Question about Canon PIXMA MX310 All-In-One Printer
I have a Canon MX320 printer and the black ink cartridge needs to be replaced. How do I get the carriage out from under the right side where it is covered to the middle so that I can access the cartridges? Thanks sue morris, Winnipeg, manitoba, canada I have an essay that needs to be delivered today.
    Guru:
  • Canon Master
  • 1,705 Answers
Normally, you just lift the lid and open any drop down covers, the cartridges then just slide to the middle
An online instruction manual is here :-
http://software.canon-europe.com/software/0035538.asp?model=
Just scroll down to and click on the line:-
And click on it, the manual should download.
Posted on Nov 15, 2010
Why wont my color ink work in my canon MX320 printer?
Take out the carriage and soak it in solution for 24 hours to clean the jets
Sep 26, 2014 | Canon PIXMA MX320 Color USB InkJet Printer
Error 5100
1) Smearing or scratches on the timing
**** film;
clean the timing **** film.
2) Foreign material or paper debris that
obstructs the carriage movement;
remove foreign material.
3) Ink cartridge conditions;
re-set the ink cartridges.
4) Cable connection
5) Part replacement:
- Timing **** film
- Carriage unit
- Logic board
- Carriage motor
Aug 22, 2011 | Canon PIXMA MX320 Color USB InkJet Printer
How do I change the ink on the Cannon MX330? I cant find where the cartridge is
I am writing this to enquire in regards to Canon Pixma MX320. I bought a Canon Pixma MX320 about 3 weeks ago, and I have brought it over to overseas. I am wondering if it is possible to change from the general ink cartridge that this particular printer use, which is PG510 and CL511 to another similar ink cartridge, which is PG810 and CL811. This is because, where I am living right now, doesn't have the particular Canon Pixma MX320, but instead Canon Pixma MX328 and MX338. The Canon Pixma MX328 and MX338 uses the PG810 and CL811. So, is it possible to substitute from PG510 to PG810 and CL511 to CL811 for Canon Pixma MX320? Thank you for your help.
Aug 29, 2010 | Canon PIXMA MX330 Multifunction InkJet...
How do you replace the ink cartridge on my Canon pixma mx320 printer?
Lift up the top lip cover together with the scanning unit cover to expose the cartridge carrier.
Open the ink locking cover. Gently pinch and pull up the cover of the cartridge carrier.
8bc22ce.jpgAfter that replace the ink cartridge...
I hope that instruction will be of help.
Please rate this answer.
Thank you for using Fixya
Jun 07, 2010 | Canon PIXMA MX320 Color USB InkJet Printer
I just installed new cartridges (3rd set) and printer still says ink is low. How can that be? Is there something I can do to reset the printer color and black buttons. They show yellow instead of green....
Hi
If you replaced the cartridges with genuine Canon cartridges then there's probably a build up of ink under the cartridge carriage. Pull out all the cartridges and lift up the carriage. Clean it using a non alcohol cleaner. While you're at it put some cleaner on a folded up paper towel and wipe the ink reservoir located on the right hand side, where the carriage sits when idle. If you replaced your Canon cartridges with off brand cartridges then you might not have changed the chips over. On the old cartridges there's a tiny chip glued to the plastic in front. This chip must be popped off and snapped onto the new cartridge. Good luck
Apr 06, 2010 | Canon PIXMA MP210 InkJet Printer
Ink replacement
open the front part of the cabinet and there u get to see the black cartridge gently pull it out and then replace it with new one
Sep 04, 2009 | Canon Pixma MP600 Printer
Pixma iP4200
You either have bought a bad cartridge, or are using a generic or refilled cartridge, or have damaged the contacts in the carriage assembly.
Replace the same cartridge again only make sure you use a new Canon cartridge. If this does not help, either the contacts in the carriage assembly are bad or the main board has bit the dust.
Repairing the contacts would require you to remove the upper case so you can access the contacts, remove the ink cartridge and streighten out the contacts before reinstallig the cartridge.
The contacts are located at the front of the carriage assembly under the ink cartridge.
Oct 06, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Canon PIXMA MX310 All-In-One Printer Logo
100 people viewed this question
old marine
old marine
