Question about Pioneer VSX-454 Receiver
This is not a pioneer vsx-454 receiver problem
What happens if you hook up a 32 ohm speaker and a 4 ohm speaker in parallel? im about to try it but am worried it will only power the 4 ohm speaker and hurt my 8-16 ohm amp? i was hoping doing such a strange thing would raise the 4 ohm load and lower the 32 ohm load into a useable range.
thanks for the help,
    Genius:
  • 1,199 Answers
I would not recomend doing this because the 4 ohm speaker is not enough to offset the 32 ohm speaker and the amp will have problems keeping up with the power consumption of the speakers and will eventully overheat and cause damage! (it will work but not well and not without risk to your amp!)
Please rate this quick response
Thank
You!
Posted on Jan 16, 2009
4 Suggested Answers
  • 3 Answers
SOURCE: listen to TV through my vsx-454
  1. Go To RADIOSHACK
  2. GO buy RCA Cables(red,white,yellow)
  3. If your Tv Has An RCA Output Connect the RCA Cables @ one End of the TV.
  4. Connect the Other End to THE VCR2 Input.
  5. SWITCH THE INPUT TO VCR2
Posted on Jun 14, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: diagram of pioneer receiver vsx-454 to show wire hookups
This site has the manual for downloading. You need to register but it's free.
Posted on Mar 02, 2010
  • 454 Answers
SOURCE: can I connect 4-ohm speakers to the VSX-455, which
No, you will burn up the amplifier, too much current flow.
Posted on Jul 30, 2010
Pioneer vsx-454
Any speaker that can handle 100 watts or more. This receiver is rated for 100 watts per channel into an 8 ohm speaker. If the speaker is less than that, it will make the amplifier work harder and heat up faster.
May 04, 2014 | Audio Players & Recorders
How do i connect a sub wooferto my reciever
I own 2 of these Pioneer VSX-D903S units.
The only way to hook a powered subwoofer up to a VSX-D903S is if your subwoofer is equipped with amplified/speaker level terminals on the back, in addition to the line-level input. If you only have a line-level input, do not attempt to hook it up to this receiver.
If you're lucky, and have speaker-level inputs on your powered subwoofer, you would use the amplified terminals (connect to B-channel on the receiver). DO NOT connect anything to the line-level connection.
Alternatively, you could build two unpowered subwoofers, then set the receiver's Impedance switch to LOW, then connect one enclosure to each of the "B-channel" outputs. Connect your regular left and right speakers to their corresponding "A-channel" outputs. [Impedance range: 4 Ohm minimum, 16 Ohm Maximum]
Jul 20, 2012 | Pioneer VSX-D903S Receiver
Diagram of pioneer receiver vsx-454 to show wire hookups
Feb 28, 2010 | Pioneer VSX-454 Receiver
Overloads with volume a third od the way up,i have 2 12 inch cerwin vegas hooked to it
fan_of_tony,
There is not much info in your question to properly answer it but here are a few things.
1) The VSX-D307 is a home receiver that is rated for no less than a 4 ohm load. If you have two 12" 4 ohm CV subs on the same channel and they are in parallel, that would create a 1.7 ohm load which would easily cause the problem.
2) If you have one on each channel connected along with speakers that are for you mids and highs, the way they are connected could be reducing the resistance load the amp will see which would easily cause the problem.
3) If you have one on each channel and no other speakers the problem would be simply that your speakers can use more power than the amp can produce. Thus you are able to raise the volume of the amp passed it's maximum output which would cause the amp to clip and the amp will go into overload protection.
4) Your receiver has an 8 ohm rated amp. Which means it can run at 4 ohms but the amp will produce more power at lower volumes on the knob setting and will max out at lower levels than if you were using a 8 ohm speakers.
In short, CV's can use a lot of power and your receiver, regardless of advertised power levels, cannot give the speakers what you are looking for in sound levels. Buy a larger dedicated amp for the CV's as the clipping from your Pioneer receiver is doing damage to your CV's. Your speaker's can hear the clipping before your ears can so damage will start to occur before your ears can hear the clipping.
-Chris
Jan 20, 2010 | Pioneer VSX-D307 Receiver
Looking to connect 4 speakers to the surround back
Series the speakers, they may not get as much power as you would like, but your receiver will last longer.
Aug 16, 2009 | Pioneer VSX-518-K Receiver
Bought new Denon receiver. Hooked up main speakers to speaker A and 3 sets of small speakers (outside, living room and dining room (in wall) to speaker B. I use a splitter for the 3 speakers on B. The...
Speakers have what they call an ohm rating. Your 570 watt receiver is 570 watts at a certain ohm load. I would imagine there might be a level difference between the 3 different speakers on B too. Anyway, if the speaker pairs have all different ohm ratings, or they are not the optimum rating for your 570 watt receiver, you will not get the full wattage rating to the speakers. Hope this helps.
Jun 23, 2009 | Pioneer VSX-454 Receiver
No audio output from Pioneer VSX-D608 Receiver
If it's under warranty..get a new one.
It's an internal breakdown ...tech service only.
Feb 05, 2009 | Pioneer VSX-D608 Receiver
Amatuer needs sub-woofer advice for Pioneer VSX-454...
Based upon your description, the subwoofer is just a speaker and is taken from the normal speaker outputs. Run your A channel to the sub and then from the sub to the left and right front speakers. That should do it.
Dan
Apr 08, 2008 | Pioneer VSX-454 Receiver
Multiple speakers in same outlet
How this reciever is set up is there are left and right A and left and right B Only one 8 ohm speaker should be attached per outlet. if you exceed that your driving the channel at a much lower resistance then the units designed for and the channel will burn up.. Oh it might last a short time but bet your last dollar it will burn up the channel if you over load it. Please dont forget to rate this.
Oct 15, 2006 | Pioneer VSX-454 Receiver
134 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
