Question about Lilly Wonder Bar Mark Iii Grounding Plate
What is it, and shoud I install 1 in my 50 Ft express?
    Scholar:
  • 72 Answers
Hi, a grounding plate is put in place on the outside of your hull (on the keel) in order to protect against damage in the event of a lightning strike. There needs to be a network of metal ribbon/cable that is attached to all metallic objects throughout the vessel and then lead to the attachment points of the plate inside the bilges. This network will channel any electric surge from above the waterline to the plate and then the water itself in an attempt to prevent the strike from blowing holes in your boat! Hope this helps.
Posted on Nov 15, 2010
Testimonial: "Thks, Great info"
WHAT IS THE AMP THE COMPRESSOR SHOUD HAVE
The amperage should be stated on the motor name plate. Match your voltage to the amperage listed.
Oct 05, 2016 | Samsung RF267AEPN 26 cu. ft. French Door...
Ice maker freeze and turning arm works but no ice can come out ice is frozen?
yes, if the tray turns and twists it shoud dispense. Is there water coming in? Freezer temp could be too low.
Apr 07, 2015 | Samsung 26 Cu. Ft. Side-by-Side...
Equlvalent expression
Assume that the room are rectangular.
Let W be the unknown width of the dining room in feet
Area of living room= 10*12=120 ft^2
Area of dining room =10*W
Combined area= sum of the two areas= (120 + 10* W) ft^2
Alternatively, you can factor out the 10 to get
Combined area =10*(12+W) ft^2
Mar 09, 2014 | Office Equipment & Supplies
Is the King Kutter ATV SeederSpreader suitable for applying lime? If so what setting shoud be used? Thanks, Doug (Giles County, VA)
lime should be applied at 50 lbs per 100 sq ft which is heavy mark off 100sq and see what it takes at 3mph
Jan 29, 2011 | King Kutter ATV SeederSpreader 350Lb...
Start up current draw
Lock motor Amps ( LMA ) is the current draw when the compressor starts.This draw of current is less then 1sec.The amp amount shoud be on the compressor Name Plate.This amp draw is also the amps used when the compressor goes bad and locks up then the overload kicks out.
May 21, 2010 | Kenmore 5 cu. ft. / 142 liter Chest...
I just need to know where the alternator is located on a 2004 dodge neon 2.0L SXT
Fig. View of the alternator after removing the splash shield - 2.0L engines
Removal & Install - 2.0L Engines
  1. Before servicing the vehicle, refer to the Precautions section.
  2. Remove or disconnect the following:
    Negative battery cable Alternator jam nut, loosen only Alternator adjustment nut, loosen only Accessory drive splash shield Alternator lower bolt, loosen only Alternator drive belt Alternator field circuit wiring connector, push the RED locking tab to release Battery positive terminal Upper and lower bolts, move alternator off pivot bracket Pivot bracket Alternator
To install:
Install or connect the following:
Alternator Pivot bracket and torque the bolts to 40 ft. lbs. (54 Nm) Alternator, move it onto pivot bracket Alternator field circuit wiring connector, push RED locking tab in until it snaps in place Battery positive terminal Alternator drive belt Tension the drive belt to 100 lbs. (used) or 135 lbs. (new) Alternator adjustment bolt Alternator jam nut and torque nut to 40 ft. lbs. (54 Nm) Alternator mount bolts and torque the bolts to 40 ft. lbs. (54 Nm) Accessory drive splash shield
Fig. Alternator mounting-2.4L engine shown
I hope helps with this (remember rated this help) Good luck.
Jan 05, 2010 | 2004 Dodge Neon
Outlook Express - I am trying to change the spell check from French to English?
You need to change the dictionary in office. You can do this under Tools in Word clicking on Spelling and grammar when the options box opens up choose dictionary language and select English. This shoud reset it for all your office programs as your default. However, If you what to change Outlook only, Open Outlook and select tools, Options, Spelling, spelling and autocorrection and custom dictionaries to make a selection
Dec 30, 2009 | Microsoft Outlook Express
Lilly Wonder Bar Mark Iii Grounding Plate Logo
52 people viewed this question
Top Lilly Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Lilly Boating Expert? Answer questions, earn points and help others
