posted by aagant on Jun 19, 2008
will not boot when power button pressed the amber light on the front flashes what I assume to be a code 2 3 2 1
Comment by aagant, posted on Jun 19, 2008
I had done that and the led still flashed the sequence 2flashes 3flashes 2flashes 1 flash repeatedly.
I was hoping this might be a service code indicating which component was at fault.
Best Solution
try removing the memories, hard drive, optical drives and power on your computer. if the computer beeps it is an indication that your computer is working and one of the remaining part could be causing the no boot. if after removing all the parts your computer will not beep or the flashing amber light will not change it looks like you will need to replace your motherboard
Comment by kikoksky, posted on Jun 19, 2008
it is a diagnostic code that your computer is manifesting but the toshiba techs can only be the one to identify the meaning of that code. but when you removed everything connected to the motherboard like memories, hard drive and optical drive or if you have other card connected to the motherboard remove it and see if there are any changes
Rating Locked! (?) aagant has rated this solution as Helpful
This Problem Also Relates To:
HP HP Pavilion dv9000z 17" Notebook Laptop PC PC Notebook
HP HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook
HP HP Pavilion dv6000z 15.4" Notebook Laptop PC 64 X2 Duo Core TL-56 1.80GHz, 1GB RAM, ... PC Notebook
HP NC4010 PC Notebook
HP Pavilion dv2500t PC Notebook
HP Pavilion ze4220 (DB385AR#ABA) PC Notebook
HP Compaq nc6320 PC Notebook
Can you Help with these PC Laptops problems?
Acer Aspire 3690-2196 PC Notebook
Slow startup, slow responce.
i have 5 to 6 minute boots... Answer This...
Acer TRAVELMATE 2300, 2310, 2410, 4000,...
acer 2420
acer 2420
I need the service manuel for... Answer This...
Acer Aspire 5500 5570-2609 Laptop Computer...
Aspire 5003WLMI No Power
Hi, my LT has suddenly stopped... Answer This...
Acer 2300 Wireless Lan Card not...
If I have to replace the card... Answer This...
Gateway 7330GZ PC Notebook
Numbers and backspace on...
The numbers line and backspace... Answer This...
Repair Service
Find PC Laptop Repairman Near You:
