Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Icemaker will not dispense ice. the bin is full. when you push the button the micro-switch clicks and the flap opens, but the motor don't turn. is it the motor or the pc board
  • 65 Answers
You are correct. Motor or Board. See if you can turn auger motor by hand It is geared and should be hard to turn but not locked up. You can also remove auger motor assembly. Plug it into 110v it will run, (replace board) or not. (replace auger motor).
Posted on Nov 15, 2010
Our Kenmore side by side refrigerator ice maker makes ice but when we press the ice dispenser lever there is no sound and no ice comes out.
If your refrigerator has an ice dispenser, you are probably used to getting ice right away when a lever or button is pressed. However, if you depress the ice maker button and nothing dispenses, there is an issue with your refrigerator. There are a few different reasons why an ice dispenser would suddenly not work. It is important to troubleshoot your refrigerator first to determine the problem. Some problems can be fixed at home, while others must be repaired by a professional
1 Remove the ice bin from the freezer and press the button on the front of the refrigerator for cubed ice.
2 Open the freezer door and hold down the switch on the door, which "tricks" the freezer into thinking the door is closed, and push the lever or button to dispense ice. The motor behind the ice bin should turn. If it does not, this means the motor is frozen.
3 Remove the motor, following the directions in your refrigerator's manual. Heat and dry out the motor with a hairdryer until the motor turns again, then reinstall the motor according to the manufacturer's directions.
Ice Bin or Chute
1 Remove the ice bin to see if it is overloaded. Ice bins that are too full can cause new ice being produced to back up and cause blockage. If this is the case, dump out the ice and rinse out the ice bin with hot water until any blockage is melted.
2 Examine the separator that divides the ice storage bin from the ice dispenser for holes. If the separator has a hole or is cracked, it must be replaced.
3 Watch the flap on the ice dispenser as you hold down the door switch and simultaneously press the button to dispense ice. If the flap does not close all the way, check for ice blockage and gently remove it. If there is no blockage, the flap will need to be replaced.
Hope this tips would help.
Have a nice day!
Sep 05, 2011 | Kenmore Side by Side Refrigerator
GE Profile 2006 Icemaker (icemaker model: wr30x....) doesn't make ice but cycles perfectly when jumped. Making 8 ice cubes at a time by jumping is cumbersome however. Can you explain how to get the...
The flexible arm is the on off switch to the timer. And the timer is in the ice maker itself. Make sure that arm is in the correct position.
Sep 13, 2010 | Refrigerators
Galaxy ice maker dispenser runs but does not dispense ice. So far as can tell it is not clogged
Check your manual, there is a wire or device to shut off icemaker when the ice bin is full it is pushed up to stop the ice making process. Make sure it is not stuck in the up position (off) and is pushed down so it can freely move up and down. If that is not the problem it could be a bad micro switch for the shutoff device or a bad water valve.
Jan 20, 2010 | GALAXY Microsystems 25.4 cu. ft....
Icemaker makes ice, but will not dispense ice via door.
The auger arm in the back of the freezer should be rotating to test this hold the door switch in and push the dispise button down. If it does not even try it could be the control switch on the door. the auger motor is a 120v motor and relatively strong. You can test to see if you can manually turn the arm it should trurn stiffly. Its alsoi a chance you don't have the been in place correctly.
Jan 10, 2010 | Frigidaire FRS23R4A Side by Side...
The ice will not come out of the icemaker when the lever on the door is pushed. Can I troubleshoot this problem?
Open the door and hold the door switch down and try the ice dispenser. Do you hear any thing. Take all the ice out of the bin and try. Anything? Take the bin out and try. Anything? The motor is behind the back cover where the bin sits. See if you get power to it using a voltmeter. If your are, probably bad motor. If not dispenser switch.
Nov 17, 2009 | GE Profile PSW26P Stainless Steel Side by...
Matag fridge msd2351hew icemaker ice and water work and cubes come of crushed ice dispencer. There is a capacitor connected to auger motor.Is this the problem? There are no other electrical parts.
If you remove the bin and look on the bottom of it you will see a rod running from front to back,this opens and closes the crusher see if it moves freely, if not dump the ice and rinse the bin out with hot water till it moves freely,if so,with the door open set the dispenser to cubes leave the bin out push the light switch in and hit the  dispenser button you should hear a loud pop and see the actuator by the auger motor move up,and drop down when you release it.
Aug 22, 2009 | Maytag Refrigerators
Ice is made but dispenser does not spin so ice wont drop
Hi, Remove the ice bin. With the freezer door open, push the door button and then push the ice dispener button to see if the auger motor is turning. If it does turn, check and see if there is something in the ice bn blocking the auger.
Please try this and let me knwo.
Thanks
Vic
May 24, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
take out ice bin, make sure you get it lined up when put back together, should click,sometimes they are a little off and you have to keep trying, mine has that defect, it works, but only on its terms, its a pain to do, but that can stop it from working due to a safety thing
Oct 30, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
No ice through dispenser
When you operate the ice dispenser lever, you should be able to hear a little click from a micro-switch that then switches the auger motor and the light on and also opens the flap. If you cannot hear this small click, then the micro-switch is faulty. The ice dispenser only works when the freezer door is closed, so you could also inspect the door light/fan switch for proper operation.
Oct 30, 2007 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Icemaker will not disppense ice on my Samsung RS2534ww
SOUNDS TO ME THE TRANSPORT AUGER MOTOR NEEDS REPLACEMENT. JUST MAKE SURE THAT ON THE CONTROL PANEL, THE CHILD INTERLOCK IS NOT ON WHICH STOPS ICE DISPENSING OPERATION. JUST DONE ONE NOW WITH THE EXACT FAULT.
Jul 14, 2007 | Samsung RS2534 Side by Side Refrigerator
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
205 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
