Question about Microsoft Windows XP Professional for PC
Using WINDOWS VISTA. how to fix it
Error+at+entry+%5BLjava.lang.Object%3B@4df756+in+entries+file+for+%27%7B1%7D%27%3Asvn%3A+...+line+*+toString%28%29+&meta=
  • 35 Answers
When are you getting this error?
are you getting the error when you log on or when opening any particular software..
Moreever the error seems to be thrown by Java.. Better reinstall java on your computer
To uninstall Java ->Start -> Type" Programs and features" on the start search and open it -> remove Java from there
Then open Internet Explorer -> Tools -> Internet Options -> click settings on Browsing history -> view objects
remove java from there. Reboot the computer once.
NOw logon to http://www.java.com to install java on your computer..
Posted on Jun 19, 2008
Bootmgr is missing
Bootmgr is the replacement for NTLDR in Vista and Win 7. NTLDR (NT loader) is the OS component which literally started the operating system in XP/2000. In the past I have had to use recovery console to go in and repair the OS (this is only available on the Windows disc). I would say in this case you will have to do the same, repair the operating system using the Windows disc.
This article is a how-to on fixing this issue, if you up for it:
http://www.howtogeek.com/howto/windows-vista/fixing-bootmgr-is-missing-error-while-trying-to-boot-windows-vista/
Jan 14, 2012 | Gateway Computers & Internet
Tip
How to fix BOOTMGR is missing" Error While Trying to Boot Windows Vista
If your Windows Vista computer has encountered the dreaded “BOOTMGR is missing” error, you aren’t alone. If the problem isn’t hardware related you can fix it with relative ease as long as you have a Windows Vista DVD handy.
If you don’t have one, you can create a Windows Vista repair disk using our guide
Boot off the Windows Vista DVD and then click Next at the first prompt
You should see a link in the lower left-hand side for “Repair your computer
The installation process will attempt to find your Vista installation directory. If there’s more than one in the list, select the correct one and then use the Next button again
Click the first link for “Startup Repair
The installation process will repair the system, and then prompt for you to reboot
Alternatively you could have chosen the Command Prompt option instead, and use the following command to fix the boot options only:
bootrec /fixboot
At this point you should be able to reboot your computer, remove the DVD and everything should be working. If not, then head over to our forums and ask your question there. We’ve got some top-notch geeks over there!
on Jun 30, 2010 | Computers & Internet
Tip
Fixing "BOOTMGR is missing" Error While Trying to Boot Windows Vista
If your Windows Vista computer has encountered the dreaded "BOOTMGR is missing" error, you aren't alone. If the problem isn't hardware related you can fix it with relative ease as long as you have a Windows Vista DVD handy.
Boot off the Windows Vista DVD and then click Next at the first prompt:
You should see a link in the lower left-hand side for "Repair your computer"
The installation process will attempt to find your Vista installation directory. If there's more than one in the list, select the correct one and then use the Next button again.
Click the first link for "Startup Repair"
The installation process will repair the system, and then prompt for you to reboot.
bootrec /fixboot
on May 27, 2010 | Computers & Internet
My compaq presario f700 laptop says bootmanager missing when i tried the reboot cds its says cannot reboot from disc
Ifyour Windows 7 or Vista computer has encountered the dreaded "BOOTMGRis missing" error, you aren't alone. If the problem isn't hardwarerelated you can fix it with relative ease as long as you have a WindowsDVD handy.
If you don't have one, you can create a Windows Vista repair disk
http://www.howtogeek.com/howto/windows-vista/how-to-make-a-windows-vista-repair-disk-if-you-dont-have-one/
Boot off the Windows Vista DVD and then click Next at the first prompt You can also follow the step from this side:http://www.howtogeek.com/howto/windows-vista/fixing-bootmgr-is-missing-error-while-trying-to-boot-windows-vista/
The installation process will attempt to find your Vistainstallation directory. If there's more than one in the list, selectthe correct one and then use the Next button again.
Alternatively you could have chosen the Command Prompt option instead,and use the following command to fix the boot options only: bootrec /fixboot
Nov 21, 2010 | Creative Labs Sound Blaster Live! Value...
Windows failed to start. An error occurred while attempting to read the boot configuration data. I have no copy of Vista.
Without your Vista CD you are really stuck. Your only option is to get an OS CD. If you get a Vista CD, I can walk you through the process of fixing it.
One other thing you might be able to try is to install a Linux distro on top of it. You could make it a dual boot setup so you could at least make good use of your computer. However, without the Vista disk, you can't fix Vista. The only reason I am mentioning Linux is because it is free and you can gain access to all your files that you were using in Vista through Linux.
If you regularly use Windows proprietary programs this won't be of much use to you. However, if you are like most people and just use MS Office, web browser, email, etc. Linux does a splendid job of replacing Windows.
Dec 22, 2009 | Sony Computers & Internet
When turn it on it says bootmgr missing what can i do
You boot sector on the hard drive is faulty.
Fixing "BOOTMGR is missing" Error While Trying to Boot Windows Vista If your Windows Vista computer has encountered the dreaded “BOOTMGR is missing” error, you aren’t alone. If the problem isn’t hardware related you can fix it with relative ease as long as you have a Windows Vista DVD handy.
If you don’t have one, you can create a Windows Vista repair disk using our guide.
You should see a link in the lower left-hand side for “Repair your computer”
The installation process will attempt to find your Vista installation directory. If there’s more than one in the list, select the correct one and then use the Next button again.
Click the first link for “Startup Repair”
bootrec /fixboot
Thank you.
Oct 13, 2009 | Dell Latitude D400 Notebook
Vista aero crash
Ok, in that case , Try doing system restore using the following link and restore your system to the date on which it was working fine.
http://www.howtogeek.com/howto/windows-vista/using-windows-vista-system-restore/
May 29, 2009 | Microsoft Windows Vista Ultimate Edition
How can i fixed the sp1 problem in windows vista?
You can go to http://www.microsoft.com and validate/ upgrade your original vista remember to have the product key on hand!
Then use auto-updating for your vista windows update for future windows updates.
Mar 05, 2009 | Microsoft Windows Vista Ultimate Edition
I cant scan!
Resolution : I
1 Scan using Windows Fax and Scan
Click the Windows icon (c01319360.gif ), click Programs , and then click Windows Fax and Scan . NOTE: The Windows Fax and Scan option is available in the Business, Ultimate, and Enterprise editions of Windows Vista. If you have the Home Basic or Home Premium edition of Windows Vista, skip to Option two: Scan using Paint .
  • Click New scan .
  • Click File , and then click Scan .
  • Option two: Scan using Paint
    1. Click the Windows icon (c01319360.gif ), click Programs , and then click Accessories .
    2. Click Paint .
    3. Click File , and then click From Scanner or Camera .
    4. Click Scan .
    II nd issue :
    Problem :
    'An error occurred while communicating with scanning device' Message Displays in Windows Vista When Scanning
    Then refer to
    http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01290511&cc=us&lc=en&dlc=en&product=441125
    Sep 23, 2008 | HP Officejet 5610 All-In-One InkJet...
    Microsoft Windows XP Professional for PC Logo
    120 people viewed this question
    Top Microsoft Computers & Internet Experts
    micky dee
    Piyal Perera
    Piyal Perera
    Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
