Question about RELIANCE ELECTRIC WATER HEATER
I just replaced my old rusted out water heater with a new Reliance 606 and now I am having problems with the circuit breaker being tripped, usually during the night. It doesn't happen everyday but is consistent. The breaker never tripped with the old heater.
    Genius:
  • 1,015 Answers
I would check with your owners manual to see what they reccomend for minimum breaker size. I don't remember on this particular model but it may be a single element instead of dual element. The single element usually use more power than dual. I would also check thermostat settings if this is a dual element. They should never be set at same temperature. Also if it continues to trip breaker I would check all wiring,then replace breaker. Sometimes they do wear out and trip when they really shoul not. Hope this helps. Thanks
Posted on Nov 15, 2010
My reliance 606 electric water heater keeps tripping the breaker. When it is reset the water gets real hot and trips again, then no hot water. Help!
You water heater most likely has a shorted heating coil, don't run it like this, call a service technician.
Nov 10, 2016 | Reliance Water Heaters
Hot water tank wont heat water, how do you relight or resat, its a reliance self cleaning 808
Reliance Water Heater Literature ' Owner's Manuals ...
www.reliancewaterheaters.com/resources/instruction-manuals
Welcome to the Reliance Water Heaters Owner's Manual and Installation ... 9 40 EKRT - 40 Gallon Tall Self-Cleaning Electric Water Heater - 9 Year Warranty . ..... 10 50 DHPST - 50 Gallon Electric Heat Pump Water Heater - 10 Year Warranty .
How to light the pilot on a Reliance 606 water heater ...
? 3:27
https://www.youtube.com/watch?v=VU2PsFVd2ug
Jul 12, 2011 - Uploaded by kilroywashere123
How to light the pilot on a Reliance 606 water heater ... How to fixwater heater, will not stay lit - sealed combustion no hot water - Duration: ...
Reliance Water Heaters - Consumer Affairs
www.consumeraffairs.com > Homeowners > Bath & Plumbing
Rating: 1.6 - ‎84 votes
I purchased a Reliance 606 water heater in 2010. ... That they don't TELL you there's areset button or that I'm having conspiracy thoughts ... After several attempts, I was able to relight it. ... It's heading to the junk pile and I will purchase a new reliable (NotReliance) ... Checked breaker and changed breaker still no hot water!
Dec 28, 2015 | Reliance Water Heaters
Have a reliance electric water heater model 606; have no hot water. I am having a problem finding the reset switch.
If it was working and recently stopped working, the heating element that heats the water probably went bad, no longer functioning. Check to make sure that there is or is not a reset button, and if there is, press and reset the heater. It's not difficult to remove the old heater element and replace it, but make sure the circuit breaker power to the water heater is off when you remove it. Take it to a water heating supply store, or large hardware store with the Brand and model number of your water heater (Reliance RELIANCE ELECTRIC WATER HEATER,model 606 ) to buy another one.
Sep 21, 2012 | RELIANCE ELECTRIC WATER HEATER
Can i replace 4500watt elements with 5500watt on a 606 model
1) Manufacturer's warranty will be voided, and I've never seen recommendation that suggests better heating or saving money from replacing 4500W with different wattage element.
2) That being said, you have 240V water heater.
4500Watts divided by 240 = 18.75 amps
5500Watts divided by 240 = 23 amps
20 amp circuit breaker with 12 gauge wire is rated for 80% of load = 16amps
30 amp circuit breaker with 10 gauge wire is rated for 80% of load = 24amps.
http://waterheatertimer.org/Figure-Volts-Amps-Watts-for-water-heater.html
3) You can use 5500Watt element if you have 30 amp breaker and 10 gauge wire.
Feb 15, 2011 | RELIANCE ELECTRIC WATER HEATER
I have the Reliance 606 and my water has been extremely hot - do I need to change both of the heating elements in it
Are you aware of how to adjust thermostat(s) on water heater? Be sure to shut off power (circuit breaker(s) to water heater prior. Should be behind covers on tank. Both should have screw in center to allow you to back down temperature. Should have an arrow indicating current temperature setting, simply move it slightly toward lower temperature (usually counterclockwise, but just double check ) and try it, until desired temperature is reached.
Nov 30, 2010 | RELIANCE ELECTRIC WATER HEATER
Hello, i have a reliance 606 im having a problem that the reset button, it keep on tripping. when i reset it last like 2 days then it trips again. i have changed the upper thermostat and element and it...
It sounds like you have things pretty well covered. I would change reset and if it continues to trip breaker I would check wiring very carefully where it enters top of water heater. Check for any nicks or bare spots on wiring insulation. Other than that about all I can think of is to change breaker. Sometimes they do get weak and trip to easily. Hope this helps. Thanks
Nov 10, 2010 | RELIANCE ELECTRIC WATER HEATER
I have a reliance 606 electric water heater. it heats water fine when its on...it keeps tripping the circuit in the breaker box though...How do I fix this? thank you!
Open covers on tank and inspect for burned connections or melted parts
1) Test electricity to water heater:
http://waterheatertimer.org/Test-electricity-to-water-heater.html
2) Test water heater elements
http://waterheatertimer.org/How-to-test-water-heater-element.html
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Aug 31, 2010 | RELIANCE ELECTRIC WATER HEATER
Water Too Hot
needs new thermostat(s) If the whole tank is heating( next time it trips, before using any hot water check the lower tank thru the lower element access(breaker off) If the lower tank is hot-you need a new lower thermostat. if just the upper part of the tank is heating -you need an upper thermostat.
Jan 18, 2010 | RELIANCE ELECTRIC WATER HEATER
Circuit breaker trips on electric hot water heater circuit
Check the voltage at the water heater. Sounds like the element is burnt out and is tripping the breaker.
If it is more then 5 years old I would check.install a new heating element.
Mar 27, 2009 | RELIANCE ELECTRIC WATER HEATER
RELIANCE ELECTRIC WATER HEATER Logo
107 people viewed this question
Top Reliance Water Heaters Experts
Mack Baxter
Gil Shultz
rickb63
Are you a Reliance Water Heater Expert? Answer questions, earn points and help others
