs about mid 90's. Problem: Error message E4. Vacuum cleaned coils on outside unit. Followed manual on startup. Set temp to 72 deg F and unit ran approx 20 to 25 minutes. Stopped again with same error message. Air from inside unit was initially cool but not cold. Never got cold even though temp in workspace was mid 80's. What do you suspect is the problem with the outside unit? Thanks.
  • 73 Answers
The E-4 message indicates low on refrigerant (R-410A type) You will need guage hose adapters sold by Ritchie/Yellow Jacket # 19173
Pridiom Group 201-266-8234 option2
Support@Pridiom.com
Posted on Jan 04, 2011
Conditioner Fan
this a split system? inside and outside unit? possible relay( if it has one) or contactor. make sure 230 volts at contactor.
Feb 19, 2014 | AmcorAire UCHW-H24AF2 Split System Air...
I have two Amcor AmcorAire UCHW-H12AF2 Split System Air Conditioner units -- 2 years old. One works fine, but the other does not blow heated air (Heat Mode). It is cold outside, but the good unit is...
your unit may be have possible leak on piping then refrigerant exit or had leakage of refigerant try to locate leak then braze it then recharge a correct amoun of refrigeran. if you use heater try to check heating element if ok by supplying voltage or used ommeter to test continuity.
Feb 03, 2011 | AmcorAire UCHW-H12AF2 Split System Air...
Unit not turning on after unit was shut off and turned back on before the 3 minute time
Shut off the circuit breaker that feeds the outdoor unit for 4 hours, remove the batteries from the remote, use a paperclip inside the hole marked "rst" behind where the batteries sit.
Pridiom Group 201-266-8234 option 2
Support@Pridiom.com
We stock a complete line of Amcor Parts
Oct 30, 2010 | AmcorAire UCHW-H24AF2 Split System Air...
I have an F1 error code. The manual states that this means the inside and outside units are not communicating. What should I look for
F-1-No communicationbetween indoor and outdoor. Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
Sep 09, 2010 | AmcorAire UCHW-H12AF2 Split System Air...
AMCOR 24,000 BTU split system. Worked fine two years, then today it had no power. Checked circuit breaker, it had popped. Reset CB and went to inside unit - would not turn on or off with remote or hard...
I had this same problem. I disconnected the thermostat wire out side at the condenser and reconnected it and it started working. A couple days later it blew the breaker again this time I found the bus where the L1, L2. GR wire connect at the condenser had melted. I wire nutted all 3 wires instead of the using the bus everything is working right again. Hope this helps.
Tim
Aug 09, 2010 | AmcorAire UCHW-H24AF2 Split System Air...
Hello unit has been running then just stop with F1 showing how can i fix this thanks cameron
The F - 1 error code shows a failure of the PFC & IPM circuit boards inside the outdoor unit.
We stock a complete line of Amcor parts.
Support@Pridiom.com
Aug 03, 2010 | AmcorAire UCHW-H12AF2 Split System Air...
We have: AmcorAire Duo Ductless Split Air Conditioner 24,000 BTU Cooling & Heating UCHW-H24CF2 by Pridiom. The tech says the compressor is shot, but Pridiom (who bought AmcorAire or what Amcor...
Amcoraire Closed their doors Aug/Sept 2009. Pridiom Group started operations October 2009, Pridiom purchased Amcor parts/equipment at bank sale. ANYTHING PRIDIOM SELL'S, PRIDIOM WARRANTS to be free of defects parts 3 years/5 years compressor. It is that simple.
Support@Pridiom.com
Jun 24, 2010 | AmcorAire UCHW-H24AF2 Split System Air...
My Fedders model AEJ12E7AG ices up. This is a combo AC/Heating window unit. The heat works fine. Has it leaked out the freon or is there a circulation proble? Is it repairable?
The most common cause of icing in these category of units is a dirty air filter or partiallly dirty condensing or evaporator coil. If the unit is over 5 years old or has been operating in a dusty environment or hasn't had much service, then also check the blower for dirty blades.
The evaporator coil is on the inside and has the filter in front of it. The condenser coil is on the outside and has no filter. It too requires periodic cleaning.
The unit will need to be partially disassembled and the coils cleaned with a stiff brush to remove any build up if they are dirty. That goes for the blower fan too. Look through the side of the casing through the vent louvers to inspect the outdoor coil. Be careful not to bend fins on the coil if possible if the coil(s) need cleaning.
Jan 07, 2010 | Heating & Cooling
AmcorAire  UCHW-H24AF2 Split System Air Conditioner Logo
178 people viewed this question
Top Amcor Heating & Cooling Experts
AJMAL KHAN
Michael Youngman
Michael Youngman
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
