Question about Mitsubishi P-93W Printer
Mitsubishi P93 thermal printer. getting a consistent "EL" error (gear lock). turning it off and on resets error, but gear lock re-occurs if I try to print anything.
Electric motor keeps cutting out
There may be a thermal protector placed internally within the motor or motor-compressor to protect the motor and motor winding's components from dangerous overheating that can cause motor failure.
This overheating generally occurs when the motor is overloaded, a bearing seizes up, something locked the motor shaft from turning, or the motor simply fails to start properly. A failure to start may be caused by faulty start winding's in a motor.
The thermal protector consists of one or more heat-sensing elements integral with the motor or motor-compressor and an external control device. The thermal protection is in place to turn the motor off when excessive heat is generated within the motor circuitry and keep it from burning up the motor.
These thermal protectors are reset when the motor cools to a safe operating temperature. There is usually a visible red button located on the wiring side of the motor, opposite of the motor shaft, but not always. In some cases, these buttons are reset manually.
Mar 10, 2014 | Garden
Mitsubishi p93 thermal printer streeking
Thermal heads show faults in two ways.
if a single line through print and you can see some colour in the print is is dust on head. Clean with isoprop alcohol and a lint free swab.
if it is a white line with no colour then its most prob a thiristor blown on the head, the white line will soon expand as other thiristors next the the faild one will soon also fail. A head replacement would be required. Is the head set at the correct voltage, replacement heads come with a test sheet and a value to adjust the head voltage too.
Feb 04, 2014 | Mitsubishi P-93W Printer
Epson 610 Workforce Printer Error; Light Bar won't reset
Sound like the scanner is the issue, is it under warranty? OR the Scanner may be locked, check for the scanner release device unlock it,.
Dec 17, 2012 | Epson Workforce 610 All-In-One InkJet...
Getting error message
turn off printer while holding #9 button press power wait till display "full nv reset" problem solve
Oct 05, 2012 | Epson WorkForce 845 Wireless All-in-One...
My printer is giving me this error message "Batch
That's a batch error, more than likely due to a communication issue between the pc and the printer. If you reboot the printer, THEN reboot the pc you should clear that error.
This error sometimes occurs when the printer has been shut down whil logged into your software, which disables communications between pc and printer. The error indicates that the printer didn't receive enough data to properly print the batch of labels/tags.
Sep 14, 2011 | Paxar Monarch 9825 Thermal Label Printer
I am using fargo direct to card 550 printing machine.In that error displays "HEAD LIFT ERROR". sir how can i solve this problem and also have lots of noise is coming from the printer..please...
In this problem , first check the front side head lift gear and gear belt.
solution : Gear or gear belt may be broken.
by
LAKSHMI KANTH,
CHENNAI.
Aug 02, 2011 | Fargo DTC550 Thermal Card Printer
I put 2 new printer cartridges in and got the effor Oxc18a0101. What should I do? My printer is an HP Photosmart D7160. I've looked at some solutions on line, but they refer to typing numbers,...
Hi Karen, This likely is either due to Bad/Expired Printhead or it could be defective printer ( hardware failure ). However you can give it a try. Follow the steps below and it should solve the problem, else we need to consider it could be defective Printhead or printer hardware failure.
The Photosmart D7160 does not has "*" and "#" because it is not a fax capable printer.
*** Fix your HP Photosmart D7360 (Reset Code/Master Reset) ***
1- Turn off power and unplug from power source.
2- Open right side of printer (looking at the front).
3- Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
4- Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
5- Unplug power source.
6- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
7- Plug in power source and turn printer on (Printer preparing occurred).
The error message 0xc18a0001 "Ink System has Failed" is now gone
Regards,
Ron
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
May 17, 2011 | HP Photosmart D7160 InkJet Printer
I was in the process of making copies, when my Epson RX700 suddenly made a loud grinding noise. It then stopped working and displayed an error message: Scanner error occurred...Please see...
There are two drives in the printer. One moves the print head (cartridge) back and forth across the paper. Check to see if the "rubber band" drive belt is slipping or broken off. There is also a roller motor which feeds the paper. This has nylon gears which can make a grinding sound if one of the gears gets stuck. Make sure there are no pieces of paper stuck in the gears.
Mar 06, 2011 | Office Equipment & Supplies
El led del papel se queda parpadeando y no imprime es como si tubiera algo atorado
Units built before June 18, 2008
Units with a S/N having a Year Built and Week Built code earlier than "08-25" are reset using the following procedure:
1. Open the media compartment and remove any media.
2. Press the Feed button and hold it approximately ten seconds until the Power, Communications and Error indicators turn off and stay off.
3. After the three indicators turn off, reload the media and close the media compartment cover.
4. Wait at least ten more seconds and press the Power button. The Printer will restart and normal operation can resume.
Units built after June 18, 2008
Units with a S/N having a Year Built and Week Built code of "08-25" or later are reset using the following procedure:
1. Press and hold the power button for 5 seconds and then release. The printer will power down.
2. Re-start the Printer as usual. Any pending data in the printer will have been deleted and must be re-sent.
Dec 16, 2010 | Zebra MZ 320 Thermal Printer
Sony up-dr 100 error 0007
This may well be a failure of the cutter switch sensor to reset. This worked for me.
Turn Off the Printer.
Remove both side panels and the plastic panel on the INSIDE of the DOOR on the right hand side. Then close the door and remove the plastic panel UNDER the door. This is held in place by two screws.
You will see a white gear on the bottom right hand side of the door. It is on the underside of the door. Turn this gear untill you can see the cutter move smoothly across the bottm of the door and return to the right side of the door. Listen for a click. This is the switch resetting. Close the door and power up the printer if you still get an error code 0008 or 0007 repeat the resetting process by turning the gear. BE SURE TO TURN OFF THE PRINTER!!
Dec 11, 2007 | Sony UP DR100 Thermal Photo Printer
483 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
