Question about Canon NP 6035 Copier
The sorter tray..where the copies are deposited...comes detached from the copier...it seems to be broken, you have to hold it in place or the normal vibrations of the copier causes it to detach..where can I get a part...the local company we use for fixing it says he can't find it...that seems a little weird...thanks TT
  • Canon Expert
  • 231 Answers
I belive that the part that you need is called Holding Tray Assembly and the part number is FG5-8666-000 and I think that you can find it at any Canon Partener.
Posted on Nov 17, 2010
Lanier 5635 Sorter
Under user tools, system settings make all prints, copies to come out in internal tray, the front and rear covers have to come off to remove screw 1 each side the SC code is shift tray motor error
Dec 18, 2013 | Lanier Office Equipment & Supplies
Minolta Copier's sorter bin won't close properly.
This 20 bin sorter uses an interlock switch and actuator to show that the sorter is properly attached to the machine. Pull the sorter away from the machine and look at the rear side of the copier that faces the sorter. There should be what looks like a spike mounted to the copier. That spike goes into a hole in the sorter which then actuals the switch. Make sure the spike is not broken or loose. Make sure the tray that the sorter sits on is not bent. Correct any issues with these 2 and you should be good to go.
Jan 07, 2010 | Minolta EP4000/5000 CS/PRO Copier
Trouble getting ''copy'' from copier to sorter. gets stuck in btwn
Clean the exit parts rollers,lever and the sorter roller and bins.
Nov 23, 2009 | Office Equipment & Supplies
Removed the sorter from a ricoh FT5832 copier and replaced with copy tray. how do I bypass the sorter cover (C-5) error message? Will not operate without the sorter plugged in.
Enter the SP mode by hitting the CLEAR MODE key, 1 0 7 then hold the CLEAR STOP key. When SP mode is selected , "1" blinks. Then enter SP 6-101-0 by hitting 6 then the . (dot) key, the 101 then the . (dot) key then the 0 key then the . (dot) key. This will tell the copier that NO sorter is intsalled. Hit the CLEAR MODE key 3 times or turn the machine off/on.
Sep 26, 2009 | Office Equipment & Supplies
E6 error On a Ricoh ft4022 copied paper doesn't throughly comes out
It can be some of this because you give us only the firs digit you should press "." for to see the two other digits which can be as follow:
E620 Main board – ARDF communication error
E621 Main board – Sorter communication error
E623 Main board – Paper tray unit communication error
For start you can see do the sorter or the ADF are good connected
It has two cables one is white and other is black see do they are good connected or it can be broken on some place of the cable, special the black because is optical cable.
also see do the paper tray is good entered in the machine if all this up mentioned are good then is a problem with the main board
May 13, 2009 | Ricoh Office Equipment & Supplies
Error code E522. How to fix this?
You have an issue with your staple finisher, probably need to inspect the stapler unit itself to make sure nothing is jammed in it and it moves freely. If you can't clear the error then most likely the unit is defective.
Hope this helps,
TankMurdock
Apr 24, 2009 | Canon NP 6551 Black and White Copier
Copystar CS7530 saying sorter is not connected when it is, machine will not copy unless I detached sorter I was also told by a tech thatI may have a bad board. Please help
Hello sir; I don't think so, that not the board problem, try to push sorter unit close to the copier as tighten you can, if still not working, you have to check the switch has been actuated.
Feb 21, 2009 | Copystar Ri-6230 Grayscale Copier
Jammed paper at the Sorter Unit
Do you get a paper jam or is the finsher not showing that is empty? You may have a broken bin or a miss alined bin or you have a lazy sensor flag. The copier should give you a idea where the paper jam is... May need more info. on this one..
Jun 06, 2008 | Canon NP 6050 Copier
E544 code
A E544 code is a sorter problem if it is a Canon copier. If it is a Canon look to see if the stapler has a jamed staple it and remove it. The front door of the sorter should have a picture to show how to remove it or remove a jam. If the bins are stuck or broken thry to turn the copier Off and unplug the sorter and turn the copier back on if it clears try to turn it Off and reinstall the sorter plug and turn it back On. If the code comes back try to see if you can detach the soter from the main body of the copier and unplug it from the back of the copier and make a exit tray for the copier. Good Luck
Apr 08, 2008 | Office Equipment & Supplies
Nothing is copying
E532 is a sorter problem. Have you replaced the staples recently? If so try to remove any jamed staples from the stable cartride and try to reinstall as shown on the inside of the soter front door. You can also try to turn the copier off and unplug the sorter and reattach it and turn on the power. See what happens, if that does not work and you don't really use the sorter, unplug it and detach it from the copier and make a exit tray and there you go. If you do use it call for service.
Feb 07, 2008 | Canon NP 6050 Copier
Canon NP 6035 Copier Logo
37 people viewed this question
old marine
old marine
