Question about Amana ARS2464BW Side by Side Refrigerator
How do I remove the cover to change the light bulb on my old side by side Amana refridgerator?
  • 8,197 Answers
May I get the model # to help you more
Posted on Nov 15, 2010
How do I got the cover off the light in the refrigerator to change out bulb?
mine was attached with screws that required a socket wrench.
I just unscrewed it, removed and washed the cover in soft dish soap, replaced the bulb and reattached
Aug 08, 2012 | Amana 22.6 cu. ft. Side-By-Side...
Amana green water filter light off
If your machine is only 2 months old and wasn't used when you bought it call the number on the label that has the model and serial number on it that is located either inside the refridgerator on the upper wall somewhere or somewhere on the frame. Being that whirlpool now owns Maytag, which encompasses Amana, you have a one year manufacturer warranty where parts and labor are both covered free of cost.
Apr 27, 2012 | Amana 22.6 cu. ft. Side-By-Side...
How can I remove the light bulb cover in my amana freezer? I have removed the screw, but it wont budge.
Hello.
the cover over the light bulb should have a squeeze tab a each end from left to right. Squeeze the cover and it should come out
Good luck, i hope this helps
Gene
Aug 03, 2011 | Amana ATB1504AR Top Freezer Refrigerator
Can you explain how to replace the light bulb in my amana oven?the model number AARG7303WW
This worked like a charm ... actually it's easier than you might think. Just a few screws and a few tugs. Give it a shot.. I found a 10W (G4 style ... you'll see the difference when you get to the store) replacement bulb at Home Depot for $6:
1) Turn off power to the unit
2) Open the lower oven door
3) Remove the side trim screws and pull the trims down and out.
4) Remove 2 screws on the sides of the control panel.
5) Open the Microwave door. Remove the 3 screws on the Air Vent Plastic Cover on top of the microwave. You can then remove the Air Vent Cover by pushing the control panel up and pull out slightly at the bottom.
6) Remove the 4 screws on the Air Vent Plastic Cover on top of the lower oven and remove the Air Vent Cover. (You may have to remove the left under side bracket of the Microwave door temporarily just for the Air Vent Cover to clear the screw of the bracket. Re-secure the side bracket of the Microwave door panel as the front panel may fall)
7) Remove the 2 screws which held the Microwave unit in place behind the Air Vent Cover on step 6.
8) Wiggle the Microwave unit out about half way to expose the light bulb unit on top center
9) Wiring to the Control Panel will prevent you from pulling the Microwave unit out any further. And you don't want to do that as the unit may fall. Space is cramped, but working carefully with your fingers or pliers you should be able to release the springs which held down the light bulb unit and change the bulb.
Feb 14, 2010 | KitchenAid KEMC378KSS Electric Double Oven
I have a 18 yr old magic chef refrigerator.The interior light is out and I don't know how to replace it.
Usually a simple job - look for a screw holding the light cover. Unpug the pfidge, remove the cover scrws and remove the bulb - usually a screw in type. Replace only with the same sort, then replace light cover and turn power on.
Nov 07, 2009 | Amana 22.6 cu. ft. Side-By-Side...
How do I change the light bulb in the amana range
You change from inside of oven. Bulb will be located under glass bulb cover. Push clip to side, remove glass cover, then unscrew bulb.
Jun 16, 2009 | Amana ACF3325 Gas Kitchen Range
Trying to replace a light bulb on an amana microwave
The lamp on this model is an assembly - bulb and socket mated together.
It is mounted in an air duct on the right side of the oven near the magnetron.
You'll have to remove the outer cover to get to it.
You can find helpful exploded view diagrams and order the bulb by entering your full model number here.
Dec 09, 2008 | Amana ACM1580AS Microwave Oven
How do I change the light bulb in an Amana microwave model# ACM1580AS?
The whole metal cover should be removed, 2 special tamper proof screws are at the bottom back end use a small screw driver to pry or break the center post and then use torx screw driver to take it out, the bulb is a specialty bulb available in partselect.com for almost 30 bucks. good luck!
Jun 20, 2008 | Amana Microwave Ovens
Light bulb replacementR
A fridge light bulb is usually a 40 watt appliance bulb with a screw base. It is heavy duty to last in the temperature. If it is not easily accesible to unscrew and replace, there may be plastic cover to unsnap.
Dec 27, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Amana 8 yr old side-by-side refridgerator/freezer
sound like you said a sealed system problem if compressor is running check the black coil under ref by the fan and see if it is warm if not you have lost freon just trash it then if it is see if fan in freezer is running if so pull back cover in freezer and see if coil starts to freeze if you have a ice block on coil then it is a defrost problem good luck
Dec 04, 2007 | Amana AFD2535DES French Door Refrigerator
Amana ARS2464BW Side by Side Refrigerator Logo
56 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
